Hi all, I am working on the coexistence study between BT and WLAN. Anyone knows where are the spec on modulation and pulse shaping for BT and 802.11 a, b, g WLAN? cfy30
bt and wlan modulation and pulse shaping?
Started by ●May 16, 2009
Reply by ●May 16, 20092009-05-16
On May 16, 10:49�am, "cfy30" <cf...@yahoo.com> wrote:> Hi all, > > I am working on the coexistence study between BT and WLAN. Anyone knows > where are the spec on modulation and pulse shaping for BT and 802.11 a, b, > g WLAN? > > cfy30I don't know what BT is but for 802.11 standards, you can either read about it on good ole wikipedia or read the actual standards. If you don't know yet, they are available for free. http://en.wikipedia.org/wiki/802.11 http://ieee802.org/11/
On Sat, 16 May 2009 08:03:27 -0700 (PDT), julius <juliusk@gmail.com> wrote:>On May 16, 10:49�am, "cfy30" <cf...@yahoo.com> wrote: >> Hi all, >> >> I am working on the coexistence study between BT and WLAN. Anyone knows >> where are the spec on modulation and pulse shaping for BT and 802.11 a, b, >> g WLAN? >> >> cfy30 > >I don't know what BT is but for 802.11 standards, you can either read >about >it on good ole wikipedia or read the actual standards. If you don't >know yet, >they are available for free. > >http://en.wikipedia.org/wiki/802.11 >http://ieee802.org/11/Or here: http://standards.ieee.org/getieee802/portfolio.html BT is 802.15. The waveforms aren't even close to compatible, so the general means of sensing each other for avoidance is just energy detection. Since the ISM band is unlicensed energy detection is more general, anyway, since an interferer may be a cordless phone or any other device compliant to the ISM rules. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Thanks julius and Eric. Let me explain a bit more, what I am looking for are the specs on the modulator and pulse shaping filter for the two standards. Are there specs describing the modulation and pulse shaping requirement? Like in WCDMA, 3GPP TS 25.101 describe the pulse shaping filter and 3GPP TS 25.213 describe the modulator? If anyone can point me directly to the specs, it is greatly appreciated. cfy30>On Sat, 16 May 2009 08:03:27 -0700 (PDT), julius <juliusk@gmail.com> >wrote: > >>On May 16, 10:49�am, "cfy30" <cf...@yahoo.com> wrote: >>> Hi all, >>> >>> I am working on the coexistence study between BT and WLAN. Anyoneknows>>> where are the spec on modulation and pulse shaping for BT and 802.11a, b,>>> g WLAN? >>> >>> cfy30 >> >>I don't know what BT is but for 802.11 standards, you can either read >>about >>it on good ole wikipedia or read the actual standards. If you don't >>know yet, >>they are available for free. >> >>http://en.wikipedia.org/wiki/802.11 >>http://ieee802.org/11/ > >Or here: > >http://standards.ieee.org/getieee802/portfolio.html > >BT is 802.15. > >The waveforms aren't even close to compatible, so the general means of >sensing each other for avoidance is just energy detection. Since the >ISM band is unlicensed energy detection is more general, anyway, since >an interferer may be a cordless phone or any other device compliant to >the ISM rules. > >Eric Jacobsen >Minister of Algorithms >Abineau Communications >http://www.ericjacobsen.org > >Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php >
The links Julius and I provided will take you to the standard documents that describe the air interface. On Sat, 16 May 2009 13:09:16 -0500, "cfy30" <cfy30@yahoo.com> wrote:>Thanks julius and Eric. > >Let me explain a bit more, what I am looking for are the specs on the >modulator and pulse shaping filter for the two standards. Are there specs >describing the modulation and pulse shaping requirement? Like in WCDMA, >3GPP TS 25.101 describe the pulse shaping filter and 3GPP TS 25.213 >describe the modulator? If anyone can point me directly to the specs, it is >greatly appreciated. > > >cfy30 > > >>On Sat, 16 May 2009 08:03:27 -0700 (PDT), julius <juliusk@gmail.com> >>wrote: >> >>>On May 16, 10:49�am, "cfy30" <cf...@yahoo.com> wrote: >>>> Hi all, >>>> >>>> I am working on the coexistence study between BT and WLAN. Anyone >knows >>>> where are the spec on modulation and pulse shaping for BT and 802.11 >a, b, >>>> g WLAN? >>>> >>>> cfy30 >>> >>>I don't know what BT is but for 802.11 standards, you can either read >>>about >>>it on good ole wikipedia or read the actual standards. If you don't >>>know yet, >>>they are available for free. >>> >>>http://en.wikipedia.org/wiki/802.11 >>>http://ieee802.org/11/ >> >>Or here: >> >>http://standards.ieee.org/getieee802/portfolio.html >> >>BT is 802.15. >> >>The waveforms aren't even close to compatible, so the general means of >>sensing each other for avoidance is just energy detection. Since the >>ISM band is unlicensed energy detection is more general, anyway, since >>an interferer may be a cordless phone or any other device compliant to >>the ISM rules. >> >>Eric Jacobsen >>Minister of Algorithms >>Abineau Communications >>http://www.ericjacobsen.org >> >>Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php >>Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
