Complex signal processing in Spread Spectrum
Started by johnlovestohate June 18, 2009
Dear All,
I have a question about processing of complex signal in demodulating
spread spectrum signals. I have a signal that is spread using a PN
sequence. This received signal is at baseband and is complex i.e. The
received samples are in complex format at baseband. I want to multiply this
received signal at baseband the PN sequence so as to strip the modulated
signal of the PN sequence. How can I do this on a complex baseband signal?
If it wasn't a complex signal a simple multiplication would suffice but,
what about complex? Any thoughts?
Thanks,
John
On Jun 18, 10:26&#4294967295;am, "johnlovestohate" <murtuzaali...@gmail.com>
wrote:
> Dear All, > I have a question about processing of complex signal in demodulating > spread spectrum signals. I have a signal that is spread using a PN > sequence. This received signal is at baseband and is complex i.e. The > received samples are in complex format at baseband. I want to multiply this > received signal at baseband the PN sequence so as to strip the modulated > signal of the PN sequence. How can I do this on a complex baseband signal? > If it wasn't a complex signal a simple multiplication would suffice but, > what about complex? Any thoughts? > > Thanks, > John
Is your spreading sequence real-valued or complex-valued? If it's real-valued, then simply do complex multiplies. If your spreading sequence is complex- valued, then you need to do complex correlation, which is convolution with a time-reversed, complex-conjugated version of the original sequence. Hope this helps, Julius
On Jun 18, 11:52&#4294967295;am, julius <juli...@gmail.com> wrote:
> On Jun 18, 10:26&#4294967295;am, "johnlovestohate" <murtuzaali...@gmail.com> > wrote: > > > Dear All, > > I have a question about processing of complex signal in demodulating > > spread spectrum signals. I have a signal that is spread using a PN > > sequence. This received signal is at baseband and is complex i.e. The > > received samples are in complex format at baseband. I want to multiply this > > received signal at baseband the PN sequence so as to strip the modulated > > signal of the PN sequence. How can I do this on a complex baseband signal? > > If it wasn't a complex signal a simple multiplication would suffice but, > > what about complex? Any thoughts? > > > Thanks, > > John > > Is your spreading sequence real-valued or complex-valued? &#4294967295;If it's > real-valued, > then simply do complex multiplies. &#4294967295;If your spreading sequence is > complex- > valued, then you need to do complex correlation, which is convolution > with > a time-reversed, complex-conjugated version of the original > sequence. > > Hope this helps, > Julius
Think of it as a convolution (aka FIR filter) of your spread data with the time-reversed, conjugated spreading sequence. If the spreading sequence is real, then just do real multiplies on both I and Q of your data. If it's complex, then you need full complex multiplies. This can be done quite efficiently with FFTs. John
