http://www.ee.washington.edu/conselec/A95/projects/surround/surround.html "As a reference, compact discs (CDs) have a dynamic range of 96 dB using 16-bit Pulse Code Modulation (PCM), and a resolution of 165 bits per audio sample operating at a sampling rate of 44.1 kHz. This is 705,600 bits of data per second per channel. The CD can store up to 74 minutes of two channel music on a single disc." What equation do I use gets the number of bits per sample? How did that website get 165 bits per audio sample? Isn't CD audio 16 bits/sample? 44100 [16] = 705600 CD is stereo, so 705600 [2] = 1411200 2^16 = 65536 different levels of loudness 16-bit = 16[6] = 96 dB dynamic range I am still confused about the 165 bit per audio sample. Is it a typo?
Math Forumla giving 165 bits per sample?
Started by ●March 16, 2004
Reply by ●March 16, 20042004-03-16
Just a typo. 165 should be 16. Probably slipped off the 6 and hit the 5. "Curious" <curious11112001@yahoo.com> wrote in message news:34a4f456.0403161543.48a25f28@posting.google.com...> http://www.ee.washington.edu/conselec/A95/projects/surround/surround.html > > "As a reference, compact discs (CDs) have a dynamic range of 96 dB > using 16-bit Pulse Code Modulation (PCM), and a resolution of 165 bits > per audio sample operating at a sampling rate of 44.1 kHz. This is > 705,600 bits of data per second per channel. The CD can store up to 74 > minutes of two channel music on a single disc." > > What equation do I use gets the number of bits per sample? > > How did that website get 165 bits per audio sample? > > Isn't CD audio 16 bits/sample? > > 44100 [16] = 705600 > > CD is stereo, so 705600 [2] = 1411200 > > 2^16 = 65536 different levels of loudness > > 16-bit = 16[6] = 96 dB dynamic range > > I am still confused about the 165 bit per audio sample. Is it a typo?
Reply by ●March 17, 20042004-03-17
On 16 Mar 2004 15:43:38 -0800, Curious wrote:> 16-bit = 16[6] = 96 dB dynamic range96dB = 20*log(2^16)> I am still confused about the 165 bit per audio sample. Is it a typo?No, but the first 149 bits are zero. ;-) -- Mike --
Mike wrote:> On 16 Mar 2004 15:43:38 -0800, Curious wrote: > > >>16-bit = 16[6] = 96 dB dynamic range > > > 96dB = 20*log(2^16) > > >>I am still confused about the 165 bit per audio sample. Is it a typo? > > > No, but the first 149 bits are zero. ;-) >But wouldn't that introduce a significant DC offset ? ;-) Paul
