On Apr 16, 1:39�am, "sasuke" <a.ssjg...@gmail.com> wrote:> I am using MATLAB to generate close to 10^8 samples of a Rayleigh fading > channel using Jakes method. Once I generate these samples, I have to then > create a 20 x 20 autocorrelation matrix. I am using MATLAB to do this. > MATLAB works perfectly for 10^6 samples, but once the number of samples > increases slightly above 50 * 10^6, MATLAB throws an "OUT of Memory" error. > I tried some techniques given inwww.mathworks.comto overcome this > problem, but they don't seem to help once the number of samples goes above > 10^7.You must be using a machine from several years ago, or are using an algorithm that requires lots of extra memory. 50*10^6 double- precision samples is under 400MB of memory. 10^8 double-precision numbers requires under a GB of memory, which should be fine on any recent computer. FFTW on my computer (which is what is used by Matlab) can compute an FFT of 10^8 double-precision real samples in under half a second on an Intel Core 2. You can calculate the autocorrelation of 10^8 samples with an FFT of only twice the length, so you should be fine. The advantage of using C instead of Matlab here would be that C gives you much better control over memory allocation; you might just be being careless and not realizing how many copies of your array you are making in Matlab. Regards, Steven G. Johnson
Autocorrelation matrix of a long sequence
Started by ●April 16, 2009
Reply by ●April 17, 20092009-04-17
On 17 Apr, 16:11, "Steven G. Johnson" <stev...@alum.mit.edu> wrote:> On Apr 16, 1:39�am, "sasuke" <a.ssjg...@gmail.com> wrote: > > > I am using MATLAB to generate close to 10^8 samples of a Rayleigh fading > > channel using Jakes method. Once I generate these samples, I have to then > > create a 20 x 20 autocorrelation matrix. I am using MATLAB to do this. > > MATLAB works perfectly for 10^6 samples, but once the number of samples > > increases slightly above 50 * 10^6, MATLAB throws an "OUT of Memory" error. > > I tried some techniques given inwww.mathworks.comtoovercome this > > problem, but they don't seem to help once the number of samples goes above > > 10^7. > > You must be using a machine from several years ago, or are using an > algorithm that requires lots of extra memory. �50*10^6 double- > precision samples is under 400MB of memory.Once upon a time matlab by default used algorithms based on verbatim implementations of matrix algebra expressions. In recent times that's not quite as much of a default, for canned functions supplied with matlab or its toolboxes, but this 'vectorization' nonsense certainly tends to lead naive users in that direction. With that in mind, I would expect 'experienced' naive users [*] to implement the computation of an K x K autocorrelation matrix from an N-length vector as something like 1) Build a K x N'ish data matrix X from the input data (maybe adding or subtracting end effects, depending on what estimator one implements) 2) Do the final computation as Rxx = X*X'; Which means one needs at least one, maybe two, copies of an K x N'ish matrix in memory to do the computations. With the numbers the OP mentions, that's 20 * 1e8 = 2e9 elements, or 1.6e10 bytes per copy of the matrix. With such numbers there's no wonder he runs out of memory. I don't have access to the signal processing toolbox, so I can't check it out myself. Does anybody know what algorithms matlab SPT functions actually use to compute the autocorrelation matrices? Rune [*] Users who know enough matlab to know about 'vectorization', but not enough about computers or programming to understand what they actually are doing.
On Apr 17, 1:42�pm, Rune Allnor <all...@tele.ntnu.no> wrote:> On 17 Apr, 09:54, itakatz <itak...@gmail.com> wrote: > > > > 4) �Compute the DFT of the zero-padded frame > > > 5) �Compute the periodogram as the squared magnitude > > > � � of the spectrum coefficients > > > 6) �Compute the IDFT of the periodogram > > > > Rune > > > A little bit off-topic: > > > Since multiplication in frequency domain is the same as (circular) > > convolving in the time domain, > > Convolution by DFT is circular, which is why you need > to zero-pad before computing the DFT. The convolution > of two N-length sequences gives as result a sequence > with at most 2N-1 non-zero elements. Zero-padding to > at least 2N-1 total length allocates the space needed > to avoid wrap-around effects. Depending on what > implementation of the FFT you have available, you might > zero-pad further, to the next power of 2. > > > shouldn't one of the segments be time- > > reversed before zero-padding and DFTing? > > Time-reversing in time domain is not sufficient to > handle wrap-around effects from circular convolution, > since you don't change the length of the input sequence. > > With pen and paper your trick might work, but in the > computer you need to allocate memory and find a map > from the 'true' index space k = -N,...,N to the RAM > address space, BaseAddress + {0,1,...2N}. > > Essentially, you need to do some book-keeping to find > out if the rxx[0] coefficient turns out in the index 0 > position of the buffer, or in the index N position. > > > in that way the auto- > > correlation is re-written as a convolution, and then it is ok to > > compute it in the freq domain. Am I right? > > In time domain, reversing the direction of a sequence x[n] > is written as x[-n]. It's a standard excercise in most DSP > books to show that if > > x[n] <-> X[k] > > is a DFT pair, then > > x[-n] <-> X'[k] > > where X' is the complex conjugate of X, is also a DFT pair. > Well, this is correct at least when x[n] is real-valued, > it might not be for complex-valued x[n]. > > Anyway, convolving x[n] by x[-n] in time domain, which > is a common estimator for the autocorrelation function > (save some scaling coefficients), can alternatively be > computed in frequency domain as a product of the DFTs: > > Sxx[k] = X[k]X'[k] = |X[k]|^2. > > Hence my algorithm works, once the relevant scaling > coefficients have been accounted for. > > RuneThanks. In the meantime I did the simple math and I indeed got that the DFT of the time reversed signal is the c.c. of the DFT of the original signal, up to a linear phase, which accounts for the fact that my time reversed signal was x[N-n-1] instead of x[-n].
Reply by ●April 18, 20092009-04-18
On 17 Apr, 23:18, itakatz <itak...@gmail.com> wrote:> On Apr 17, 1:42�pm, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > > > On 17 Apr, 09:54, itakatz <itak...@gmail.com> wrote: > > > > > 4) �Compute the DFT of the zero-padded frame > > > > 5) �Compute the periodogram as the squared magnitude > > > > � � of the spectrum coefficients > > > > 6) �Compute the IDFT of the periodogram > > > > > Rune > > > > A little bit off-topic: > > > > Since multiplication in frequency domain is the same as (circular) > > > convolving in the time domain, > > > Convolution by DFT is circular, which is why you need > > to zero-pad before computing the DFT. The convolution > > of two N-length sequences gives as result a sequence > > with at most 2N-1 non-zero elements. Zero-padding to > > at least 2N-1 total length allocates the space needed > > to avoid wrap-around effects. Depending on what > > implementation of the FFT you have available, you might > > zero-pad further, to the next power of 2. > > > > shouldn't one of the segments be time- > > > reversed before zero-padding and DFTing? > > > Time-reversing in time domain is not sufficient to > > handle wrap-around effects from circular convolution, > > since you don't change the length of the input sequence. > > > With pen and paper your trick might work, but in the > > computer you need to allocate memory and find a map > > from the 'true' index space k = -N,...,N to the RAM > > address space, BaseAddress + {0,1,...2N}. > > > Essentially, you need to do some book-keeping to find > > out if the rxx[0] coefficient turns out in the index 0 > > position of the buffer, or in the index N position. > > > > in that way the auto- > > > correlation is re-written as a convolution, and then it is ok to > > > compute it in the freq domain. Am I right? > > > In time domain, reversing the direction of a sequence x[n] > > is written as x[-n]. It's a standard excercise in most DSP > > books to show that if > > > x[n] <-> X[k] > > > is a DFT pair, then > > > x[-n] <-> X'[k] > > > where X' is the complex conjugate of X, is also a DFT pair. > > Well, this is correct at least when x[n] is real-valued, > > it might not be for complex-valued x[n]. > > > Anyway, convolving x[n] by x[-n] in time domain, which > > is a common estimator for the autocorrelation function > > (save some scaling coefficients), can alternatively be > > computed in frequency domain as a product of the DFTs: > > > Sxx[k] = X[k]X'[k] = |X[k]|^2. > > > Hence my algorithm works, once the relevant scaling > > coefficients have been accounted for. > > > Rune > > Thanks. > > In the meantime I did the simple math and I indeed got that the DFT of > the time reversed signal is the c.c. of the DFT of the original > signal, up to a linear phase, which accounts for the fact that my time > reversed signal was x[N-n-1] instead of x[-n].The practical implication would probably be that you find the rxx[0] element of the autocorrelation in array element with index N, instead of the element with index 0. Not a big deal, but a detail to keep track of. Rune
