Hello, Working on the design of decimation filter for multistage, sample rate conversion. I have designed a filter which represents G(z). With freqz(b,1,1024) I can plot the frequency response of the filter (the coefficients are in "b"). However, its output will be downsampled by, say M = 10. How to plot the frequency response of G(z^10)? The kind of plot like Figure 4.4-7 (c), in P.P. Vaidyanathan, "Multirate Systems and Filter Banks", Prentice Hall, 1993, page 142. TIA -- Jaime Andr�s Aranguren Cardona jaac@nospam.sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com (Remove "nospam" from e-mail address)
Multirate filters, MATLAB
Started by ●October 13, 2004
Reply by ●October 14, 20042004-10-14
Hi Jaime Downsampling would produce G(z^(1/10)). To get G(z^10), use upsampling by 10. This is how the figure you refer to is obtained. Upsampling by 10 would mean inserting 9 zeroes after each coefficient in b. A freqz after this operation should yield the desired result. Regards Biswaroop "Jaime Andr�s Aranguren Cardona" <jaac@nospam.sanjaac.com> wrote in message news:<1097691804.V820vnzzwb5wpYACB8+Tjw@teranews>...> Hello, > > Working on the design of decimation filter for multistage, sample rate > conversion. > > I have designed a filter which represents G(z). With freqz(b,1,1024) I can > plot the frequency response of the filter (the coefficients are in "b"). > However, its output will be downsampled by, say M = 10. How to plot the > frequency response of G(z^10)? > > The kind of plot like Figure 4.4-7 (c), in P.P. Vaidyanathan, "Multirate > Systems and Filter Banks", Prentice Hall, 1993, page 142. > > TIA
b_palit@rediffmail.com (Biswaroop Palit) wrote in message news:<49fc39b9.0410132135.71356bb9@posting.google.com>...> Hi Jaime > Downsampling would produce G(z^(1/10)). To get G(z^10), use upsampling > by 10. This is how the figure you refer to is obtained. > > Upsampling by 10 would mean inserting 9 zeroes after each coefficient > in b. A freqz after this operation should yield the desired result.You're right. Thanks for correctng me. Regards, JaaC> > Regards > Biswaroop > > "Jaime Andr�s Aranguren Cardona" <jaac@nospam.sanjaac.com> wrote in message news:<1097691804.V820vnzzwb5wpYACB8+Tjw@teranews>... > > Hello, > > > > Working on the design of decimation filter for multistage, sample rate > > conversion.
Hi, Here's an example using the Signal Processing Toolbox that plots the response of a filter running at two different rates. Assuming a decimation factor of 10. h = dfilt.dffir(fir1(100,.25)) fvtool(h,h,'Fs',[1 1/10]) If you have the MathWorks' Filter Design Toolbox you can also define multirate multistage filters and view their responses with FVTool. Type "help mfilt/firdecim" for details. By the way, the kind of plot you see in the reference you mentioned is achieved using an Interpolator FIR (IFIR) filter. You can use the IFIR function in the Filter Design Toolbox to achieve those results. Type "help ifir" in MATLAB for details. Here's an example usage of the IFIR function: % Design periodic filter H(z) and image-suppressor G(z) filter. Fs = 8e3; [h,g] = ifir(40,'low',[70 80]/(Fs/2),[.1 .01]); H = dfilt.dffir(h); G = dfilt.dffir(g); % View individual filter responses. hfv = fvtool(H,G); legend(hfv,'Periodic Filter','Image Suppressor Filter'); % Cascade H(z) and G(z) and view overall response. Hcas = cascade(H,G); hfv2 = fvtool(Hcas); legend(hfv2,'Overall Filter'); HTH -Paul ---- "Biswaroop Palit" <b_palit@rediffmail.com> wrote in message news:49fc39b9.0410132135.71356bb9@posting.google.com...> Hi Jaime > Downsampling would produce G(z^(1/10)). To get G(z^10), use upsampling > by 10. This is how the figure you refer to is obtained. > > Upsampling by 10 would mean inserting 9 zeroes after each coefficient > in b. A freqz after this operation should yield the desired result. > > Regards > Biswaroop > > "Jaime Andr�s Aranguren Cardona" <jaac@nospam.sanjaac.com> wrote inmessage news:<1097691804.V820vnzzwb5wpYACB8+Tjw@teranews>...> > Hello, > > > > Working on the design of decimation filter for multistage, sample rate > > conversion. > > > > I have designed a filter which represents G(z). With freqz(b,1,1024) Ican> > plot the frequency response of the filter (the coefficients are in "b"). > > However, its output will be downsampled by, say M = 10. How to plot the > > frequency response of G(z^10)? > > > > The kind of plot like Figure 4.4-7 (c), in P.P. Vaidyanathan, "Multirate > > Systems and Filter Banks", Prentice Hall, 1993, page 142. > > > > TIA
