Rate-gyro and compass: Kalman filter
Started by Marco Trapanese ●May 27, 2009
Hi to all,
I have an underwater vehicle with an electronic compass and a rate-gyro.
You know, the compass has a good long-term accuracy but it's slow and
noisy on short-term (there are several DC brushless motors in the nearby).
On the other side, the rate-gyro is more accurate on the short-term and
for not-so-slow turns.
I want to mix up the two values in order to get a more accurate heading
output. As far as I know I need a Kalman filter, I read something on the
web.
Anyway, I can't figure out how to design it. May you help me with some
code or any documents related?
Thanks
Marco Trapanese
On Wed, 27 May 2009 17:20:53 +0200, Marco Trapanese wrote:
> Hi to all, > > I have an underwater vehicle with an electronic compass and a rate-gyro. > > You know, the compass has a good long-term accuracy but it's slow and > noisy on short-term (there are several DC brushless motors in the > nearby). On the other side, the rate-gyro is more accurate on the > short-term and for not-so-slow turns. > > I want to mix up the two values in order to get a more accurate heading > output. As far as I know I need a Kalman filter, I read something on the > web. > > Anyway, I can't figure out how to design it. May you help me with some > code or any documents related? >
AFAIK you'll end up needing a 3-axis gyro. Your vehicle isn't going to be running on rails, and you need all three axes to keep track of your one "cared about" axis as the vehicle rotates in all possible ways. See this thread; search down to the word "bibliography" for my suggestions on this subject. -- http://www.wescottdesign.com
Tim Wescott ha scritto:
> AFAIK you'll end up needing a 3-axis gyro. Your vehicle isn't going to > be running on rails, and you need all three axes to keep track of your > one "cared about" axis as the vehicle rotates in all possible ways.
Hi Tim, you helped me a lot in the past with your answers and your book! You're right when you say I need a 3-axis gyro. And this will be mandatory on bigger vehicles (to say the truth, I will use a 6 DOF IMO) but on smaller ones I have to use only the z-axis gyro. They don't run on rails, indeed, but the pitch and roll ranges are about ±7° in normal conditions. Furthermore, I don't need a huge accuracy. At the moment I use only the compass output (with a PID) to do the auto heading and the response is quite poor. I tried to use only the rate-gyro, integrated to output an heading value and this improved the overall performance. For this first step, I just need to mix up the compass with the gyro output. Next upgrade will consider a more complex sensor and control loop.
> See this thread; search down to the word "bibliography" for my > suggestions on this subject.
Did you mean "see this link" - your website? Marco
On Thu, 28 May 2009 09:52:25 +0200, Marco Trapanese wrote:
> Tim Wescott ha scritto: > >> AFAIK you'll end up needing a 3-axis gyro. Your vehicle isn't going to >> be running on rails, and you need all three axes to keep track of your >> one "cared about" axis as the vehicle rotates in all possible ways. > > > Hi Tim, > > you helped me a lot in the past with your answers and your book! You're > right when you say I need a 3-axis gyro. And this will be mandatory on > bigger vehicles (to say the truth, I will use a 6 DOF IMO) but on > smaller ones I have to use only the z-axis gyro. > > They don't run on rails, indeed, but the pitch and roll ranges are about > ±7° in normal conditions. Furthermore, I don't need a huge accuracy. At > the moment I use only the compass output (with a PID) to do the auto > heading and the response is quite poor. > > I tried to use only the rate-gyro, integrated to output an heading value > and this improved the overall performance. > > For this first step, I just need to mix up the compass with the gyro > output. Next upgrade will consider a more complex sensor and control > loop.
With two closely related inputs like this, if you don't need the acquisition capabilities of a Kalman, you can approximate what you want with plain old filtering and intuition. You won't get an optimum filter, but then you wouldn't get that with the Kalman exercise unless you got all the noise variances and other error terms very well modeled. First, consider a pair of inputs that are just noisy versions of the same thing: ra = x + na, rb = x + nb If you filter these right then you'll get back your signal plus noise: x_est = H * ra + (1 - H) * rb. So, for example, if H is a 1st-order lowpass filter with DC gain of 1, then 1 - H will be a first-order highpass filter with AC gain of 1. But what you have is approximated by ra = x + na (your compass) rb = dx/dt + nb (your gyro) So make a third signal: rc = rb / s (I'm playing fast and loose with notation) then rc = x + nb / s Now you know that the noise on ra is severe but good at DC, and you know the noise on rc is infinite at DC. So choose that 1st-order lowpass filter again, and use x_est = H * ra + (1 - H) * rc. That should get you close.
>> See this thread; search down to the word "bibliography" for my >> suggestions on this subject. > > > Did you mean "see this link" - your website?
No, I meant this: http://www.dsprelated.com/showmessage/111654/1.php. I just left it out... -- http://www.wescottdesign.com
> First, consider a pair of inputs that are just noisy versions of the same > thing: > > ra = x + na, > rb = x + nb > > If you filter these right then you'll get back your signal plus noise: > > x_est = H * ra + (1 - H) * rb. > > So, for example, if H is a 1st-order lowpass filter with DC gain of 1, > then 1 - H will be a first-order highpass filter with AC gain of 1. > > But what you have is approximated by > > ra = x + na (your compass) > rb = dx/dt + nb (your gyro)
Ok.
> So make a third signal: > > rc = rb / s (I'm playing fast and loose with notation)
You're integrating the gyro, aren't you?
> then > > rc = x + nb / s
Yep. But as far as I see rc != ra, because the compass output is referred to the North but the integrated gyro has no reference.
> Now you know that the noise on ra is severe but good at DC, and you know > the noise on rc is infinite at DC. So choose that 1st-order lowpass > filter again, and use > > x_est = H * ra + (1 - H) * rc. > > That should get you close.
Ok, I got it. My only doubt is related to the reference of the gyro. I can't understand how to handle that...
> No, I meant this: http://www.dsprelated.com/showmessage/111654/1.php. I > just left it out...
Very interesting. Thank you. Marco
On Thu, 28 May 2009 21:16:59 +0200, Marco Trapanese wrote:
> Tim Wescott ha scritto: > >> First, consider a pair of inputs that are just noisy versions of the >> same thing: >> >> ra = x + na, >> rb = x + nb >> >> If you filter these right then you'll get back your signal plus noise: >> >> x_est = H * ra + (1 - H) * rb. >> >> So, for example, if H is a 1st-order lowpass filter with DC gain of 1, >> then 1 - H will be a first-order highpass filter with AC gain of 1. >> >> But what you have is approximated by >> >> ra = x + na (your compass) >> rb = dx/dt + nb (your gyro) > > > Ok. > > >> So make a third signal: >> >> rc = rb / s (I'm playing fast and loose with notation) > > > You're integrating the gyro, aren't you? > > >> then >> >> rc = x + nb / s > > > Yep. But as far as I see rc != ra, because the compass output is > referred to the North but the integrated gyro has no reference. > > >> Now you know that the noise on ra is severe but good at DC, and you >> know the noise on rc is infinite at DC. So choose that 1st-order >> lowpass filter again, and use >> >> x_est = H * ra + (1 - H) * rc. >> >> That should get you close. > > > Ok, I got it. > My only doubt is related to the reference of the gyro. I can't > understand how to handle that...
If you choose H to be a unity-gain DC filter, i.e. H = w0/(s + w0), then 1 - H will have zero gain at DC. This means that 1-H will have an 's' term in it's numerator, which will cancel with the integrator in rc. So rc = w_g/s + nb/s, but 1 - H = s / (s + w0) so (1 - H) rc = (wg + nb) / (s + w0). This is a low-pass filter. Your gyro's 'reference' is zero (assuming zero gyro drift); the average compass heading comes from the compass. Note that if you want this to work around the full circle you'll have to mind your p's and q's in the filter implementation such that the filter correctly handles the transition from -180 to +180 seamlessly. -- http://www.wescottdesign.com
> This is a low-pass filter. Your gyro's 'reference' is zero (assuming > zero gyro drift); the average compass heading comes from the compass.
Great! Now I understand!
> Note that if you want this to work around the full circle you'll have to > mind your p's and q's in the filter implementation such that the filter > correctly handles the transition from -180 to +180 seamlessly.
Yes, I got it. Thanks a lot! Marco
Tim, I'm playing with some filters to see what they do :) Currently, I'm trying a biquad IIR but I can't easily handle the 360&deg; -> 0&deg; transition and vice versa. The straight case is quite simple: if (HMR3300.hdg > 270 && ROVDATA.hdg < 90) ROVDATA.hdg = (int) iir_update(&iir_low_pass, HMR3300.hdg + 360) else if (HMR3300.hdg < 90 && ROVDATA.hdg > 270) ROVDATA.hdg = (int) iir_update(&iir_low_pass, HMR3300.hdg - 360) if (ROVDATA.hdg >= 360) ROVDATA.hdg -= 360; if (ROVDATA.hdg < 0 ) ROVDATA.hgd += 360; where HMR3300.hdg is the input signal and ROVDATA.hdg the current filter value. But what about the samples stored in the delay line? Conditioning all the samples seems to be a bit harder. And if the filter is longer? Argh! I can't see a simple way. Someone suggested me to convert the angle to cartesian coordinates (sin, cos) filter them and then come back with atan. There is a more convenient way to do this? Marco
In article <KI2dnRRwTPRANoPXnZ2dnUVZ_qZi4p2d@web-ster.com>,
Tim Wescott  <tim@seemywebsite.com> wrote:
>On Thu, 28 May 2009 09:52:25 +0200, Marco Trapanese wrote: >> For this first step, I just need to mix up the compass with the gyro >> output. Next upgrade will consider a more complex sensor and control >> loop. > >With two closely related inputs like this, if you don't need the >acquisition capabilities of a Kalman, you can approximate what you want >with plain old filtering and intuition. [....] >If you filter these right then you'll get back your signal plus noise: >x_est = H * ra + (1 - H) * rb.
Ignoring the intuition ;), this is what's also referred to as a complementary filter, right? -- Wim Lewis <wiml@hhhh.org>, Seattle, WA, USA. PGP keyID 27F772C1 "We learn from history that we do not learn from history." -Hegel
On Fri, 05 Jun 2009 08:18:36 +0200, Marco Trapanese wrote:
> Tim Wescott ha scritto: > >> Note that if you want this to work around the full circle you'll have >> to mind your p's and q's in the filter implementation such that the >> filter correctly handles the transition from -180 to +180 seamlessly. > > > Tim, > > I'm playing with some filters to see what they do :) Currently, I'm > trying a biquad IIR but I can't easily handle the 360&deg; -> 0&deg; transition > and vice versa. > > The straight case is quite simple: > > if (HMR3300.hdg > 270 && ROVDATA.hdg < 90) > ROVDATA.hdg = (int) iir_update(&iir_low_pass, HMR3300.hdg + 360) > else if (HMR3300.hdg < 90 && ROVDATA.hdg > 270) > ROVDATA.hdg = (int) iir_update(&iir_low_pass, HMR3300.hdg - 360) > > if (ROVDATA.hdg >= 360) ROVDATA.hdg -= 360; if (ROVDATA.hdg < 0 ) > ROVDATA.hgd += 360; > > where HMR3300.hdg is the input signal and ROVDATA.hdg the current filter > value. > > But what about the samples stored in the delay line? > > Conditioning all the samples seems to be a bit harder. And if the filter > is longer? Argh! > > I can't see a simple way. Someone suggested me to convert the angle to > cartesian coordinates (sin, cos) filter them and then come back with > atan. > > There is a more convenient way to do this?
Convenient, simple -- and damned subtle and hard to wrap your brain around: Use the fact that integers wrap to your advantage. It's the only time you'll be able to, so revel in it. If you're programming in C, on a machine that uses 2's compliment arithmetic, then INT_MAX will equal 2^(N-1) - 1, where N is the word width in bits. INT_MIN will equal exactly -2^(N-1). So map your angles into integers such that INT_MIN represents -180 degrees. Then -- as if by magic -- you'll find that +179 degrees + 1 degree = -180 degrees. Now _carefully_ arrange your filter: y_t = y_t + (x_t - y_t) / factor. This is a first-order low-pass with a pole at 1 - 1/factor. What's cool about it is that (on all of the machines that I've encountered) the x_t - y_t term wraps, so it always finds the shortest path between the state and the target. y_t x_t x_t - y_t 0x6000 0xa000 0x4000 0x7000 0xa000 0x3000 0x7c00 0xa000 0x2400 0x8500 0xa000 0x1b00 0x8bc0 0xa000 0x1440 Try it, You'll like it. Hopefully this will get you started -- I'm sure this can be extended to 2nd-order filters, but you'll have to use a more state-space approach rather than looking up bilinear filters in a cook book. -- http://www.wescottdesign.com
