hi I am using A C6711 dsp. I have an interrupt that operates at 16kHz. I want to add a LCD initialisation routine onto this interrupt, since i will only call LCD init once on power up and then not call it again. I am unsure of generating delays in the ISR though for the LCD. The system clock is 100Mhz and the ISR is 16khz So for 2 ms delay in the ISR for the LCDinit can i just use a simple for loop for 2ms / (1/16000) = 32 samples? isr() { static int LCD = 1; if(LCD) { call LCD routine once for(i=0;i<32;i++); //delay of 2 ms? writetoLCD; for(i=0;i<32;i++) writetoLCD; LCD = 0; } //do other processing in ISR } i do not think this is correct though? as in the ISR we are still at 100MHz? please excuse me as i do not have test hardware to check this when my program is running in real time. I am sure there will be more efficient means of doing this but i would just like to understand if i am correct? thanks John
interrupts and delays
Started by ●April 10, 2009
Reply by ●April 10, 20092009-04-10
johnstokes wrote:> hi > > I am using A C6711 dsp. I have an interrupt that operates at 16kHz. I > want to add a LCD initialisation routine onto this interrupt, since i will > only call LCD init once on power up and then not call it again. I am > unsure of generating delays in the ISR though for the LCD. > > The system clock is 100Mhz and the ISR is 16khz So for 2 ms delay in the > ISR for the LCDinit can i just use a simple for loop for 2ms / (1/16000) = > 32 samples? > > isr() > { > static int LCD = 1; > if(LCD) > { > call LCD routine once > for(i=0;i<32;i++); //delay of 2 ms? > writetoLCD; > > for(i=0;i<32;i++) > writetoLCD; > LCD = 0; > } > > //do other processing in ISR > > } > > > i do not think this is correct though? as in the ISR we are still at > 100MHz? please excuse me as i do not have test hardware to check this when > my program is running in real time. > > I am sure there will be more efficient means of doing this but i would > just like to understand if i am correct?Premise: You initialize the LCD only once. Premise: You initialize the LCD in the interrupt routine. Conclusion: The interrupt routine is called only once. Question: What is the interrupt routine for? Notice: Initializations are usually done without interrupts in a preamble to the main program. (That's how some interrupt registers are initialized.) Advice: When a device has a bust/~ready flag, use it instead of a timed delay. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●April 11, 20092009-04-11
On Apr 10, 10:50�am, "johnstokes" <rich_sedgew...@yahoo.com> wrote:> hi > > I am using A C6711 dsp. �I have an interrupt that operates at 16kHz. �I > want to add a LCD initialisation routine onto this interrupt, since i will > only call LCD init once on power up and then not call it again. �I am > unsure of generating delays in the ISR though for the LCD. � > > The system clock is 100Mhz and the ISR is 16khz �So for 2 ms delay in the > ISR for the LCDinit can i just use a simple for loop for 2ms / (1/16000) = > 32 samples? > > isr() > { > � �static int LCD = 1; > � � if(LCD) > � � { > � � �call LCD routine once > � � �for(i=0;i<32;i++); //delay of 2 ms? > � � �writetoLCD; > > � � �for(i=0;i<32;i++) > � � �writetoLCD; > � � �LCD �= 0; > � � } > > � �//do other processing in ISR > > } > > i do not think this is correct though? as in the ISR we are still at > 100MHz? please excuse me as i do not have test hardware to check this when > my program is running in real time. > > I am sure there will be more efficient means of doing this but i would > just like to understand if i am correct? > > thanks > JohnThe delay of 2 msec should be realized by waiting until the ISR runs 32 more times, not by waiting 2 msec inside the ISR. John
