Hi All. I have never worked on OFDM but still I have a doubt. I know how to model time varying frequency selective channel for single carrier system in *time domain*. I am pretty sure that exactly the same way you can model the time varying frequency selective channel for OFDM. But is it something like you can model the time varying frequency selective channel for OFDM in *frequency domain* itself? And if it is possible, then which would be the best way to model time varying frequency selective channel for OFDM, time domain or frequency domain? Thanks Best Regards, Chintan
OFDM and channel modeling
Started by ●May 21, 2009
Reply by ●May 22, 20092009-05-22
I can guess what you are getting at. But I don't think it is feasible. Since standard OFDM has a cyclic prefix, in ideal conditions you can do the modelling in frequency domain as well. But that does not take into consideration time varying nature of nature of channel ( for coherence time much smaller than OFDM symbol). Also, by definition, you can not simulate cases where channel response length is larger than the cyclic prefix. I have used time domain channel with OFDM multiple times and it works fine. It is also defined the same way by all specifications (WiMAX, LTE etc) that I have come across, So I would suggest the same to you as well. Regards Piyush On May 22, 1:14�am, "cpshah99" <cpsha...@rediffmail.com> wrote:> Hi All. > > I have never worked on OFDM but still I have a doubt. > > I know how to model time varying frequency selective channel for single > carrier system in *time domain*. I am pretty sure that exactly the same way > you can model the time varying frequency selective channel for OFDM. > > But is it something like you can model the time varying frequency > selective channel for OFDM in *frequency domain* itself? > > And if it is possible, then which would be the best way to model time > varying frequency selective channel for OFDM, time domain or frequency > domain? > > Thanks > > Best Regards, > > Chintan
>I can guess what you are getting at. But I don't think it is feasible. >Since standard OFDM has a cyclic prefix, in ideal conditions you can >do the modelling in frequency domain as well. But that does not take >into consideration time varying nature of nature of channel ( for >coherence time much smaller than OFDM symbol). Also, by definition, >you can not simulate cases where channel response length is larger >than the cyclic prefix. I have used time domain channel with OFDM >multiple times and it works fine. It is also defined the same way by >all specifications (WiMAX, LTE etc) that I have come across, So I >would suggest the same to you as well. > >Regards >Piyush >Hi Piyush Thanks for your reply. Actually there was a bit of conflict over channel modeling for OFDM and I was pressing that you can model channel in time domain and it has to be like that but some ppl did nt agree with that. I guess it will become more clear once I start to work on it. Thanks anyways. Chintan
On May 22, 3:18�am, "cpshah99" <cpsha...@rediffmail.com> wrote:> > Hi Piyush > > Thanks for your reply. > > Actually there was a bit of conflict over channel modeling for OFDM and I > was pressing that you can model channel in time domain and it has to be > like that but some ppl did nt agree with that. > > I guess it will become more clear once I start to work on it. > > Thanks anyways. > > ChintanPersonally I almost always do modeling in time, especially when it comes to issues like acquisition, changing channel parameters, and synchronization. It's too easy to over-simplify things in the frequency domain. Plus, your implementation will be in the time domain, so why not have as accurate a model as possible. As you should know, the translation from time to frequency is not straight-forward as many think, in particular when you have sampling issues in terms of both representation and system dynamics. A very common mistake is to do tea leaf reading of a "spectrum" of a non-stationary signal. Even more basically, people throw around terms like FFT very loosely without clever qualifiers whether the output of the computation is representative or not. As Piyush said, that's why OFDM has cyclic prefix. But exactly because of this, be careful when moving from time to frequency domain representations. Or, in a mathematical sense, make sure that when you move from time to frequency domain representations, your system is statistically invariant (at least to an extent that you can guarantee). I don't think you can do this very easily with time-varying channels unless you consider only trivial cases. Julius
Hi Julius Thanks for replying. Actually I do not know when I will work on OFDM, but what you guys r saying is correct as always. I simulated a time varying channel recently for my single carrier underwater system and it is an acurate model. And as you said, why not model channel in time domain as acurately as possible. Thanks again. Chintan
