[OT-ish] It's Spring, when a young man's thoughts turn to
Started by Tim Wescott June 2, 2009
Getting the heck out of engineering school while he's still young!
For some reason, this year I'm getting mail directly from the "help me I
have a month to get my senior project done" crowd.  I always start by
pointing them to their prof/teaching assistant/tutor/whatever, but it's
hard to decide just how much help to give these guys (none is too little
IMHO, but I certainly don't want to spend _much_).  (It's a bit too late
to point out that it's a bit too late to be starting -- but then, senior
projects are about learning things like when to start, I suppose).
There needs to be a generic "So you need to finish your senior project"
FAQ out there.
www.wescottdesign.com
"Tim Wescott" <tim@seemywebsite.com> wrote in message
news:WvCdnWXTytfdyrjXnZ2dnUVZ_gChnZ2d@web-ster.com...
> For some reason, this year I'm getting mail directly from the "help me I > have a month to get my senior project done" crowd. I always start by > pointing them to their prof/teaching assistant/tutor/whatever, but it's > hard to decide just how much help to give these guys (none is too little > IMHO, but I certainly don't want to spend _much_).
You should start selling parts kits with your inverted pendulum demo and point them to it to make a few quick bucks. :-)
> Getting the heck out of engineering school while he's still young! > > For some reason, this year I'm getting mail directly from the "help me I > have a month to get my senior project done" crowd. I always start by > pointing them to their prof/teaching assistant/tutor/whatever, but it's > hard to decide just how much help to give these guys (none is too little > IMHO,
That really depends on how the question is asked. If its an "I'm an embedded systems master and have an emergency, I need to implement USB. Now I see USB but have doubt. How I implement USB?" Then 'none' is definitely not too little. If its an "I'm trying to use USB for the first time. I started off reading XYZ book, and most of it made sense. However, now I come to implement it it stops working after 5 minutes. I've tried A, B and C to debug the problem, but am having no luck. Can you suggest the next steps I should take" - then I will take the time to try and give an answer. -- Regards, Richard. + http://www.FreeRTOS.org Designed for Microcontrollers. More than 7000 downloads per month. + http://www.SafeRTOS.com Certified by T&#4294967295;V as meeting the requirements for safety related systems.
On Tue, 02 Jun 2009 11:45:52 -0500, Tim Wescott <tim@seemywebsite.com>
wrote:
>Getting the heck out of engineering school while he's still young! > >For some reason, this year I'm getting mail directly from the "help me I >have a month to get my senior project done" crowd. I always start by >pointing them to their prof/teaching assistant/tutor/whatever, but it's >hard to decide just how much help to give these guys (none is too little >IMHO, but I certainly don't want to spend _much_). (It's a bit too late >to point out that it's a bit too late to be starting -- but then, senior >projects are about learning things like when to start, I suppose). > >There needs to be a generic "So you need to finish your senior project" >FAQ out there.
Tim, You're wa-a-a-ay behind. I'm getting tons of "o-mi-gawd, I can't find a job" inquiries. It's terrible this year... anyone surprised ?:-) ...Jim Thompson -- | James E.Thompson, P.E. | mens | | Analog Innovations, Inc. | et | | Analog/Mixed-Signal ASIC's and Discrete Systems | manus | | Phoenix, Arizona 85048 Skype: Contacts Only | | | Voice:(480)460-2350 Fax: Available upon request | Brass Rat | | E-mail Icon at http://www.analog-innovations.com | 1962 | Obama... another Carter, just more ego and less brains or talent
Tim Wescott wrote:
> Getting the heck out of engineering school while he's still young! > > For some reason, this year I'm getting mail directly from the "help me I > have a month to get my senior project done" crowd. I always start by > pointing them to their prof/teaching assistant/tutor/whatever, but it's > hard to decide just how much help to give these guys (none is too little > IMHO, but I certainly don't want to spend _much_). (It's a bit too late > to point out that it's a bit too late to be starting -- but then, senior > projects are about learning things like when to start, I suppose). > > There needs to be a generic "So you need to finish your senior project" > FAQ out there. >
It seems that too often the FAQ answer should be: start it when you are a junior. Ed
On Jun 2, 2:25&#4294967295;pm, ehsjr <eh...@NOSPAMverizon.net> wrote:
> > It seems that too often the FAQ answer should be: > start it when you are a junior.
Then they would not have any bearing on the real world. You know, the world in which you are only told about the project *after* the promised delivery date...
On 2009-06-02, FreeRTOS.org <noemail@given.com> wrote:
> "Tim Wescott" <tim@seemywebsite.com> wrote > >> Getting the heck out of engineering school while he's still young! >> >> For some reason, this year I'm getting mail directly from the >> "help me I have a month to get my senior project done" crowd. >> I always start by pointing them to their prof/teaching >> assistant/tutor/whatever, but it's hard to decide just how >> much help to give these guys (none is too little IMHO, > > That really depends on how the question is asked. If its an > "I'm an embedded systems master and have an emergency, I need > to implement USB. Now I see USB but have doubt. How I > implement USB?" Then 'none' is definitely not too little.
I sometimes get those sorts of e-mails (almost always from one of a small handful of Asian countries). The "student" apparently has absolutely no technical knowlege/skills, and always demands "please send me source codes" or requests step-by-step instructions on how to design something. There's obviously no hope for a poor kid who's managed to make it through 3+ years of engineering school without learning much of anything. They appear unable to even use Google, which raises the question of how do they find the e-mail addresses of people to whom they send questions? Sadly, I've learned to ignore those e-mails.
> If its an "I'm trying to use USB for the first time. I > started off reading XYZ book, and most of it made sense. > However, now I come to implement it it stops working after 5 > minutes. I've tried A, B and C to debug the problem, but am > having no luck. Can you suggest the next steps I should take" > - then I will take the time to try and give an answer.
Yup, "real" questions (even rather confused ones) on specific topics are always welcome -- though more so on newsgroups and mailing lists than via private e-mail. I usually try to point them towards an appropriate forum and then answer the question there (if I can). -- Grant Edwards grante Yow! I'm in direct contact at with many advanced fun visi.com CONCEPTS.
Grant Edwards wrote:
> Yup, "real" questions (even rather confused ones) on specific > topics are always welcome -- though more so on newsgroups and > mailing lists than via private e-mail. I usually try to point > them towards an appropriate forum and then answer the question > there (if I can).
I like it when the questions come early enough for the answers to be of possible use. We got to know Julius Kusuma when he was a senior at Purdue. It was clear then that he could think (and nobody here ever said "I told you so!" Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Jun 2, 5:09&#4294967295;pm, Jerry Avins <j...@ieee.org> wrote:
> Grant Edwards wrote: > > &#4294967295; &#4294967295;... > > > Yup, "real" questions (even rather confused ones) on specific > > topics are always welcome -- though more so on newsgroups and > > mailing lists than via private e-mail. &#4294967295;I usually try to point > > them towards an appropriate forum and then answer the question > > there (if I can). > > I like it when the questions come early enough for the answers to be of > possible use. We got to know Julius Kusuma when he was a senior at > Purdue. It was clear then that he could think (and nobody here ever said > "I told you so!" > > Jerry
Guilty as charged! (The asking questions part. The thinking part I leave to you). The Julius Kusuma ;-)
On Tue, 02 Jun 2009 10:51:54 -0700, Jim Thompson
<To-Email-Use-The-Envelope-Icon@My-Web-Site.com> wrote:
>On Tue, 02 Jun 2009 11:45:52 -0500, Tim Wescott <tim@seemywebsite.com> >wrote: > >>Getting the heck out of engineering school while he's still young! >> >>For some reason, this year I'm getting mail directly from the "help me I >>have a month to get my senior project done" crowd. I always start by >>pointing them to their prof/teaching assistant/tutor/whatever, but it's >>hard to decide just how much help to give these guys (none is too little >>IMHO, but I certainly don't want to spend _much_). (It's a bit too late >>to point out that it's a bit too late to be starting -- but then, senior >>projects are about learning things like when to start, I suppose). >> >>There needs to be a generic "So you need to finish your senior project" >>FAQ out there. > >Tim, You're wa-a-a-ay behind. I'm getting tons of "o-mi-gawd, I >can't find a job" inquiries. It's terrible this year... anyone >surprised ?:-)
All from H1B holders.
