Rune Allnor wrote:> On 13 Jun, 01:41, Tim Wescott <t...@seemywebsite.com> wrote: > >> No matter what you do you'll spend ten times >>more on the non-processor part of your BOM -- why cut corners on the >>processing? > > > BOM? > > RuneBill Of Material
Sample rate selection for digital control project
Started by ●June 9, 2009
Reply by ●June 13, 20092009-06-13
On Jun 12, 7:41�pm, Tim Wescott <t...@seemywebsite.com> wrote:> > Good 16-bit processors just aren't that much more expensive than 8-bit > ones in hobbyist quantities; even the 32-bit ARM chips from Luminary/TI > aren't _that_ much more. �No matter what you do you'll spend ten times > more on the non-processor part of your BOM -- why cut corners on the > processing? > > --www.wescottdesign.comI don't disagree. My partner is the EE/board designer/microcontroller guy, and he has experience with the AVR, so that's the first board he made (I guess I'm the Aero E/controls/theory guy). I tried to talk him out of it. He did like the Luminary Board, so that may be our next board. To be fair, there are several examples of hobby and university research/lab quadrotors out there that make use of 8-bit AVRs or PICs as the main controller (but they are pretty much r/c only - not autonomous). - Roy
On Jun 13, 1:44�am, pnachtwey <pnacht...@gmail.com> wrote:> > I would use a 32 bit CPU woth good debugging tools. �The development/ > debugging tools will cost more than the 8 bit or 32 bit micro > controller > > Peter Nachtwey > .The toolset was one of my partner's concerns. There seem to be good free development tools out there for the 8-bit micros (AVR in particular). There seem to be free tools for at least some 32-bit CPUs, but we don't have any experience. Does anyone have specific recommendations for 32-bit chips or boards? As I said earlier, the Luminary (now TI) seemed reasonable and the ARM appears to have free tools available. This is the board my partner found: http://www.luminarymicro.com/products/lm3s1968_evaluation_kits.html Thanks Roy
On Sat, 13 Jun 2009 11:56:35 -0700, Roy wrote:> On Jun 12, 7:41 pm, Tim Wescott <t...@seemywebsite.com> wrote: > > >> Good 16-bit processors just aren't that much more expensive than 8-bit >> ones in hobbyist quantities; even the 32-bit ARM chips from Luminary/TI >> aren't _that_ much more. No matter what you do you'll spend ten times >> more on the non-processor part of your BOM -- why cut corners on the >> processing? >> >> --www.wescottdesign.com > > I don't disagree. My partner is the EE/board designer/microcontroller > guy, and he has experience with the AVR, so that's the first board he > made (I guess I'm the Aero E/controls/theory guy). I tried to talk him > out of it. He did like the Luminary Board, so that may be our next > board. To be fair, there are several examples of hobby and university > research/lab quadrotors out there that make use of 8-bit AVRs or PICs as > the main controller (but they are pretty much r/c only - not > autonomous). > > - RoyI've used the Luminary board, and like it. If you're working in a Windows environment it'll just fire up and go (if you're a crazed Linux nut, you'll find less support, but it's possible to use it -- in theory at least). My personal bias when doing low volume stuff is to go with a hot processor. That way you can spend your time concentrating on the underlying problem, instead of constantly working to shoehorn the application into the processor. Later, if power/price/space concerns motivate you, you can go to a smaller processor. -- http://www.wescottdesign.com
On Jun 8, 8:30 pm, Roy <brewer....@gmail.com> wrote:> Hi, > > I am trying to determine the sample rate for a new hobby project > (digital control of a quad-rotor flying robot). The few references > I've found seem to suggest there are no rigorous calculations > available to decide the sample rate. They suggested the following > "rules of thumb": > > * Use ten times the rate suggested by Shannon’s sampling theorem. > * Make sure that there are four to ten samples per rise time of the > closed loop system. > * Make sure that there are 15 to 45 samples per period of the > oscillating closed loop system. > * Sampling frequency should be 10 to 30 times the bandwidth. > * Choose ωcTs to be 0.15 to 0.5, where ωc is the crossover frequency > and Ts is the sampling time. > * Choose the sampling time in such a manner that the decrease in phase > margin of the discretized system is not more than 5 to 15 degrees of > the margin in the continuous time system. > > I don't have an actual vehicle, nor do I have a model (yet). I've seen > data on the web that indicates the (open loop) step response of rotor > thrust has a rise time of 0.1 sec, which implies a bandwidth of 3.5 Hz > or so (I'm presuming the inertia of the frame will only increase the > rise time). So it seems that I could get away with 35-100 Hz sampling > rate (per the 4th rule) > > Does anyone have any better rules or calculation procedure? What if > the un-augmented system is unstable? Are there rules of thumb or > calculations to select the closed loop bandwidth? > > Thanks in advance, > RoyI've worked on various military and commercial flight control systems and 10ms update rates are common, I think 20ms was the slowest. The fastest input sensors (usually the position sensors) have about a 25Hz (-3db) bandwidth.
Reply by ●June 14, 20092009-06-14
On Jun 13, 10:52�pm, joepierson <gkicomput...@yahoo.com> wrote:> > I've worked on various military and commercial flight control systems > and 10ms update rates are common, I think 20ms was the slowest. The > fastest input sensors (usually the position sensors) have about a 25Hz > (-3db) bandwidth.I've worked on a few military digital FCS as well. Ours were multi- rate systems with control law code running between 20 and 50 Hz. But I'd expect the (~1 kg, ~1 m) quadrotor to have a lot faster dynamics than full size 10K - 50K+ lbs vehicles - Roy
On Jun 14, 8:39 am, Roy <brewer....@gmail.com> wrote:> On Jun 13, 10:52 pm, joepierson <gkicomput...@yahoo.com> wrote: > > > > > I've worked on various military and commercial flight control systems > > and 10ms update rates are common, I think 20ms was the slowest. The > > fastest input sensors (usually the position sensors) have about a 25Hz > > (-3db) bandwidth. > > I've worked on a few military digital FCS as well. Ours were multi- > rate systems with control law code running between 20 and 50 Hz. But > I'd expect the (~1 kg, ~1 m) quadrotor to have a lot faster dynamics > than full size 10K - 50K+ lbs vehicles > > - Royyou would be wrong because the 10K+ vehicles are doing Mach 3. Our large transport aircraft, fighter aircraft and 10 pound UAVs all use around the same update rate. In all cases you are fundamentally limited by your input sensors and actuator response, if you are using standard RC servo's your talking 50ms response time (no load), so if you can't control your vehicle at those rates it will never work by simply increasing the update rate to .1 ms rate cause the servo's won't respond.
Reply by ●June 15, 20092009-06-15
On Jun 14, 12:54�pm, joepierson <gkicomput...@yahoo.com> wrote:> On Jun 14, 8:39 am, Roy <brewer....@gmail.com> wrote: > > > On Jun 13, 10:52 pm, joepierson <gkicomput...@yahoo.com> wrote: > > > > I've worked on various military and commercial flight control systems > > > and 10ms update rates are common, I think 20ms was the slowest. The > > > fastest input sensors (usually the position sensors) have about a 25Hz > > > (-3db) bandwidth. > > > I've worked on a few military digital FCS as well. Ours were multi- > > rate systems with control law code running between 20 and 50 Hz. But > > I'd expect the (~1 kg, ~1 m) quadrotor to have a lot faster dynamics > > than full size �10K - 50K+ lbs vehicles > > > - Roy > > you would be wrong because the 10K+ vehicles are doing Mach 3. Our > large transport aircraft, fighter aircraft and 10 pound UAVs all use > around the same update rate. In all cases you are fundamentally > limited by your input sensors and actuator response, if you are using > standard RC servo's your talking 50ms response time (no load), so if > you can't control your vehicle at those rates it will never work by > simply increasing the update rate to .1 ms rate cause the servo's > won't respond.I was referring to the vehicles I was working on (subsonic rotorcraft). I wonder if we don't work for or with the same company - how many have that broad a product line these days? I also wonder if there's something about the design of the flight control computer that makes them all run at about the same rate (as opposed to sensor & actuator characteristics)? I'm sure you'll correct me if I'm wrong, but I can't see the 10-lb UAV having the same sensors and actuators as the transport and fighter. If you look back in the thread you'll see that I'm not using servos, but direct DC motor control. my initial thought was to base the iteration rate on the bandwidth of the motor / rotor, but Tim reminded me that wrapping an inner loop around the motor could be used to increase their b/w. - Roy
On Jun 8, 8:30�pm, Roy <brewer....@gmail.com> wrote: This was done with a Parallax Propeller Chip. That is considerably more processing power than an 8 bit micro controller. http://www.youtube.com/watch?v=4IZ5eAeneWk I doubt that sample time is an issue with the Propeller chip. As pointed out above there are probably other devices that are much more limiting when it comes to response. Peter Nachtwey
On Jun 14, 9:54�am, joepierson <gkicomput...@yahoo.com> wrote:> On Jun 14, 8:39 am, Roy <brewer....@gmail.com> wrote: > > > On Jun 13, 10:52 pm, joepierson <gkicomput...@yahoo.com> wrote: > > > > I've worked on various military and commercial flight control systems > > > and 10ms update rates are common, I think 20ms was the slowest. The > > > fastest input sensors (usually the position sensors) have about a 25Hz > > > (-3db) bandwidth. > > > I've worked on a few military digital FCS as well. Ours were multi- > > rate systems with control law code running between 20 and 50 Hz. But > > I'd expect the (~1 kg, ~1 m) quadrotor to have a lot faster dynamics > > than full size �10K - 50K+ lbs vehicles > > > - Roy > > you would be wrong because the 10K+ vehicles are doing Mach 3. Our > large transport aircraft, fighter aircraft and 10 pound UAVs all use > around the same update rate. In all cases you are fundamentally > limited by your input sensors and actuator response, if you are using > standard RC servo's your talking 50ms response time (no load), so if > you can't control your vehicle at those rates it will never work by > simply increasing the update rate to .1 ms rate cause the servo's > won't respond.A flight control loop running at 50-100 Hz will work not work if you are using the "wrong type" of sensors, i.e., the "wrong type" of gyros and accelerometers. The "right type" of sensors are integrating-type sensors, whose output is delta-V for accelerometers (i.e, not acceleration) and delta-theta for gyros (i.e., not rate). These sensors work by maintain a mass (or spinning mass) at some null position using an internal control loop. The output of the sensor is the control signal needed to maintain the null position. With such a sensor, low rates for the control loop are possible, since the sensor itself has integrated out all the high frequency details that would otherwise cause problems (Nyquist etc). Low-cost MEMS sensors (of the type that probably would be used by the OP) are the "wrong type" of sensor. These sensors do not have an internal control loop that maintains the mass at a null position. Rather, these sensors allow the mass to displace, and output an open- loop signal representing the displacement. As such, they measure instantaneous values of rate and acceleration, and do not integrate to delta-theta and delta-V. In addition, since the masses are typically very small and undamped, the instantaneous values of rate and acceleration are particularly prone to high frequency content, such as actual content caused by vehicle vibration and the like, and non-real content caused by electrical noise and the like. As such, these instantaneous measurements come with all the downsides of digitally- sampled systems (again, Nyquist etc), multiplied by actual vehicle dynamics such as high-frequency coning and sculling motions. And as a result, a much higher rate is needed for a flight control loop that uses such a sensor. In past work, we have used a 600 Hz loop frequency for the flight control loop of a system that uses such MEMS-style sensors. We in addition ran a strap-down navigation calculation using quaternions that were updated crudely at the 600Hz rate, but which were normalized and used at a much lower 100 Hz rate.
