Hello all, Please, I wanna know more about maximal ratio combining post DFT techniques. I'm studing this receving method, also i found a chipset improving this technique: http://www.teamcast.com/en/maj-e/c2a2i15040/products/dibcom-products/dvb-t-diversity-demodulation-chipset.htm but i do not understand the theory. The combining is frequency domain ? Someone can help me ? Best regards
about MRC techniques for OFDM
Started by ●April 13, 2009
Reply by ●April 13, 20092009-04-13
On Apr 13, 4:30 am, odysse...@tin.it wrote:> Hello all, > > Please, I wanna know more about maximal ratio combining post DFT > techniques. I'm studing this receving method, also i found a chipset > improving this technique: > > http://www.teamcast.com/en/maj-e/c2a2i15040/products/dibcom-products/... > > but i do not understand the theory. The combining is frequency > domain ? Someone can help me ? > > Best regardsIf you want to just understand maximal ratio combining, any of the standard communications textbooks will explain it in good detail. See, for example, Proakis: Digital Communications. That theory should carry over to frequency-domain combining too. Otherwise, your question is too generic. Please ask a more specific question on whatever it is you do not understand. Thanks, Dilip.
> Otherwise, your question is too generic. Please ask a more specific > question > on whatever it is you do not understand.sorry i was too generic. Digital Communications is a good book for MRC theory but i wanna know more about MRC for OFDM modulation. In particular I am interested in understanding where the combining is done (pre or post DFT). In other words it's better combing the OFDM symbol in time domain or combing the symbol which modulate the single sub-carriers (i.e in frequency domain) ?
odyssey25@tin.it wrote:>>Otherwise, your question is too generic. Please ask a more specific >>question >>on whatever it is you do not understand. > > > sorry i was too generic.> Digital Communications is a good book for MRC theory but i wanna know > more about MRC for OFDM modulation. In particular I am interested in > understanding where the combining is done (pre or post DFT).Of course post FFT is better, since you can compute MRC separately for each subcarririer. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> Of course post FFT is better, since you can compute MRC separately for > each subcarririer.Ok. Now, let us consider a system with two antennas. For these two antennas, i think, the chipest has two different " RF front ends + COFMD demodulator" . Some more, for each sub-carrier the signals from different antennas are linearly combined. Now, a weight factor (with zero phase) is associated with the k-th subcarrier. Well, i do not understand how can be possible calculate these weight factors, if they are equal for all the OFDM subcarriers of the same received signal or they are different for each sub-carrier (in the same receive signal). I hope I made myself clear
odyssey25@tin.it wrote:>>Of course post FFT is better, since you can compute MRC separately for >>each subcarririer. > > > Ok.What OK? Do you think you did me a favor?> Now, let us consider a system with two antennas. For these two > antennas, i think, the chipest has two different " RF front ends + > COFMD demodulator" . Some more, for each sub-carrier the signals from > different antennas are linearly combined. Now, a weight factor (with > zero phase) is associated with the k-th subcarrier. Well, i do not > understand how can be possible calculate these weight factors, if they > are equal for all the OFDM subcarriers of the same received signal or > they are different for each sub-carrier (in the same receive signal). > I hope I made myself clearOMFG what a clueless retard. Go read your textbooks, idiot. VLV
Reply by ●April 14, 20092009-04-14
On Apr 13, 1:46�pm, odysse...@tin.it wrote:> > Of course post FFT is better, since you can compute MRC separately for > > each subcarririer. > > Ok. > Now, let us consider a system with two antennas. For these two > antennas, i think, the chipest has two different " RF front ends + > COFMD demodulator" . Some more, for each sub-carrier the signals from > different antennas are linearly combined. Now, a weight factor (with > zero phase) is associated with the k-th subcarrier. Well, i do not > understand how can be possible calculate these weight factors, if they > are equal for all the OFDM subcarriers of the same received signal or > they are different for each sub-carrier (in the same receive signal). > I hope I made myself clearIt's not completely clear but the gist seems to be that you have a 2- antenna receiver. The signals from the two antennas are combined pre- FFT, then the FFT is taken and the weights are applied post-FFT to the combined signal. In this case, you can calculate the weights that need to be applied by a training method based on transmitting and receiving a known sequence. Yes, the weights will be different for each subcarrier. This is also sometimes referred to as a frequency-domain equalizer (FEQ/FDQ) as opposed to a time-domain equalizer (TEQ/TDQ). Thanks, Dilip.
On Mon, 13 Apr 2009 10:46:43 -0700 (PDT), odyssey25@tin.it wrote:>> Of course post FFT is better, since you can compute MRC separately for >> each subcarririer. > >Ok. >Now, let us consider a system with two antennas. For these two >antennas, i think, the chipest has two different " RF front ends + >COFMD demodulator" . Some more, for each sub-carrier the signals from >different antennas are linearly combined. Now, a weight factor (with >zero phase) is associated with the k-th subcarrier. Well, i do not >understand how can be possible calculate these weight factors, if they >are equal for all the OFDM subcarriers of the same received signal or >they are different for each sub-carrier (in the same receive signal). >I hope I made myself clear >Not clear. You seemed to be saying that you combined them first and then applied weighting. Are you talking about the EQ weights or the MRC weights? Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Apr 14, 7:39�am, Dilip Warrier <dili...@yahoo.com> wrote:> On Apr 13, 1:46�pm, odysse...@tin.it wrote: > > > > Of course post FFT is better, since you can compute MRC separately for > > > each subcarririer. > > > Ok. > > Now, let us consider a system with two antennas. For these two > > antennas, i think, the chipest has two different " RF front ends + > > COFMD demodulator" . Some more, for each sub-carrier the signals from > > different antennas are linearly combined. Now, a weight factor (with > > zero phase) is associated with the k-th subcarrier. Well, i do not > > understand how can be possible calculate these weight factors, if they > > are equal for all the OFDM subcarriers of the same received signal or > > they are different for each sub-carrier (in the same receive signal). > > I hope I made myself clear > > It's not completely clear but the gist seems to be that you have a 2- > antenna receiver. The signals from the two antennas are combined pre- > FFT, then the FFT is taken and the weights are applied post-FFT to the > combined signal. In this case, you can calculate the weights that need > to be applied by a training method based on transmitting and receiving > a known sequence. Yes, the weights will be different for each > subcarrier.Once the signals are combined, you can not apply different weights to them. You need to apply different weights to different signals before combining. However, if you want to combine them pre-fft, as the training signal is in frequency domain, you would need to estimate the frequency response first and then ifft it to get the response in time domain. If the frequency of the two antennas are not perfectly matched, things can get very ugly. I would say it is not a good approach to combine them pre-fft.>This is also sometimes referred to as a frequency-domain > equalizer (FEQ/FDQ) as opposed to a time-domain equalizer (TEQ/TDQ). >This has nothing to do with frequency or time domain equalization.> Thanks, > Dilip.
