Hi, I am implementing the MUSIC DOA estimator in TI DSP. I am searching for a better implementation of Singular value decomposition of a matrix algorithm in DSP. Can anyone throw some light on that? Is it efficient to implement the LAPACK routines in DSP or is there any better techniques? Also can anyone tell me the links where I can learn about SVD implementations. Thanks. Regards, Krish
Help please..
Started by ●April 10, 2009
Reply by ●April 10, 20092009-04-10
On 10 Apr, 19:46, "krish_dsp" <nmkr...@gmail.com> wrote:> Hi, > I am implementing the MUSIC DOA estimator in TI DSP. I am searching for a > better implementation of Singular value decomposition of a matrix > algorithm > in DSP. Can anyone throw some light on that?Depends on what you mean by 'better'. It's not very likely you will find faster general-purpose implementations than LAPACK on general-purpose platforms.> Is it efficient to implement the LAPACK routines in DSP or is there any > better techniques?Again, it depends on what you mean by 'better'. LAPACK used to be available as FORTRAN source code (and presumably it still is), so if you find a compatible fortran compiler, you might be able to compile original LAPACK code for your target platform. This might be 'more efficient' in terms of man-hours needed to get the thing up and running. But run-time might not be optimal, and there are no guarantees you can compile the source code for your target. Even if you can, there is the question if the library (the whole LAPACK is large) fits into the available memory, or if you can identify and isolate only the parts you need. On the other hand, hand-crafted assembly code might be faster and smaller, but might take ages to produce and test.> Also can anyone tell me the links where I can learn about SVD > implementations.The book 'Matrix Computations' by Golub and van Loan is mandatory. Start with that one, and work out from the references there. There was a guy, Steinbeck(?), who used to publish on fast ESPRIT algorithms some ten years ago. Don't know the details of those algorithms, though, or if they are convertible to use with MUSIC. Rune
"krish_dsp" <nmkrish@gmail.com> writes:> Hi, > I am implementing the MUSIC DOA estimator in TI DSP. I am searching for a > better implementation of Singular value decomposition of a matrix > algorithm > in DSP. Can anyone throw some light on that? > Is it efficient to implement the LAPACK routines in DSP or is there any > better techniques?If it's for the 67x, check out TI's DSP library: http://focus.ti.com/docs/toolsw/folders/print/sprc121.html> Also can anyone tell me the links where I can learn about SVD > implementations.@BOOK{meyer, title = "{Matrix Analysis and Applied Linear Algebra}", author = "{Carl~D.~Meyer}", publisher = "Society for Industrial and Applied Mathematics", year = "2000"}> Thanks. > Regards, > Krish-- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://www.digitalsignallabs.com
