Would someone explain PLL based clock? Phase locked loop Thanks
PLL based Clock
Started by ●April 21, 2009
Reply by ●April 21, 20092009-04-21
justinvil1103 wrote:> Would someone explain PLL based clock? > > Phase locked loop >That's like asking "would someone explain dirt?" What part of the vast set of possibilities do you need to be informed of? I would assume, hearing that phrase, that it's a clock line that's phase locked to some source for some reason. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On Apr 21, 5:26�pm, "justinvil1103" <WillerJustin...@Bellsouth.net> wrote:> Would someone explain PLL based clock? > > Phase locked loop > > ThanksIn a processor, FPGA, or data acquisition card, a PLL can be used to multiply an input clock up to a higher rate. The multiplication factor is typically programmable. It's basically a synthesizer. John
Reply by ●April 23, 20092009-04-23
http://lmgtfy.com/?q=phase+locked+loop "justinvil1103" <WillerJustinvil@Bellsouth.net> wrote in message news:XYSdnTMVddiKp3PUnZ2dnUVZ_tSdnZ2d@giganews.com...> Would someone explain PLL based clock? > > Phase locked loop > > Thanks
>http://lmgtfy.com/?q=phase+locked+loop > >"justinvil1103" <WillerJustinvil@Bellsouth.net> wrote in message >news:XYSdnTMVddiKp3PUnZ2dnUVZ_tSdnZ2d@giganews.com... >> Would someone explain PLL based clock? >> >> Phase locked loop >> >> Thanks > > >That is a great link! That domain is definitely going in my back pocket for future use.
