hi every body,
i am using 6713DSK for my project.i use AIC23 for sampling a 1khz sin wave
and collect them in a buffer.i configured MCBSP for 32 bit one frame
format.after sampling i shift 32 bits samples to right to just have 16 bits
of left channel.then when i plot the collected samples in CCS it is not a
1khz sin wave.does anyone know what is my problem. i dont have mush
time.please help me if you can.also you can send your response to this mail
address:mahnaznamazi@gmail.com
thanks.
mahnaz.
my code:
//connect a 1khx sin wave to channel left of codec ,
//then plot the buffer sample[8] in ccs,it must be a 1khx sin wave.
#define CHIP_6713
#include <stdio.h>
#include <csl.h>
#include <csl_mcbsp.h>
#include "dsk6713.h"
#include "dsk6713_aic23.h"
/* Codec configuration settings */
DSK6713_AIC23_Config config = {
0x0017, // 0 DSK6713_AIC23_LEFTINVOL Left line input channel volume
0x0017, // 1 DSK6713_AIC23_RIGHTINVOL Right line input channel volume
0x00d8, // 2 DSK6713_AIC23_LEFTHPVOL Left channel headphone volume
0x00d8, // 3 DSK6713_AIC23_RIGHTHPVOL Right channel headphone volume
0x0011, // 4 DSK6713_AIC23_ANAPATH Analog audio path control
0x0000, // 5 DSK6713_AIC23_DIGPATH Digital audio path control
0x0000, // 6 DSK6713_AIC23_POWERDOWN Power down control
0x0043, // 7 DSK6713_AIC23_DIGIF Digital audio interface format
0x0029, // 8 DSK6713_AIC23_SAMPLERATE Sample rate control
0x0001 // 9 DSK6713_AIC23_DIGACT Digital interface activation
Uint32 sample[64];
int i;
void init_mcbsp(void);
void main()
DSK6713_AIC23_CodecHandle hCodec;
CSL_init();
init_mcbsp();
DSK6713_init();
/* Start the codec */
hCodec = DSK6713_AIC23_openCodec(0, &config);
for (i=0;i<64;i++)
/* Read a 16-bit value from the left channel */
DSK6713_AIC23_read(hCodec, &sample[i]);
//sample[i]=(sample[i])>>16;
printf("sample %d=%d\n",i+1,sample[i]);
DSK6713_AIC23_closeCodec(hCodec);
} //end of main
void init_mcbsp(){
MCBSP_Config mcbsp_config= {
MCBSP_FMKS(SPCR, FREE, NO) |
MCBSP_FMKS(SPCR, SOFT, NO) |
MCBSP_FMKS(SPCR, FRST, YES) |
MCBSP_FMKS(SPCR, GRST, YES) |
MCBSP_FMKS(SPCR, XINTM, XRDY) |
MCBSP_FMKS(SPCR, XSYNCERR, NO) |
MCBSP_FMKS(SPCR, XRST, YES) |
MCBSP_FMKS(SPCR, DLB, OFF) |
MCBSP_FMKS(SPCR, RJUST, RZF) |
MCBSP_FMKS(SPCR, CLKSTP, DISABLE) |
MCBSP_FMKS(SPCR, DXENA, OFF) |
MCBSP_FMKS(SPCR, RINTM, RRDY) |
MCBSP_FMKS(SPCR, RSYNCERR, NO) |
MCBSP_FMKS(SPCR, RRST, YES),
MCBSP_FMKS(RCR, RPHASE, SINGLE) |
MCBSP_FMKS(RCR, RFRLEN2, DEFAULT) |
MCBSP_FMKS(RCR, RWDLEN2, DEFAULT) |
MCBSP_FMKS(RCR, RCOMPAND, MSB) |
MCBSP_FMKS(RCR, RFIG, NO) |
MCBSP_FMKS(RCR, RDATDLY, 0BIT) |
MCBSP_FMKS(RCR, RFRLEN1, OF(0)) | // This changes to 1
FRAME
MCBSP_FMKS(RCR, RWDLEN1, 32BIT) | // This changes to 16
bits per frame
MCBSP_FMKS(RCR, RWDREVRS, DISABLE),
MCBSP_FMKS(XCR, XPHASE, SINGLE) |
MCBSP_FMKS(XCR, XFRLEN2, DEFAULT) |
MCBSP_FMKS(XCR, XWDLEN2, DEFAULT) |
MCBSP_FMKS(XCR, XCOMPAND, MSB) |
MCBSP_FMKS(XCR, XFIG, NO) |
MCBSP_FMKS(XCR, XDATDLY, 0BIT) |
MCBSP_FMKS(XCR, XFRLEN1, OF(0)) | // This changes to 1
FRAME
MCBSP_FMKS(XCR, XWDLEN1, 32BIT) | // This changes to 16
bits per frame
MCBSP_FMKS(XCR, XWDREVRS, DISABLE),
MCBSP_FMKS(SRGR, GSYNC, DEFAULT) |
MCBSP_FMKS(SRGR, CLKSP, DEFAULT) |
MCBSP_FMKS(SRGR, CLKSM, DEFAULT) |
MCBSP_FMKS(SRGR, FSGM, DEFAULT) |
MCBSP_FMKS(SRGR, FPER, DEFAULT) |
MCBSP_FMKS(SRGR, FWID, DEFAULT) |
MCBSP_FMKS(SRGR, CLKGDV, DEFAULT),
MCBSP_MCR_DEFAULT,
MCBSP_RCER_DEFAULT,
MCBSP_XCER_DEFAULT,
MCBSP_FMKS(PCR, XIOEN, SP) |
MCBSP_FMKS(PCR, RIOEN, SP) |
MCBSP_FMKS(PCR, FSXM, EXTERNAL) |
MCBSP_FMKS(PCR, FSRM, EXTERNAL) |
MCBSP_FMKS(PCR, CLKXM, INPUT) |
MCBSP_FMKS(PCR, CLKRM, INPUT) |
MCBSP_FMKS(PCR, CLKSSTAT, DEFAULT) |
MCBSP_FMKS(PCR, DXSTAT, DEFAULT) |
MCBSP_FMKS(PCR, FSXP, ACTIVEHIGH) |
MCBSP_FMKS(PCR, FSRP, ACTIVEHIGH) |
MCBSP_FMKS(PCR, CLKXP, FALLING) |
MCBSP_FMKS(PCR, CLKRP, RISING)
MCBSP_Handle hMcbsp;
hMcbsp = MCBSP_open(MCBSP_DEV1,MCBSP_OPEN_RESET);
if (hMcbsp==INV){
printf("can not open mcbsp1\n");
MCBSP_config(hMcbsp,&mcbsp_config);
MCBSP_start( hMcbsp, MCBSP_RCV_START | MCBSP_SRGR_START |
MCBSP_SRGR_FRAMESYNC ,220);
sampling with 6713DSK
Started by ●May 26, 2009
