Respected sir, with ur valuable information i have implemented a viterbi decoder with k=7,1/2 decoder with puncturing capability satidfactorily.... . i have also implemented a puncturing unit which punctures the 1/2 code to rate 2/3 and 3/4 rate... using fifo ram and state machine.. and it is working... but i have a problem with the output data rate of the clock in 2/3 that is .If iam giving the encoded output at 1 Mhz to the 2/3 punctuer unit that is 2 bits for each clock cycle i have to output 3 bits for every two clock cyclesss... that if input to puncture unit is 1 mhz output data should go serially at 1.5 mhz that is 3/2 of master clock frequency from the puncture unit.. and the same case with the depuncture unit it should sample the data serially at 3/2 of the master clock frequency and given to decoder. and the same case with 3/4 puncturing if input i need clock with 3/4 frequency of the master clock ; so how can we achieve this clock in the punturing unit and depuncturing unit.. as the clock will be changing for the rate 1/2 , 2/3 and 3/4 puntureing.. optionsss. smilarly for 3/4 for an input clock of 3 mhz outpu clock or data transmission shuld happen at 4 mhz or 4/3 of the master clock frequency. how can we change that clock.. so please kindly throw some light on this....
puncturing clock in viterbi
Started by ●March 16, 2004
Reply by ●March 16, 20042004-03-16
