a question about the effect of channel estimation and equalization in ofdm
Started by MrJiang June 24, 2009
in OFDM systems, the LS channel estimation result should be
H'=P'/P
if we compensate the received data symbols with one tap scheme, the
equalization result should be
D''=D'/H' = P*D'/P';
one the right of the above equation, D'/P' looks like the differential
decoding result
so the coherent demodulation with LS estimation and onetap equalization
sees like the differential demodulation.
but why the coherent modulation is so popular in OFDM system.
On Jun 24, 9:39=A0am, "MrJiang" <misterji...@126.com> wrote:
> in OFDM systems, the LS channel estimation result should be > > H'=3DP'/P > > if we compensate the received data symbols with one tap scheme, the > equalization result should be > > D''=3DD'/H' =3D P*D'/P'; > > one the right of the above equation, D'/P' looks like the differential > decoding result > > so the coherent demodulation with LS estimation and onetap equalization > sees like the differential demodulation. > > but why the coherent modulation is so popular in OFDM system.
It's because if you really think about it, A=3DA'/B, so therefore B''=3DB'/ C.
>On Jun 24, 9:39=A0am, "MrJiang" <misterji...@126.com> wrote: >> in OFDM systems, the LS channel estimation result should be >> >> H'=3DP'/P >> >> if we compensate the received data symbols with one tap scheme, the >> equalization result should be >> >> D''=3DD'/H' =3D P*D'/P'; >> >> one the right of the above equation, D'/P' looks like the differential >> decoding result >> >> so the coherent demodulation with LS estimation and onetap
equalization
>> sees like the differential demodulation. >> >> but why the coherent modulation is so popular in OFDM system. > >It's because if you really think about it, A=3DA'/B, so therefore
B''=3DB'/
>C. >
sorry, I can't get your meaning. could you explain it?
equalization
B''=3DB'/
>C. >
>>On Jun 24, 9:39=A0am, "MrJiang" <misterji...@126.com> wrote: >>> in OFDM systems, the LS channel estimation result should be >>> >>> H'=3DP'/P >>> >>> if we compensate the received data symbols with one tap scheme, the >>> equalization result should be >>> >>> D''=3DD'/H' =3D P*D'/P'; >>> >>> one the right of the above equation, D'/P' looks like the
differential
>>> decoding result >>> >>> so the coherent demodulation with LS estimation and onetap >equalization >>> sees like the differential demodulation. >>> >>> but why the coherent modulation is so popular in OFDM system. >> >>It's because if you really think about it, A=3DA'/B, so therefore >B''=3DB'/ >>C. >> > >sorry, I can't get your meaning. >could you explain it? >
Please specify what H, D and P are.
