digital signal processing of stock prices
Started by Beliavsky ●May 6, 2009
The May 2009 issue of Futures (as in financial derivatives) magazine
has a an interview with money manager Rafael Molinero, who has used
DSP algorithms to trade successfully. Based on what he says, I wonder
if someone can name the algorithms he may be using and provide
references to relevant books and/or papers.
Quoting the article:
He quickly became intrigued by DSP. [...]
Markets also move in waves similar to, but not identical to, the waves
of sound, leading Molinero to ask, "If markets have a non-random
component, can we extract the random one and keep the non-random one?"
This mean transforming existing algorithms, for a variety of reasons:
first, markets aren't sound waves, and second, DSP is designed to
rebuild something that previously existed (sound), while traders are
trying to project a bit into the future.
"We decompose the price into linear (trending) and non-linear
(cyclical) components, and then the algorithms identify which are
signals," Molinear explains., adding that what's left after filtering
the noise is probably the market's real pulse. Models also generate a
probability of success on each trade. "For example, if you can explain
a signal with very few components, it's probably a strong signal,
which we can use to project the next directional move."
This, he says, enables them to avoid getting whipsawed in choppy
markets and also to get into trending markets earlier.
"The models adapt in frequency based on the speed at which the market
is going," he explains. "By decomposing the market, we can look at the
underlying components. If these components change directions
frequently, our models will trade short-term, if not our models will
trade medium-term."
On May 6, 3:30&#4294967295;pm, Beliavsky <beliav...@aol.com> wrote:
> The May 2009 issue of Futures (as in financial derivatives) magazine > has a an interview with money manager Rafael Molinero, who has used > DSP algorithms to trade successfully. Based on what he says, I wonder > if someone can name the algorithms he may be using and provide > references to relevant books and/or papers. > > Quoting the article: > > He quickly became intrigued by DSP. [...] > > Markets also move in waves similar to, but not identical to, the waves > of sound, leading Molinero to ask, "If markets have a non-random > component, can we extract the random one and keep the non-random one?" > > This mean transforming existing algorithms, for a variety of reasons: > first, markets aren't sound waves, and second, DSP is designed to > rebuild something that previously existed (sound), while traders are > trying to project a bit into the future. > > [...] > > "We decompose the price into linear (trending) and non-linear > (cyclical) components, and then the algorithms identify which are > signals," Molinear explains., adding that what's left after filtering > the noise is probably the market's real pulse. Models also generate a > probability of success on each trade. "For example, if you can explain > a signal with very few components, it's probably a strong signal, > which we can use to project the next directional move." > > This, he says, enables them to avoid getting whipsawed in choppy > markets and also to get into trending markets earlier. > > "The models adapt in frequency based on the speed at which the market > is going," he explains. "By decomposing the market, we can look at the > underlying components. If these components change directions > frequently, our models will trade short-term, if not our models will > trade medium-term."
You have to be careful about which model you use for the Market. A couple of Nobel Laureates were on the board in a company called Long Term Capital Management. They devised some really neat analyses and allowed them to reap 40% annual returns and this worked great until the collapse of the Russian market. Their theory was good except it didn't account for the herd effect in a bear market. They lost their asses in 1998! And other stock firms ended up bailing them out. We had a guy here who posted alot about fancy methods of analysis, but the market crash in the early 2000s silenced him as well. Often one finds a model that fits the market over a short period of time, but noone seems to be able to fit the market over long periods of time. It is hardly a stationary process. Clay
On May 6, 3:52&#4294967295;pm, c...@claysturner.com wrote:
> Often one finds a model that fits the market over a short period of > time, but noone seems to be able to fit the market over long periods > of time. It is hardly a stationary process.
True, but the person being profiled uses methods that deal with the nonstationarity, as described in the last three paragraphs of the excerpt.
I have noted that a couple of books on Kalman filters have used econometrics as the application for the theory. This book is quite good on the Kalman filter part: http://www.amazon.com/Analysis-Methods-Oxford-Statistical-Science/dp/0198523548/ref=sr_1_1?ie=UTF8&s=books&qid=1241640404&sr=8-1 Don't know how well eceonomy part works, though. I have noted that the examples are based on reviewing historic data to see effects of manipulations, like what effect the requirement to wear seat belts in cars had on fatality rates in road accidents. The example in the book showed data from a couple of years before and after the legislation. I can't remember having seen examples of predictions. But then, analyzing data after the fact is trivial compared to predicting future behaviour. Rune
On Wed, 6 May 2009 12:52:33 -0700 (PDT), clay@claysturner.com wrote:
>You have to be careful about which model you use for the Market. A >couple of Nobel Laureates were on the board in a company called Long >Term Capital Management. They devised some really neat analyses and >allowed them to reap 40% annual returns and this worked great until >the collapse of the Russian market. Their theory was good except it >didn't account for the herd effect in a bear market. They lost their >asses in 1998! And other stock firms ended up bailing them out. > >We had a guy here who posted alot about fancy methods of analysis, but >the market crash in the early 2000s silenced him as well. > >Often one finds a model that fits the market over a short period of >time, but noone seems to be able to fit the market over long periods >of time. It is hardly a stationary process.
http://en.wikipedia.org/wiki/Renaissance_Technologies -- Torbj&#4294967295;rn Svensson Diaz
On May 6, 4:42&#4294967295;pm, Torbj&#4294967295;rn Svensson Diaz <tobit...@gmail.com> wrote:
> On Wed, 6 May 2009 12:52:33 -0700 (PDT), c...@claysturner.com wrote: > >You have to be careful about which model you use for the Market. A > >couple of Nobel Laureates were on the board in a company called Long > >Term Capital Management. They devised some really neat analyses and > >allowed them to reap 40% annual returns and this worked great until > >the collapse of the Russian market. Their theory was good except it > >didn't account for the herd effect in a bear market. They lost their > >asses in 1998! And other stock firms ended up bailing them out. > > >We had a guy here who posted alot about fancy methods of analysis, but > >the market crash in the early 2000s silenced him as well. > > >Often one finds a model that fits the market over a short period of > >time, but noone seems to be able to fit the market over long periods > >of time. It is hardly a stationary process. > > http://en.wikipedia.org/wiki/Renaissance_Technologies > > -- > Torbj&#4294967295;rn Svensson Diaz
Thanks for the link. RenTech's Medallion Fund is only open to former and current Renaissance employees. Their other funds are down. Madoff's fund looked good too until!! I'm not saying the RenTech is a Ponzi scheme, but it needs to be properly scrutinized and they keep quite a bit of stuff quiet. They even petitioned the SEC about not revealing their short positions. It will be interesting to see how they fare with the current economic situation. Clay
Beliavsky wrote:
> On May 6, 3:52 pm, c...@claysturner.com wrote: > >> Often one finds a model that fits the market over a short period of >> time, but noone seems to be able to fit the market over long periods >> of time. It is hardly a stationary process. > > True, but the person being profiled uses methods that deal with the > nonstationarity, as described in the last three paragraphs of the > excerpt.
It will be a long time before technology is able to predict as much as a month into the future of the stock market. Wishful thinking often buoys what amounts to get-rich-quick schemes. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Jerry Avins wrote:
> Beliavsky wrote: >> On May 6, 3:52 pm, c...@claysturner.com wrote: >> >>> Often one finds a model that fits the market over a short period of >>> time, but noone seems to be able to fit the market over long periods >>> of time. It is hardly a stationary process. >> >> True, but the person being profiled uses methods that deal with the >> nonstationarity, as described in the last three paragraphs of the >> excerpt. > > It will be a long time before technology is able to predict as much as a > month into the future of the stock market.
This may *never* occur. I don't think the stock market is anything like analytic. Even applying heuristics requires the applier to make assumptions. Look at the CDS market failure - an assumption in the model everybody used led to the downfall. There's no reason to think that the set of such assumptions is even countable, much less manageable. Once you conquer one, it's hard to think that a reasonable person can be confident that was the *last* one.
> Wishful thinking often buoys > what amounts to get-rich-quick schemes. > > Jerry
-- Les Cargill
On Wed, 6 May 2009 12:30:26 -0700 (PDT), Beliavsky <beliavsky@aol.com> wrote:
I read this twice, and I'm still puzzled by the reference to "DSP". The last time I read an article about someone's attempt to model the ups and downs of the stock market, it was based on "time-series analysis". True, a lot of DSP algorithms _are_ functions of time, but by using the term "DSP" is Mr. Molinero saying anything more than that?
It's a nice buzzword, and its use makes him newsworthy.
"If my signal has noise, can I extract the signal?"
> This mean transforming existing algorithms, for a variety of reasons: > first, markets aren't sound waves, ...
(although I hear of frequent yelling and screaming among the individual traders <grin!>)
> ... and second, DSP is designed to > rebuild something that previously existed (sound), while traders are > trying to project a bit into the future.
I'm not a DSP expert -- I don't even play one on TV -- but something about this description of DSP seems... limited. I freely admit that I haven't read the article, and Mr. Molinero may, indeed, have found a way of modelling the rise and fall of stock prices. Based on the article, though, I'm a little cautious about the quality of his tailoring. Am I just missing something? Frank McKenney -- Inborn desires are a nuisance to those with utopian and totalitarian visions, which often amount to the same thing. What stands in the way of most utopias is not pestilence and drought but human behavior. -- Steven Pinker, "The Blank Slate" -- Frank McKenney, McKenney Associates Richmond, Virginia / (804) 320-4887 Munged E-mail: frank uscore mckenney ayut mined spring dawt cahm (y'all)
On 6 Mai, 22:42, Torbj&#4294967295;rn Svensson Diaz <tobit...@gmail.com> wrote:
http://en.wikipedia.org/wiki/Madoff
