error in linking fftw
Started by mayur.sarode June 4, 2009
I am not able to link fftw3 library with my c program
c code:
#include<stdio.h>
#include<fftw3.h>
int main()
int i=0;
fftw_complex *in,*out;
fftw_plan p;
fftw_malloc ;
int N=100;
in=(fft_complex*)fft_malloc(sizeof(fftw_complex) * N);
out=(fft_complex*)fft_malloc(sizeof(fftw_complex) * N);
for(i=0;i <N;i++)
   *(in+i)=i;
p = fftw_plan_dft_r2c_1d(N, in, out,FFT_PRESERVE_INPUT);
fftw_execute(p);
fftw_destroy_plan(p);
fftw_free(in);
fftw_free(out);
for(i=0;i<N;i++)
printf("%d \n",out[i]);
return(0);
 gcc -lfftw3 -o fft fft.c -L/usr/local/lib
output
fft.c: In function &lsquo;main&rsquo;:
fft.c:15: error: &lsquo;fft_complex&rsquo; undeclared (first use in this
function)
fft.c:15: error: (Each undeclared identifier is reported only once
fft.c:15: error: for each function it appears in.)
fft.c:15: error: expected expression before &lsquo;)&rsquo; token
fft.c:16: error: expected expression before &lsquo;)&rsquo; token
fft.c:18: error: incompatible types in assignment
fft.c:19: error: &lsquo;FFT_PRESERVE_INPUT&rsquo; undeclared (first use in this
function)
fft.c:19: warning: passing argument 2 of &lsquo;fftw_plan_dft_r2c_1d&rsquo; from
incompatible pointer type
CXan anyone help me out
mayur.sarode wrote:
> I am not able to link fftw3 library with my c program > c code: > > #include<stdio.h> > #include<fftw3.h> > int main() > { > int i=0; > fftw_complex *in,*out; > fftw_plan p; > fftw_malloc ; > int N=100; > in=(fft_complex*)fft_malloc(sizeof(fftw_complex) * N); > out=(fft_complex*)fft_malloc(sizeof(fftw_complex) * N); > for(i=0;i <N;i++) > *(in+i)=i; > p = fftw_plan_dft_r2c_1d(N, in, out,FFT_PRESERVE_INPUT); > fftw_execute(p); > fftw_destroy_plan(p); > fftw_free(in); > fftw_free(out); > for(i=0;i<N;i++) > printf("%d \n",out[i]); > return(0); > } > > gcc -lfftw3 -o fft fft.c -L/usr/local/lib > > > output > fft.c: In function &lsquo;main&rsquo;: > fft.c:15: error: &lsquo;fft_complex&rsquo; undeclared (first use in this > function) > fft.c:15: error: (Each undeclared identifier is reported only once > fft.c:15: error: for each function it appears in.) > fft.c:15: error: expected expression before &lsquo;)&rsquo; token > fft.c:16: error: expected expression before &lsquo;)&rsquo; token > fft.c:18: error: incompatible types in assignment > fft.c:19: error: &lsquo;FFT_PRESERVE_INPUT&rsquo; undeclared (first use in this > function) > fft.c:19: warning: passing argument 2 of &lsquo;fftw_plan_dft_r2c_1d&rsquo; from > incompatible pointer type > > CXan anyone help me out > > >
gcc -lfftw3 -o fft fft.c -I/usr/local/include -L/usr/local/lib Paul
Paul Russell wrote:
> mayur.sarode wrote: >> I am not able to link fftw3 library with my c program >> c code: >> >> #include<stdio.h> >> #include<fftw3.h> >> int main() >> { >> int i=0; >> fftw_complex *in,*out; >> fftw_plan p; >> fftw_malloc ; >> int N=100; >> in=(fft_complex*)fft_malloc(sizeof(fftw_complex) * N); >> out=(fft_complex*)fft_malloc(sizeof(fftw_complex) * N); >> for(i=0;i <N;i++) >> *(in+i)=i; >> p = fftw_plan_dft_r2c_1d(N, in, out,FFT_PRESERVE_INPUT); >> fftw_execute(p); >> fftw_destroy_plan(p); >> fftw_free(in); >> fftw_free(out); >> for(i=0;i<N;i++) >> printf("%d \n",out[i]); >> return(0); >> } >> >> gcc -lfftw3 -o fft fft.c -L/usr/local/lib >> >> >> output >> fft.c: In function &lsquo;main&rsquo;: >> fft.c:15: error: &lsquo;fft_complex&rsquo; undeclared (first use in this >> function) >> fft.c:15: error: (Each undeclared identifier is reported only once >> fft.c:15: error: for each function it appears in.) >> fft.c:15: error: expected expression before &lsquo;)&rsquo; token >> fft.c:16: error: expected expression before &lsquo;)&rsquo; token >> fft.c:18: error: incompatible types in assignment >> fft.c:19: error: &lsquo;FFT_PRESERVE_INPUT&rsquo; undeclared (first use in this >> function) >> fft.c:19: warning: passing argument 2 of &lsquo;fftw_plan_dft_r2c_1d&rsquo; from >> incompatible pointer type >> >> CXan anyone help me out >> >> >> > > gcc -lfftw3 -o fft fft.c -I/usr/local/include -L/usr/local/lib > > Paul
Also note that there are numerous typos, e.g. it should be "fftw_malloc", "fftw_complex" and "FFTW_PRESERVE_INPUT". Paul
