Hi~ Here I use gardner TED in 16QAM receiver. But I got a problem on the design on loop filter. Is there some guide on the design? I found some references, but not worked. Carlin~
gardner TED -- loop filter design
Started by ●April 22, 2009
Reply by ●April 22, 20092009-04-22
On Apr 22, 4:16�am, "Carlin" <myqs...@126.com> wrote:> Hi~ > Here I use gardner TED in 16QAM receiver. > But I got a problem on the design on loop filter. > > Is there some guide on the design? I found some references, but not > worked. > > Carlin~Mengali, d'Andrea, "Synchronization Techniques for Digital Receivers."
Hey Julius Sorry to jump in the discussion. That book by Meyr is pretty good but I just have one doubt. My receiver works with the synchronization algorithm I am using. I am getting the BER results for uncoded QPSK which is very close to that of perfect synchronization. But when I use channel coding, why the BER is degraded when compared with BER for coded QPSK with perfect synchronisation. I can think of one reason is that Linear Interpolation introduces some sort of distortion. Any inputs from your side? Thanks Chintan
On Apr 22, 8:49�am, "cpshah99" <cpsha...@rediffmail.com> wrote:> Hey Julius > > Sorry to jump in the discussion. > > That book by Meyr is pretty good but I just have one doubt.Actually, I recommended a book by Mengali and d'Andrea ....> My receiver works with the synchronization algorithm I am using. I am > getting the BER results for uncoded QPSK which is very close to that of > perfect synchronization. But when I use channel coding, why the BER is > degraded when compared with BER for coded QPSK with perfect > synchronisation. > > I can think of one reason is that Linear Interpolation introduces some > sort of distortion.Yes, of course this is the case, even in floating points. You need to test the SNR degradation from your linear interpolator. It is always a function of {oversampling rate, interpolator order, fractional delay, input SNR, bit precision}. Typically the last two are ignored, since if you design it properly they should be very small. Try plotting the MSE for a sinusoid with different relative frequency normalized to your sampling rate, averaged over random phase but same fractional delay. Now change the fractional delay and try it again. Then try different frequencies. I don't have a reference handy, but I'm sure this is already tabulated somewhere. Julius
Hey Julius Thanks for replying. I was thinking, initialy I could not understand anything about timing (rt now also I dont know everything), but after I realised how these book put this problem in mathematical form, it was easy. Most of the books assume that after the receive filter they have got raised cosine pulse, which is not the case in the problem that I am dealing. I have delay, multipath, time scaling and noise. But it is more fascinating when the problem is clear. Thanks again. Chintan
On Apr 22, 1:50�pm, "cpshah99" <cpsha...@rediffmail.com> wrote:> Hey Julius > > Thanks for replying. > > I was thinking, initialy I could not understand anything about timing (rt > now also I dont know everything), but after I realised how these book put > this problem in mathematical form, it was easy. Most of the books assume > that after the receive filter they have got raised cosine pulse, which is > not the case in the problem that I am dealing. I have delay, multipath, > time scaling and noise. > > But it is more fascinating when the problem is clear.There you go! That's the spirit!
On Apr 23, 1:50�am, "cpshah99" <cpsha...@rediffmail.com> wrote:> Hey Julius > > Thanks for replying. > > I was thinking, initialy I could not understand anything about timing (rt > now also I dont know everything), but after I realised how these book put > this problem in mathematical form, it was easy. Most of the books assume > that after the receive filter they have got raised cosine pulse, which is > not the case in the problem that I am dealing. I have delay, multipath, > time scaling and noise. > > But it is more fascinating when the problem is clear. > > Thanks again. > > ChintanThe raised cosine pulse filtering is largely irrelvant to this problem. Gardner is normally used before the equalizer, so depending on the nature of your channel it is trying to sync to a horribly distorted version of the signal. So, what you have is the normal case. The problem with comms books is they focus so much on the clean cases, or taking the possible impairments one by one, that trying to handle the real world can be a nasty shock after reading them. :-) Steve
Reply by ●April 23, 20092009-04-23
>On Apr 22, 4:16=A0am, "Carlin" <myqs...@126.com> wrote: >> Hi~ >> Here I use gardner TED in 16QAM receiver. >> But I got a problem on the design on loop filter. >> >> Is there some guide on the design? I found some references, but not >> worked. >> >> Carlin~ > >Mengali, d'Andrea, "Synchronization Techniques for Digital Receivers." >Thank you~
Hi Steve>The raised cosine pulse filtering is largely irrelvant to this >problem. Gardner is normally used before the equalizer, so depending >on the nature of your channel it is trying to sync to a horribly >distorted version of the signal. So, what you have is the normal case. >I have not worked on Gardner timing recovery yet, but this is conventional that in receiver first comes synchronization and then equalizer and so on. But I have had a look on many books and theses that they say received signal y=\sum I_n g(t-nT-\tau) where g(t) is raised cosine. So basically they assume as you have said mostly one impairement. Now, in my underwater acoustic case, I have additional term, time scaling on top of all these. So far as I know, it is not normal, because in radio comms even if you are travelling at 160km/hr, the scalling factor a=v/c=10^-7 so basically u can ignore the time scaling. I might be wrong in claiming that the problem that I am dealing is not normal.>trying to handle>the real world can be a nasty shock after reading them. :-) >Tell me about it. I had almost gone mad :-) and I got this clarified when I was reading one spy novel. Chintan
