Hello, I have a continuous spectral plot that I need to filter. The spectrum is unique in that at a glance it looks like white noise, however if you look closer there are bins (frequencies) that have constant amplitudes. The problem is if I simply average the continuous spectrum, the noise averages to the same amplitudes as the constants. What would be the best algorithm to extract these constant amplitudes/frequencies? Would video averaging work or does it just average the noise and I wouldn't see the constants? Thomas
Filtering...looking for constant amplitudes
Started by ●April 28, 2009
Reply by ●April 28, 20092009-04-28
On Apr 28, 1:08�pm, "Thomas Magma" <somewh...@overtherainbow.com> wrote:> Hello, > > I have a continuous spectral plot that I need to filter. The spectrum is > unique in that at a glance it looks like white noise, however if you look > closer there are bins (frequencies) that have constant amplitudes. The > problem is if I simply average the continuous spectrum, the noise averages > to the same amplitudes as the constants. What would be the best algorithm to > extract these constant amplitudes/frequencies? Would video averaging work or > does it just average the noise and I wouldn't see the constants? > > ThomasCan you decrease the resolution bandwidth (larger FFT)? John
Reply by ●April 29, 20092009-04-29
Thomas Magma wrote:> Hello, > > I have a continuous spectral plot that I need to filter. The spectrum is > unique in that at a glance it looks like white noise, however if you look > closer there are bins (frequencies) that have constant amplitudes. The > problem is if I simply average the continuous spectrum, the noise averages > to the same amplitudes as the constants. What would be the best algorithm to > extract these constant amplitudes/frequencies? Would video averaging work or > does it just average the noise and I wouldn't see the constants?Obvious answer: average the complex spectrum, not the power spectrum. If you only have the power spectrum, then compute the mean and the deviation for every bin; estimate S/N in the bin from there. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On 28 Apr, 19:08, "Thomas Magma" <somewh...@overtherainbow.com> wrote:> Hello, > > I have a continuous spectral plot that I need to filter. The spectrum is > unique in that at a glance it looks like white noise, however if you look > closer there are bins (frequencies) that have constant amplitudes. The > problem is if I simply average the continuous spectrum, the noise averages > to the same amplitudes as the constants. What would be the best algorithm to > extract these constant amplitudes/frequencies? Would video averaging work or > does it just average the noise and I wouldn't see the constants?The answer depends entirely on what you attempt to do. What kind of application is this? Exactly what is it you try to infer from the data? The mere presence of sinusoidals? Frequencies? Amplitudes? Bandwidths? Rune
"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message news:_fYJl.15429$hc1.2488@flpi150.ffdc.sbc.com...> > > Thomas Magma wrote: > >> Hello, >> >> I have a continuous spectral plot that I need to filter. The spectrum is >> unique in that at a glance it looks like white noise, however if you look >> closer there are bins (frequencies) that have constant amplitudes. The >> problem is if I simply average the continuous spectrum, the noise >> averages to the same amplitudes as the constants. What would be the best >> algorithm to extract these constant amplitudes/frequencies? Would video >> averaging work or does it just average the noise and I wouldn't see the >> constants? > > Obvious answer: average the complex spectrum, not the power spectrum. > If you only have the power spectrum, then compute the mean and the > deviation for every bin; estimate S/N in the bin from there. > > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultant > http://www.abvolt.com > >Hi Vladimir, Thanks for the response, I don't have the complex spectrum, but it looks like I ended up doing something very similar to what you suggested. I ran the bins through a low pass filter and then determined the absolute difference between the filtered data and each raw point. The constant amplitude bins now stand out like sore thumbs. Thomas
Reply by ●April 30, 20092009-04-30
On Wed, 29 Apr 2009 16:27:34 -0700, "Thomas Magma" <somewhere@overtherainbow.com> wrote:>"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote in message >news:_fYJl.15429$hc1.2488@flpi150.ffdc.sbc.com... >> >> >> Thomas Magma wrote: >> >>> Hello, >>> >>> I have a continuous spectral plot that I need to filter. The spectrum is >>> unique in that at a glance it looks like white noise, however if you look >>> closer there are bins (frequencies) that have constant amplitudes. The >>> problem is if I simply average the continuous spectrum, the noise >>> averages to the same amplitudes as the constants. What would be the best >>> algorithm to extract these constant amplitudes/frequencies? Would video >>> averaging work or does it just average the noise and I wouldn't see the >>> constants? >> >> Obvious answer: average the complex spectrum, not the power spectrum. >> If you only have the power spectrum, then compute the mean and the >> deviation for every bin; estimate S/N in the bin from there. >> >> >> Vladimir Vassilevsky >> DSP and Mixed Signal Design Consultant >> http://www.abvolt.com >> >> >Hi Vladimir, > >Thanks for the response, I don't have the complex spectrum, but it looks >like I ended up doing something very similar to what you suggested. I ran >the bins through a low pass filter and then determined the absolute >difference between the filtered data and each raw point. The constant >amplitude bins now stand out like sore thumbs.I was thinking run each bing through a highpass filter and an envelope (absolute value and running average) function, so the constant bins will have zero output. But what you did is essentially the same. This is an intriguing signal. Is it some sort of steganography technique?> >Thomas >
>>> Thomas Magma wrote: >>> >>>> Hello, >>>> >>>> I have a continuous spectral plot that I need to filter. The spectrum >>>> is >>>> unique in that at a glance it looks like white noise, however if you >>>> look >>>> closer there are bins (frequencies) that have constant amplitudes. The >>>> problem is if I simply average the continuous spectrum, the noise >>>> averages to the same amplitudes as the constants. What would be the >>>> best >>>> algorithm to extract these constant amplitudes/frequencies? Would video >>>> averaging work or does it just average the noise and I wouldn't see the >>>> constants? >>> >>> Obvious answer: average the complex spectrum, not the power spectrum. >>> If you only have the power spectrum, then compute the mean and the >>> deviation for every bin; estimate S/N in the bin from there. >>> >>> >>> Vladimir Vassilevsky >>> DSP and Mixed Signal Design Consultant >>> http://www.abvolt.com >>> >>> >>Hi Vladimir, >> >>Thanks for the response, I don't have the complex spectrum, but it looks >>like I ended up doing something very similar to what you suggested. I ran >>the bins through a low pass filter and then determined the absolute >>difference between the filtered data and each raw point. The constant >>amplitude bins now stand out like sore thumbs. > > I was thinking run each bing through a highpass filter and an > envelope (absolute value and running average) function, so the > constant bins will have zero output. But what you did is essentially > the same. > > This is an intriguing signal. Is it some sort of steganography > technique? >I had to look up definition of steganography...so no I'm not doing that. It's part of a search algorithm used to position locate based on the Doppler shift. Thomas
