Hi: Does a device that switches frequency [in number of Hz] with peak-to- peak amplitude [in number of in electron(s)-per-second-per-square- meter] � and visa versa -- exist? If not, is it possible to construct one? In this device, the input of a signal that has a frequency of X Hz and a peak-to-peak amplitude of Y electron[s]-per-second-per-square-meter will result in the output of a signal that has a frequency of Y Hz and a peak-to-peak amplitude of X electron[s]-per-second-per-square-meter. Thanks
Can this be accomplished?
Started by ●May 10, 2009
Reply by ●May 10, 20092009-05-10
On May 9, 10:14 pm, Archimedes' Lever <OneBigLe...@InfiniteSeries.Org> wrote in http://groups.google.com/group/sci.physics/msg/0e0c01ece9b726d6?hl=en :> On Sat, 9 May 2009 21:57:48 -0700 (PDT), GreenXenon > > <glucege...@gmail.com> wrote:> >Hi: > > >Does a device that switches frequency [in number of Hz] with peak-to- > >peak amplitude [in number of in electron(s)-per-second-per-square- > >meter] � and visa versa -- exist? If not, is it possible to construct > >one? > > >In this device, the input of a signal that has a frequency of X Hz and > >a peak-to-peak amplitude of Y electron[s]-per-second-per-square-meter > >will result in the output of a signal that has a frequency of Y Hz and > >a peak-to-peak amplitude of X electron[s]-per-second-per-square-meter. > > >Thanks >> Come back when you finally get the right terms down.Where are the terms wrong?
"GreenXenon" <glucegen1x@gmail.com> wrote in message news:43e821fe-784d-4ed3-8e86-bb1afcdec36f@r31g2000prh.googlegroups.com... Hi:>Does a device that switches frequency [in number of Hz] with peak-to- >peak amplitude [in number of in electron(s)-per-second-per-square- >meter] � and visa versa -- exist? If not, is it possible to construct >one? > >In this device, the input of a signal that has a frequency of X Hz and >a peak-to-peak amplitude of Y electron[s]-per-second-per-square-meter >will result in the output of a signal that has a frequency of Y Hz and >a peak-to-peak amplitude of X electron[s]-per-second-per-square-meter.Not enough info. You will have to explain what the output media is ? Coper wire? Air? Water? Constant area or variable? What frequency range? Audio? Radar?
Cwatters wrote:> > Not enough info. You will have to explain what the output media is ? Coper > wire? Air? Water? Constant area or variable? What frequency range? Audio? > Radar? > >It's obviously a raygun.
"GreenXenon" <glucegen1x@gmail.com> wrote in messagenews:6acd9b7e-679c-4bba-91db-47f728baadbb@v35g2000pro.googlegroups.com...> On May 9, 10:40 pm, Mark Harriss <bi...@blartco.co.uk> wrote: > > > Yep > > "Yep" to what?You being a completely moronic troll. MrT.
As to your question, I should think the problem would be how to measure electrons. I searched google.com for the words... measuring electrons And came up with some interesting things. Might want to try that. As to the negative replies, I suggest you try asking your question on individual groups instead of posting to 5 groups with the same post. Then you can see which groups offer constructive suggestions and which do not. Then ask your future questions on the more positive groups. Also you can search for the word forum along with a general topic word like electronics and find some interesting discussion groups. "GreenXenon" wrote in message Hi: Does a device that switches frequency [in number of Hz] with peak-to- peak amplitude [in number of in electron(s)-per-second-per-square- meter] � and visa versa -- exist? If not, is it possible to construct one? In this device, the input of a signal that has a frequency of X Hz and a peak-to-peak amplitude of Y electron[s]-per-second-per-square-meter will result in the output of a signal that has a frequency of Y Hz and a peak-to-peak amplitude of X electron[s]-per-second-per-square-meter. Thanks
On May 10, 9:06 am, Stuart <Spam...@argonet.co.uk> wrote in http://groups.google.com/group/alt.engineering.electrical/msg/977409bf5d65aa1e?hl=en :> In article > <43e821fe-784d-4ed3-8e86-bb1afcdec...@r31g2000prh.googlegroups.com>, > GreenXenon <glucege...@gmail.com> wrote:> > > Hi: > > Does a device that switches frequency [in number of Hz] with peak-to- > > peak amplitude [in number of in electron(s)-per-second-per-square- > > meter] " and visa versa -- exist? If not, is it possible to construct > > one? > > In this device, the input of a signal that has a frequency of X Hz and > > a peak-to-peak amplitude of Y electron[s]-per-second-per-square-meter > > will result in the output of a signal that has a frequency of Y Hz and > > a peak-to-peak amplitude of X electron[s]-per-second-per-square-meter.> > Most things can be accomplished if we knew what the hell you were talking > about. Frequency changing can be done, yes, but what the rest of your post > is about is anybody's guess.In an electronic signal, amplitude measure the amount of electron[s]- per-second-per-square-meter. More electron[s]-per-second-per-square- meter means more amplitude.
