Sharp DSP notch filter
Started by Eeyore May 20, 2009
Ben Bradley wrote:
> Here are my thoughts after reading the whole thread (I DID learn C > 22 years ago - didn't make me rich, but it paid a lot more than > cleaning toilets in recording studios, and probably even more than > designing pro audio equipment). > > In sci.electronics.design and comp.dsp, On Thu, 21 May 2009 02:54:36 > +0100, Eeyore <rabbitsfriendsandrelations@hotmail.com> wrote: > > >I am proposing to engage on a project regarding mains voltage 'purity' > >(and absence of ) with regard to audible clicks and pops in high-end > >professional and hi-fi audio equipment. > > > >Typical EMC filters operate in the RF band and are threfore no use to > >filter audio 'in band' noise that can travel through transformer > >interwinding capacitance etc. > > > >I have found some of the TI INA series that will with suitable > >preconditioning, tolerate mains voltages and give excellent common-mode > >etc rejection. So assembling a 'preamp' front end should be no problem. > > From what others posted, I'm thinking you might want to make > several of these, to also measure things like the neutral voltage and > the ground voltage (maybe referenced to your own ground stake you put > in the ground outside the window or door, on the opposite side of the > building where the main power comes in). Make these to withstand a > kilovolt or more on the inputs (use several series resistors in each > leg). That way you can see common-mode signals as well as > differential. > > > >What I will need to do however is to filter all the mains frequencies > >and harmonics to a very large degree. > > You say elsewhere you want to see the results in "real time." I > interpret that as "not having to wait 30 seconds for processing," that > a half-second or two seconds might be acceptable. > > Others have said it, but I also see this as a PC application. A USB > audio interface with four inputs should work (you probably want 24bit > samples - if USB can't do 48/24 and 4 channels, you then use a desktop > machine (or firewire, whatever), perhaps powered by a battery backup > to insure line isolation, with a 4=channel or 8-channel card). Three > inputs are for hot-to-neutral, neutral-to-your-ground, > ground-to-your-ground, and the forth is the balanced output (with > ground not connected!) of the mixer/console/UUT. > > You run this thing, and it samples data continuously. When the > mixer has an output (or when there's an anomalous output on any of the > other three inputs), the thing samples a few more cycles, then stops > and does the filtering (on data that's a few cycles long), and shows > the areas of interest, both with and without the 50/60Hz imposed on > the hot/neutral input. > > This puts all the algorithms in a PC which has plenty of DSP > horsepower thesedays, and also makes a good multichannel data > recorder. I'm thinking you (or someone who knows C and PC code > development) can get the Audacity source and modify it to do this (I > don't know of the legalities and such of using the code in a > commercial product, if you have to make the code you add open-source > or what). > > And you just might want to have more inputs to look at, such as the > main DC filtering caps of the console. This would show if the > transient occurs at a time when the rectifiers are conducting.
Hi Ben, just wanted to acknowledge the thought you put into this ( along with all the other useful contributors ). I'm going to chew it over and get back later. Graham -- due to the hugely increased level of spam please make the obvious adjustment to my email address
On 2009-05-25, panteltje@gmail.com <panteltje@gmail.com> wrote:
> On May 25, 10:10&nbsp;pm, "m...@sushi.com" <m...@sushi.com> wrote: > >> You can always dual boot a windows PC. > > It can be quite a challenge for a non Unix wizzard to start using > Linux, > especially command line tools like humfilter. > As humfitler is a a simple command line program,. > written in a simple C, and basically only > does wav file format input to wave file output, > it should be easily portable to DOS, and run in > a MSDOS window in for example XP. > Perhaps compile with the old djgpp compiler?
Or compile with the current mingw compiler and run it on the windows command-line
On 2009-05-26, Nico Coesel <nico@puntnl.niks> wrote:
> "miso@sushi.com" <miso@sushi.com> wrote: > >>On May 25, 2:21=A0pm, pantel...@gmail.com wrote: >>> On May 25, 10:10=A0pm, "m...@sushi.com" <m...@sushi.com> wrote: >>> >>> > You can always dual boot a windows PC. >>> >>> It can be quite a challenge for a non Unix wizzard to start using >>> Linux, >>> especially command line tools like humfilter. >>> As humfitler is a a simple command line program,. >>> written in a simple C, and basically only >>> does wav file format input to wave file output, >>> it should be easily portable to DOS, and run in >>> a MSDOS window in for example XP. >>> Perhaps compile with the old djgpp compiler? >>> Several of my programs have been ported to DOS by people. >>> I am sure you can somehow send the wave output to a soundcard >>> even in MS software. >> >>It's been my experience that it is easier to compile software under >>Linux. The lack of compilers for windows is the issue. I assume to > > Look for Mingw. Thats a GCC that works fine to compile software under > Windows. Still, more complex programs cannot be compiled easely > because of the Linux build tools.
You can rin mingw on linux, or many of the build tools are portable to windows (modulo the limitations of the windows command-line).
Jasen Betts wrote:
> On 2009-05-26, Nico Coesel <nico@puntnl.niks> wrote: >> "miso@sushi.com" <miso@sushi.com> wrote: >> >>> On May 25, 2:21=A0pm, pantel...@gmail.com wrote: >>>> On May 25, 10:10=A0pm, "m...@sushi.com" <m...@sushi.com> wrote: >>>> >>>>> You can always dual boot a windows PC. >>>> It can be quite a challenge for a non Unix wizzard to start using >>>> Linux, >>>> especially command line tools like humfilter. >>>> As humfitler is a a simple command line program,. >>>> written in a simple C, and basically only >>>> does wav file format input to wave file output, >>>> it should be easily portable to DOS, and run in >>>> a MSDOS window in for example XP. >>>> Perhaps compile with the old djgpp compiler? >>>> Several of my programs have been ported to DOS by people. >>>> I am sure you can somehow send the wave output to a soundcard >>>> even in MS software. >>> It's been my experience that it is easier to compile software under >>> Linux. The lack of compilers for windows is the issue. I assume to >> Look for Mingw. Thats a GCC that works fine to compile software under >> Windows. Still, more complex programs cannot be compiled easely >> because of the Linux build tools. > > You can rin mingw on linux, or many of the build tools are portable > to windows (modulo the limitations of the windows command-line).
Cygwin gives you a proper Linux command line under Windows. -- W . | ,. w , "Some people are alive only because \|/ \|/ it is illegal to kill them." Perna condita delenda est ---^----^---------------------------------------------------------------
