On May 17, 3:38�pm, Richard Owlett <rowl...@atlascomm.net> wrote:> _TYPICALLY_ when looking to satisfy "Nyquist criterion" one looks to > sample a waveform at >= a particular frequency.actually strictly >. the particular frequency is twice the highest frequency ever expected in the content of the continuous-time signal.> I've gut feeling that Nyquist implies more.you mean the theorem with his name in it (that everyone says is better attributed to Whittaker, Shannon, Kotelnikov, and/or Raabe)> I suspect it's more about information transfer rate.information transfer rate needs to know information about S/N which the basic Sampling Theorem doesn't concern itself with. the capacity rate of transfer of information through a channel is B C = integral{ log2( (S+N)/N ) df } 0 where S = S(f) = signal power spectrum N = N(f) = noise power spectrum B = upper Bandwidth (no S(f) for f>B) C = channel capacity in bits per unit time (if base-2 log is used)> What question should I be asking.i dunno. i dunno what it is you want. r b-j
Implications of Nyquist? ?????
Started by ●May 17, 2009
Reply by ●May 18, 20092009-05-18
On Sun, 17 May 2009 22:55:48 -0400, Jerry Avins wrote:> Tim Wescott wrote: > > ... > >> If I am not mistaken an absolutely band limited signal _is_ of limited >> duration, which is one of the salient features that makes it impossible >> to be real world. > > Erm .. unlimited duration?Yes, quite. _Un_ limited duration, or infinite duration, or just about any duration that goes on forever and ever and ever. I was out in the hot sun all day today, burning about three yards of brush. I think I fried some brain cells. (This doesn't explain the times I mistype things when I'm supposedly doing _well_). -- www.wescottdesign.com
On Sun, 17 May 2009 20:01:05 -0700, dvsarwate@yahoo.com wrote:> On May 17, 9:22 pm, Tim Wescott <t...@seemywebsite.com> wrote: >> On Sun, 17 May 2009 23:02:45 +0000, glen herrmannsfeldt wrote: >> > Tim Wescott <t...@seemywebsite.com> wrote: >> >> >> If I am not mistaken an absolutely band limited signal _is_ of limited >> duration, which is one of the salient features that makes it impossible >> to be real world. > > That is, the signal is limited in **both** frequency and time? I don't > believe that this is correct. A signal that is absolutely limited in > one domain extends to plus/minus infinity in the other domain. A > strictly band-limited signal is of infinite duration, and a strictly > time-limited > signal has Fourier transform that is nonzero for arbitrarily large > values > of frequency.You are correct; I mistyped. I had the image of a signal of infinite extent in time when I typed "limited duration". The "un" fell off and is probably hiding under my desk ready to bite my ankle when I'm not watching. -- www.wescottdesign.com
robert bristow-johnson <rbj@audioimagination.com> wrote:> On May 17, 3:38?pm, Richard Owlett <rowl...@atlascomm.net> wrote: >> _TYPICALLY_ when looking to satisfy "Nyquist criterion" one looks to >> sample a waveform at >= a particular frequency.> actually strictly >. the particular frequency is twice the highest > frequency ever expected in the content of the continuous-time signal.Well, since we already decided that it only applies to infinite durations signals, and we very rarely have one of those, it will be rare that we have a chance to tell the difference between > and >= in actual measurement. In addition, if you have a tolerance on the frequency source that is likely to cover the difference.>> I've gut feeling that Nyquist implies more.I used to have a copy of the original Nyquist paper. You can probably find it in a nearby university library.> you mean the theorem with his name in it (that everyone says is better > attributed to Whittaker, Shannon, Kotelnikov, and/or Raabe)>> I suspect it's more about information transfer rate.Yes.> information transfer rate needs to know information about S/N which > the basic Sampling Theorem doesn't concern itself with. the capacity > rate of transfer of information through a channel is>> What question should I be asking.Read the paper. It is interesting to read, especially seeing what has changed over the years and what has not changed. -- glen
Reply by ●May 28, 20092009-05-28
Richard Owlett dug myself into semantic traps saying:> _TYPICALLY_ when looking to satisfy "Nyquist criterion" one looks to > sample a waveform at >= a particular frequency.^^^^^^^^^!!!!!!!!> > I've gut feeling that Nyquist implies more.^^^^^^^> > I suspect it's more about information transfer rate.^^^^^^^^^^^> > What question should I be asking. >Julius referred me to an article on "rate of innovation". That seemed a good candidate for a search term ---- until I read its first paragraph. I then Googled for ( Whittaker Shannon Kotelnikov Raabe et al.) The Wikipedia article "Nyquist�Shannon sampling theorem" spotlighted some semantic problems. Just saying "Nyquist criterion" implies a *WRONG* 'universe of discourse' in subtle ways due to vagaries of English semantics (formal vs informal vs jargon {technical or other}). Limiting it to signals (by implication) expressible by a time varying voltage between a pair of conductors *AND* examining how they may be decomposed and _RECONSTRUCTED_. That "RECONSTRUCTED" is the key. My question arises out of an interest in a subset of speech recognition - phoneme recognition (could be thought of as a portion of finite vocabulary discrete speech). I won't pose my question in those terms as I'd likely misuse some technical terms - I know more than I grok. (Thank you Mr. Heinlein) I'll try to pose my question in terms of "text to speech" instead. The input will be 1 page of printed text (cf time limited). It will be straight declarative sentences (no ! or ?) (cf band limited). Following the example using "Lena" and "Mona Lisa" as image compression test cases, I'll specify printed copies of Lincoln's "Gettysburg Address" as the input. The test of "fidelity" would be an ideal court stenographer transcribing using IPA and reading back the text, which would be independent of input being 10 point Courier Regular or 15 point Garmond Bold Italic etc. Something is remaining the same. In my original post, when I used the term "information" I was referring to "information" gained by listening to the stenographer reading back the text. What key word(s) should I investigate? Thank you.
Richard Owlett wrote:> Richard Owlett dug myself into semantic traps saying:ARGGH - the problems of line wrapping when adding emphasis to quoted text. I'll edit with explicit CR-LF and hope it comes thru better.> >> _TYPICALLY_ when looking to satisfy "Nyquist criterion" one looks >> to sample a waveform at >= a particular frequency. > ^^^^^^^^^!!!!!!!! >> >> I've gut feeling that Nyquist implies more. > ^^^^^^^ >> >> I suspect it's more about information transfer rate. > ^^^^^^^^^^^ >> >> What question should I be asking. >> > > Julius referred me to an article on "rate of innovation". That seemed a > good candidate for a search term ---- until I read its first paragraph. > > I then Googled for ( Whittaker Shannon Kotelnikov Raabe et al.) > The Wikipedia article "Nyquist�Shannon sampling theorem" spotlighted > some semantic problems. > > Just saying "Nyquist criterion" implies a *WRONG* 'universe of > discourse' in subtle ways due to vagaries of English semantics (formal > vs informal vs jargon {technical or other}). Limiting it to signals (by > implication) expressible by a time varying voltage between a pair of > conductors *AND* examining how they may be decomposed and _RECONSTRUCTED_. > > That "RECONSTRUCTED" is the key. > > My question arises out of an interest in a subset of speech recognition > - phoneme recognition (could be thought of as a portion of finite > vocabulary discrete speech). I won't pose my question in those terms as > I'd likely misuse some technical terms - I know more than I grok. (Thank > you Mr. Heinlein) > > I'll try to pose my question in terms of "text to speech" instead. > The input will be 1 page of printed text (cf time limited). > It will be straight declarative sentences (no ! or ?) (cf band limited). > Following the example using "Lena" and "Mona Lisa" as image compression > test cases, I'll specify printed copies of Lincoln's "Gettysburg > Address" as the input. > > The test of "fidelity" would be an ideal court stenographer transcribing > using IPA and reading back the text, which would be independent of input > being 10 point Courier Regular or 15 point Garmond Bold Italic etc. > > Something is remaining the same. In my original post, when I used the > term "information" I was referring to "information" gained by listening > to the stenographer reading back the text. > > What key word(s) should I investigate? > > Thank you. > > > > > > >
Reply by ●May 29, 20092009-05-29
On May 17, 3:38�pm, Richard Owlett <rowl...@atlascomm.net> wrote:> _TYPICALLY_ when looking to satisfy "Nyquist criterion" one looks to > sample a waveform at >= a particular frequency. > > I've gut feeling that Nyquist implies more. > > I suspect it's more about information transfer rate. > > What question should I be asking. > > Signed > ADMITTED *STUPIDENT*Hello Richard, The following paper is most excellent, and I believe will more than answer your questions. http://www.imagescience.org/meijering/publications/download/pieee2002.pdf Clay Turner
clay@claysturner.com wrote: (snip)> The following paper is most excellent, and I believe will more than > answer your questions.> http://www.imagescience.org/meijering/publications/download/pieee2002.pdfI would also recommend reading Nyquist's paper, though I don't know that it is available on the web. It should be easy to find in a big university library, or maybe even a small one. -- glen
On May 29, 3:09�pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> c...@claysturner.com wrote: > > (snip) > > > The following paper is most excellent, and I believe will more than > > answer your questions. > >http://www.imagescience.org/meijering/publications/download/pieee2002... > > I would also recommend reading Nyquist's paper, though I don't > know that it is available on the web. �It should be easy to > find in a big university library, or maybe even a small one. > > -- glenI agree, I just thought I'd point Richard to something on the web. Clay
On May 29, 3:40�pm, c...@claysturner.com wrote:> On May 29, 3:09�pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote: > > > c...@claysturner.com wrote: > > > (snip) > > > > The following paper is most excellent, and I believe will more than > > > answer your questions. > > >http://www.imagescience.org/meijering/publications/download/pieee2002... > > > I would also recommend reading Nyquist's paper, though I don't > > know that it is available on the web. �It should be easy to > > find in a big university library, or maybe even a small one. > > > -- glen > > I agree, I just thought I'd point Richard to something on the web. > > ClayIt may help to know the Nyquist's article was reprinted: "Certain Topics in Telegraph Transmission Theory", Nyquist, Harry, Proc. IEEE, Vol 90, No 2, Feb 2002 FWIW, Clay
