Hi folks, Im working on developing a Matlab version of pruned FFT/IFFT algorithm. But although i think that the implementation is correct, the reults are not equal to full FFT. So, in a fast x-correlation problem this mismatch arises out of the maximum (the time delay) is somtimes shifted. I am at pains to search about this accuracy/mismatch but i have not found the point. I need your knowledge and help. Thanks in advance, Patrick
pruned FFT/IFFT
Started by ●June 3, 2009
Reply by ●June 5, 20092009-06-05
On Jun 3, 9:05�am, "patrickm" <patrikiopat...@hotmail.com> wrote:> Hi folks, > > Im working on developing a Matlab version of pruned FFT/IFFT algorithm. > But although i think that the implementation is correct, the reults are not > equal to full FFT. So, in a fast x-correlation problem this mismatch arises > out of the maximum (the time delay) is somtimes shifted. > > I am at pains to search about this accuracy/mismatch but i have not found > the point. I need your knowledge and help. > > Thanks in advance, > > PatrickI don't use Matlab, but I do know that it has real to complex FFTs and complex to real IFFTs. So why would you bother to prune things yourself when there's something similar already available? I doubt that your algorithm is working right. You should check whatever points you're getting from the pruned FFT and compare them to the same points in a 'known good' FFT program. Then check your IFFT. If you're doing pruned forward and inverse algorithms and then doing a cross correlation, you've got 3 distinct places where you can make mistakes. Check each of the 3 parts against results that you know to be correct. I also don't know if you're doing the cross correlation correctly. Matlab has a function to do that, too. Kevin
