Compression artifacts in compressed audio typically show up as ringing, pre-echo, drop-outs, warbling, metallic ringing, an underwater feeling, hissing, or "graininess". How and when the artifacts above occured? Where can i get the appropriate speech samples to taste the effect? More,anyone can explain how the artifacts come into being in detail? Any coments would be appreciated. Regards HyeeWang@gmail.com
Started by ●May 4, 2009
Reply by ●May 4, 20092009-05-04
"HyeeWang" <hyeewang@gmail.com> wrote in message news:617c12a9-6ff2-405a-abea-528daa16b1fb@v23g2000pro.googlegroups.com...> Compression artifacts in compressed audio typically show up as > ringing, pre-echo, drop-outs, warbling, > metallic ringing, an underwater feeling, hissing, or "graininess". > > How and when the artifacts above occured? Where can i get the > appropriate speech samples to taste the effect? > More,anyone can explain how the artifacts come into being in detail? > > Any coments would be appreciated. > > Regards > HyeeWang@gmail.com
On May 4, 6:16�pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> wrote:> "HyeeWang" <hyeew...@gmail.com> wrote in message > > news:617c12a9-6ff2-405a-abea-528daa16b1fb@v23g2000pro.googlegroups.com... > > > > > Compression artifacts in compressed audio typically show up as > > ringing, pre-echo, drop-outs, warbling, > > metallic ringing, an underwater feeling, hissing, or "graininess". > > > How and when the artifacts above occured? Where can i get the > > appropriate speech samples to taste the effect? > > More,anyone can explain how the artifacts come into being in detail? > > > Any coments would be appreciated. > > > Regards > > HyeeW...@gmail.com- Hide quoted text - > > - Show quoted text -
You are just adding fuel to the fire. Please don't respond to trolls. Rick On May 4, 9:03�am, HyeeWang <hyeew...@gmail.com> wrote:> On May 4, 6:16�pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> > wrote: > > > "HyeeWang" <hyeew...@gmail.com> wrote in message > > >news:617c12a9-6ff2-405a-abea-528daa16b1fb@v23g2000pro.googlegroups.com... > > > > Compression artifacts in compressed audio typically show up as > > > ringing, pre-echo, drop-outs, warbling, > > > metallic ringing, an underwater feeling, hissing, or "graininess". > > > > How and when the artifacts above occured? Where can i get the > > > appropriate speech samples to taste the effect? > > > More,anyone can explain how the artifacts come into being in detail? > > > > Any coments would be appreciated. > > > > Regards > > > HyeeW...@gmail.com- Hide quoted text - > > > - Show quoted text - > >
rickman wrote:> You are just adding fuel to the fire. Please don't respond to trolls. > > Rick > > > On May 4, 9:03 am, HyeeWang <hyeew...@gmail.com> wrote: >> On May 4, 6:16 pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> >> wrote: >> >>> "HyeeWang" <hyeew...@gmail.com> wrote in message >>> news:617c12a9-6ff2-405a-abea-528daa16b1fb@v23g2000pro.googlegroups.com... >>>> Compression artifacts in compressed audio typically show up as >>>> ringing, pre-echo, drop-outs, warbling, >>>> metallic ringing, an underwater feeling, hissing, or "graininess". >>>> How and when the artifacts above occured? Where can i get the >>>> appropriate speech samples to taste the effect? >>>> More,anyone can explain how the artifacts come into being in detail? >>>> Any coments would be appreciated. >>>> Regards >>>> HyeeW...@gmail.com- Hide quoted text - >>> - Show quoted text - >> >I second that -- long experience on USENET teaches that the only way to deal with bad behavior is to _maybe_ say something to someone once, then if they don't get the message then _ignore_ them, no matter how hard it may be. Otherwise you just get sucked into becoming part of the problem, instead of part of the solution. If you like USENET well enough to put up with the weirdos, consider getting a real newsreader that lets you filter by the originator's name (I use Pan and Thunderbird). Then just filter out any content from them, and let them gnash their teeth and foam at the mouth all they want, alone. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●May 5, 20092009-05-05
On May 5, 1:19�am, Tim Wescott <t...@seemywebsite.com> wrote:> rickman wrote: > > You are just adding fuel to the fire. �Please don't respond to trolls. > > > Rick > > > On May 4, 9:03 am, HyeeWang <hyeew...@gmail.com> wrote: > >> On May 4, 6:16 pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> > >> wrote: > > >>> "HyeeWang" <hyeew...@gmail.com> wrote in message > >>>news:617c12a9-6ff2-405a-abea-528daa16b1fb@v23g2000pro.googlegroups.com... > >>>> Compression artifacts in compressed audio typically show up as > >>>> ringing, pre-echo, drop-outs, warbling, > >>>> metallic ringing, an underwater feeling, hissing, or "graininess". > >>>> How and when the artifacts above occured? Where can i get the > >>>> appropriate speech samples to taste the effect? > >>>> More,anyone can explain how the artifacts come into being in detail? > >>>> Any coments would be appreciated. > >>>> Regards > >>>> HyeeW...@gmail.com- Hide quoted text - > >>> - Show quoted text - > > I second that -- long experience on USENET teaches that the only way to > deal with bad behavior is to _maybe_ say something to someone once, then > if they don't get the message then _ignore_ them, no matter how hard it > may be. > > Otherwise you just get sucked into becoming part of the problem, instead > of part of the solution. > > If you like USENET well enough to put up with the weirdos, consider > getting a real newsreader that lets you filter by the originator's name > (I use Pan and Thunderbird). �Then just filter out any content from > them, and let them gnash their teeth and foam at the mouth all they > want, alone. > > -- > > Tim Wescott > Wescott Design Serviceshttp://www.wescottdesign.com > > Do you need to implement control loops in software? > "Applied Control Theory for Embedded Systems" was written for you. > See details athttp://www.wescottdesign.com/actfes/actfes.html- Hide quoted text - > > - Show quoted text -Giving my apologise to whoever for my rude offence humbly. HyeeWang
