I will like to know how I can get the equivalent magnitude of a non stationary signal in the time from a power spectral density plot of the signal.
Non stationary signal Processing
Started by ●April 17, 2009
Reply by ●April 17, 20092009-04-17
On Apr 17, 12:28�pm, "ayodei" <olufem...@yahoo.com> wrote:> I will like to know how I can get the equivalent magnitude of a non > stationary signal in the time from a power spectral density plot of the > signal.So would I, let me know when you figure it out ;)
On Apr 18, 4:28�am, "ayodei" <olufem...@yahoo.com> wrote:> I will like to know how I can get the equivalent magnitude of a non > stationary signal in the time from a power spectral density plot of the > signal.You cannot. It's not a unique transformation back to the time-domain and the randomness comes from an ensemble which is infinite. You can get the autocorrelation but that's all. Hardy
Reply by ●April 18, 20092009-04-18
>On Apr 18, 4:28=A0am, "ayodei" <olufem...@yahoo.com> wrote: >> I will like to know how I can get the equivalent magnitude of a non >> stationary signal in the time from a power spectral density plot ofthe>> signal. > >You cannot. It's not a unique transformation back to the time-domain >and the randomness comes from an ensemble which is infinite. You can >get the autocorrelation but that's all. > > >Hardy >Hardy, Do you suggestions on how I can obtain the frequencies and corresponding magnitudes of a non stationary signal?
On Sat, 18 Apr 2009 01:16:53 -0500, ayodei wrote:>>On Apr 18, 4:28=A0am, "ayodei" <olufem...@yahoo.com> wrote: >>> I will like to know how I can get the equivalent magnitude of a non >>> stationary signal in the time from a power spectral density plot of > the >>> signal. >> >>You cannot. It's not a unique transformation back to the time-domain and >>the randomness comes from an ensemble which is infinite. You can get the >>autocorrelation but that's all. >> >> >>Hardy >> > Hardy, > Do you suggestions on how I can obtain the frequencies and corresponding > magnitudes of a non stationary signal?I think the point that Hardy is trying to make is that when the signal is non-stationary the concepts of "frequency" and "power" (or "magnitude") lose a lot of their meaning, and therefore their utility as tools for understanding a signal's behavior as it wends it's way through any given system. You _may_ be able to assign some very sensible meanings to the terms for the purposes of the particular problem that you are working on, but there is no universally sensible set of definitions for this sort of thing when the signal is non-stationary. HTH. -- http://www.wescottdesign.com
Please can anyone help suggest how I can analyse a non stationary signal to get its frequency and corresponding amplitude.>On Sat, 18 Apr 2009 01:16:53 -0500, ayodei wrote: > >>>On Apr 18, 4:28=A0am, "ayodei" <olufem...@yahoo.com> wrote: >>>> I will like to know how I can get the equivalent magnitude of a non >>>> stationary signal in the time from a power spectral density plot of >> the >>>> signal. >>> >>>You cannot. It's not a unique transformation back to the time-domainand>>>the randomness comes from an ensemble which is infinite. You can getthe>>>autocorrelation but that's all. >>> >>> >>>Hardy >>> >> Hardy, >> Do you suggestions on how I can obtain the frequencies andcorresponding>> magnitudes of a non stationary signal? > >I think the point that Hardy is trying to make is that when the signal is>non-stationary the concepts of "frequency" and "power" (or "magnitude") >lose a lot of their meaning, and therefore their utility as tools for >understanding a signal's behavior as it wends it's way through any given>system. > >You _may_ be able to assign some very sensible meanings to the terms for>the purposes of the particular problem that you are working on, but there>is no universally sensible set of definitions for this sort of thing when>the signal is non-stationary. > >HTH. > >-- >http://www.wescottdesign.com >
On Apr 18, 5:54�am, "ayodei" <olufem...@yahoo.com> wrote:> Please can anyone help suggest how I can analyse a non stationary signal to > get its frequency and corresponding amplitude. > > >On Sat, 18 Apr 2009 01:16:53 -0500, ayodei wrote: > > >>>On Apr 18, 4:28=A0am, "ayodei" <olufem...@yahoo.com> wrote: > >>>> I will like to know how I can get the equivalent magnitude of a non > >>>> stationary signal in the time from a power spectral density plot of > >> the > >>>> signal. > > >>>You cannot. It's not a unique transformation back to the time-domain > and > >>>the randomness comes from an ensemble which is infinite. You can get > the > >>>autocorrelation but that's all. > > >>>Hardy > > >> Hardy, > >> Do you suggestions on how I can obtain the frequencies and > corresponding > >> magnitudes of a non stationary signal? > > >I think the point that Hardy is trying to make is that when the signal is > >non-stationary the concepts of "frequency" and "power" (or "magnitude") > >lose a lot of their meaning, and therefore their utility as tools for > >understanding a signal's behavior as it wends it's way through any given > >system. > > >You _may_ be able to assign some very sensible meanings to the terms for > >the purposes of the particular problem that you are working on, but there > >is no universally sensible set of definitions for this sort of thing when > >the signal is non-stationary. > > >HTH. > > >-- > >http://www.wescottdesign.comhttp://en.wikipedia.org/wiki/Spectrogram
On Apr 17, 11:28�am, "ayodei" <olufem...@yahoo.com> wrote:> I will like to know how I can get the equivalent magnitude of a non > stationary signal in the time from a power spectral density plot of the > signal.The Hilbert Huang Transform (ha! I will stop discussing this now) -Martin
On Sat, 18 Apr 2009 04:54:38 -0500, ayodei wrote:> Please can anyone help suggest how I can analyse a non stationary signal > to get its frequency and corresponding amplitude.To rephrase: "Please could someone answer my question with the answer I want to hear?" For that, you need to go into management. Hire someone, tell them what you want to hear, tell them you'll fire them if they don't tell you what you want to hear, then sit back and be satisfied. -- http://www.wescottdesign.com
On Sat, 18 Apr 2009 04:54:38 -0500, ayodei wrote:> Please can anyone help suggest how I can analyse a non stationary signal > to get its frequency and corresponding amplitude.You're getting thoughtful answers to an ill-posed question. Because the question is ill-posed and can't be answered truthfully and meaningfully in the form you pose it, the answers you're getting are details as to why the question is ill posed. You are responding to this by asking the same damn question over and over again. How in the world do you think that's going to help you? If there were a good answer to your question as posed, someone would have answered it so far. Instead of just whining louder, try some of the common strategies for correcting the problem: say "I see that my question can't be answered, what question should I ask?". Or "I think this should be answerable (and detail why), or "why isn't my question answerable". Or tell us what you're trying to _do_ with the answer to the question, and see if someone has some positive suggestions. Just don't ask the same damn question a forth time. Twice is too much, three times in getting irritating. -- http://www.wescottdesign.com
