Hi iam doing my M.Phil and my research area is Image Processing and specifically "TEXT EXTRACTION FROM IMAGES".. Can u give me some ideas based on this.. from the papers already i gone through i can able to understand only the THEROTICAL Concepts.. I dont know to apply PRACTICALLY eg.. After detecting text in an image put bounding boxes but my big doubt is how to put bounding boxes around the text? how to write MATLAB code for it.. i dont have any idea sir... Wat i have done through is 1.If it is color image convert to grayscale image 2.By thresholding i convert to binary image.. 3.Then applying edge eg..sobel,roberts etc i can highlight the text area.. tats it.. but how to extract only the text pixels in an image.. kindly help me Thanx in advance
Text Extraction from image
Started by ●June 4, 2009
Reply by ●June 4, 20092009-06-04
radhiya86@gmail.com wrote:> Hi > > iam doing my M.Phil and my research area is Image Processing and > specifically "TEXT EXTRACTION FROM IMAGES".. > > > Can u give me some ideas based on this.. > > from the papers already i gone through i can able to understand only > the THEROTICAL Concepts.. > > > I dont know to apply PRACTICALLY > > > eg.. After detecting text in an image put bounding boxes but my big > doubt is how to put bounding boxes around the text? > how to write MATLAB code for it.. i dont have any idea sir... > > > Wat i have done through is > 1.If it is color image convert to grayscale image > 2.By thresholding i convert to binary image.. > 3.Then applying edge eg..sobel,roberts etc i can highlight the text > area.. > > > tats it.. > > > but how to extract only the text pixels in an image.. > > > kindly help meYou are delving into optical character recognition -- OCR. Although good results have been achieved, the problem is not completely solved despite decades of work. You have a lot of reading to do. I wish you luck. You might find software at http://www.simpleocr.com/ interesting. I doubt that this is a task for Matlab. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
