Me wrote:> "Tim Wescott" <tim@seemywebsite.com> wrote in message > news:CcKdnbtkBvUWVsHXnZ2dnUVZ_gJi4p2d@web-ster.com... >> Note that by carefully defining the sampling process you can derive the z >> transform from the Laplace transform in a way that is exact. The usual >> derivation defines sampling as multiplication by a series of impulses of >> infinite height and finite area; this gives everyone gas pains but is >> generally a nice way of thinking of it. You can avoid impulses at the >> expense of convenience (but not rigor, as far as I can tell). > > There's no need for those "gas pains" ... > > 1. The transform for the Unit Impulse is derived from a limiting process. > > 2. A practical limiting process for us is the Nyquist criterion. > > 3. According to Nyquist, once the sampling pulses have become sufficiently > frequent to ensure that the amplitude-modulated sidebands are not aliasing > with each other, no further advantage (OK, yeah, low pass filtering becomes > easier) is gained by increasing the frequency of the sampling pulses, and, > thereby > reducing their width. > > 4. To make life easier for ourselves, we like to use a previously calculated > transform > in our analysis, that of the Unit Impulse. > > 5. However, because of the stopping-short in our limiting process, our > sampling > signal is not a train of Unit Impulses, but a train of T*d(t). > > Simple to derive ..... a Unit Impulse is T* (1/T), but our sampling pulses > are > T * 1 ie, 1 volt. So to convert Unit Impulses so that they can represent our > sampling pulses, we must multiply by T > > 6. Most texts omit this crucial facor of T, the sampling interval, and so > bring about > the "gas pains" .... (Cue: Airry r. been (sp?)) > > 7. Bristow-Johnson has a spiel on the reconstruction process, and finds it > necessary > to introduce this T factor to make things work. > > 8. If you introduce it at the sampling stage, then all is sweetness and > light. > > 9. Conclusion. Change all the textbooks to describe sampling as a train of > T*d(t) and > not as a train of d(t), then the gas pains disappear, and peace reigns > throughout the realm. > >Hi Me, The problem with representing the sampled signal as a train of pulses of duration T second is that this introduces sin(x)/x distortion of the time-domain response, which is a complication we don't need. On another point: I think the 'gas pains' that were mentioned come about as soon as we start talking about a pulse that has both an infinite amplitude and zero duration. What seems to be overlooked is that it is not necesary to picture the Dirac delta functon as having an infinite amplitude, and out of all the specific instances of this function that you may imagine, the infinite-amplitude example is the least useful. The only requirement for a delta function is that its integral is exactly unity over any interval that you choose, however short. If you pick an interval of exactly zero that introduces the infinite-amplitude problem, so why do it? Actually, I argue that an 'infinite-amplitude delta function' is not even possible. At first sight a unity result for the integration would seem to be allowable mathematically, because after all, infinity times zero is indeterminate and might as well be zero as anything else :=). The problem with this is that integrating a function over an interval of exactly zero can never generate a value of unity. This is because when we evaluate the definite integral this involves subtracting identical values, giving a result that must always be zero, even when we subtract infinity from infinity. In summary, we need to forget the infinite-amplitude stuff. It is neither useful nor valid. Regards, John
Differences between laplace transform, z transform and fourier transform
Started by ●July 14, 2009
Reply by ●July 16, 20092009-07-16
"John Monro" <johnmonro@optusnet.com.au> wrote in message news:4a5e9ccb$0$23633$afc38c87@news.optusnet.com.au...> The problem with representing the sampled signal as a train of pulses of > duration T second is that this introduces sin(x)/x distortion of the > time-domain response, which is a complication we don't need.> The only requirement for a delta function is that its integral is exactly > unity over any interval that you choose, however short. If you pick an > interval of exactly zero that introduces the infinite-amplitude problem, > so why do it?You seem to be disagreeing with yourself in the two paragraphs quoted above. The sin(x)/x distortion is introduced anyway as part of the standard reconstruction process.
Me wrote:> "John Monro" <johnmonro@optusnet.com.au> wrote in message > news:4a5e9ccb$0$23633$afc38c87@news.optusnet.com.au... >> The problem with representing the sampled signal as a train of pulses of >> duration T second is that this introduces sin(x)/x distortion of the >> time-domain response, which is a complication we don't need. > >> The only requirement for a delta function is that its integral is exactly >> unity over any interval that you choose, however short. If you pick an >> interval of exactly zero that introduces the infinite-amplitude problem, >> so why do it? > > You seem to be disagreeing with yourself in the two paragraphs > quoted above. > > The sin(x)/x distortion is introduced anyway as part of the standard > reconstruction process. > > >There would be a disagreement if there were only two choices: 1. Represent the signal as a series of pulses of duration T sec. 2. Represent the signal as a series of infinite-amplitude, zero-width pulses. In fact there is a third choice. It seems I failed to make it clear that I think it is useful to represent the sampled signal as a series of pulses of finite ampilitude and non-zero duration. The values of the amplitude and duration are not defined (and don't need to be defined). Only the integral over a very short period of time is defined. (I claim no originality for this thought :=). Regarding the sin(x)/x distortion, simple reconstruction by holding each sample for one full sample-period does indeed give the same sin(x)/x distortion as the scheme you are siggesting, but the distortion occurs at the last step in the reproduction process and we don't have to worry about distortion before then. If we use the representation you suggest, we either have to agree to ignore the distortion that is (conceptually) introduced right at the sampling stage, or we include the distortion, which messes up the representation. Neither seems very satisfactory to me. Regards, John
Sorry, I was misled by your original reply. Thinking further on the matter, there is no sin(x)/x anomaly, because what I proposed is just a scaling of the amplitude by a factor of T (or 1/T depending which way you look at it), but with no change of shape. I was /am positing a reperesentation of scaled Unit Impulses. The issue of integration is not relevant. Even if sin(x)/x were involved, then in the linear systems which we discuss, it does not matter what the ordre of analysis is, whether the sin(x)/x is considered at the beginning or at the end. In my approach, it is considered at the end because it is not introduced at the start. Sure, we start off with a sampling pulse of the form U(nT) - U((n+1)T) in which sin(x)/x might be relevant, but by the simple conversion to T.d(t) it is definitely not relevant. NO. If youuse the representation that I suggest you do NOT have to consider the distortion because it ain't there. "John Monro" <johnmonro@optusnet.com.au> wrote in message news:4a5edbea$0$4046$afc38c87@news.optusnet.com.au...>> > There would be a disagreement if there were only two choices: > 1. Represent the signal as a series of pulses of duration T sec. > 2. Represent the signal as a series of infinite-amplitude, zero-width > pulses. > > In fact there is a third choice. It seems I failed to make it clear that I > think it is useful to represent the sampled signal as a series of pulses > of finite ampilitude and non-zero duration. The values of the amplitude > and duration are not defined (and don't need to be defined). Only the > integral over a very short period of time is defined. (I claim no > originality for this thought :=). > > Regarding the sin(x)/x distortion, simple reconstruction by holding each > sample for one full sample-period does indeed give the same sin(x)/x > distortion as the scheme you are siggesting, but the distortion occurs at > the last step in the reproduction process and we don't have to worry about > distortion before then. > > If we use the representation you suggest, we either have to agree to > ignore the distortion that is (conceptually) introduced right at the > sampling stage, or we include the distortion, which messes up the > representation. Neither seems very satisfactory to me. > > Regards, > John > >
I thought you were proposing that the width of each pulse should be T. Maybe I misunderstood you. I am not really sure now what you mean by T.d(t) but maybe I should ponder a bit further. Regards, John Me wrote:> Sorry, I was misled by your original reply. Thinking further on the > matter, there is no sin(x)/x anomaly, because what I proposed is > just a scaling of the amplitude by a factor of T (or 1/T depending which > way you look at it), but with no change of shape. > > I was /am positing a reperesentation of scaled Unit Impulses. > > The issue of integration is not relevant. > > Even if sin(x)/x were involved, then in the linear systems which we > discuss, it does not matter what the ordre of analysis is, whether > the sin(x)/x is considered at the beginning or at the end. > > In my approach, it is considered at the end because it is not introduced > at the start. Sure, we start off with a sampling pulse of the form > U(nT) - U((n+1)T) in which sin(x)/x might be relevant, but by the > simple conversion to T.d(t) it is definitely not relevant. > > NO. If youuse the representation that I suggest you do NOT have > to consider the distortion because it ain't there. > > > > "John Monro" <johnmonro@optusnet.com.au> wrote in message > news:4a5edbea$0$4046$afc38c87@news.optusnet.com.au... >> There would be a disagreement if there were only two choices: >> 1. Represent the signal as a series of pulses of duration T sec. >> 2. Represent the signal as a series of infinite-amplitude, zero-width >> pulses. >> >> In fact there is a third choice. It seems I failed to make it clear that I >> think it is useful to represent the sampled signal as a series of pulses >> of finite ampilitude and non-zero duration. The values of the amplitude >> and duration are not defined (and don't need to be defined). Only the >> integral over a very short period of time is defined. (I claim no >> originality for this thought :=). >> >> Regarding the sin(x)/x distortion, simple reconstruction by holding each >> sample for one full sample-period does indeed give the same sin(x)/x >> distortion as the scheme you are siggesting, but the distortion occurs at >> the last step in the reproduction process and we don't have to worry about >> distortion before then. >> >> If we use the representation you suggest, we either have to agree to >> ignore the distortion that is (conceptually) introduced right at the >> sampling stage, or we include the distortion, which messes up the >> representation. Neither seems very satisfactory to me. >> >> Regards, >> John >> >> > >
Reply by ●July 17, 20092009-07-17
On Jul 15, 2:50�am, "Me" <inva...@invalid.invalid> wrote:> "Tim Wescott" <t...@seemywebsite.com> wrote in message > > news:CcKdnbtkBvUWVsHXnZ2dnUVZ_gJi4p2d@web-ster.com... > > > Note that by carefully defining the sampling process you can derive the z > > transform from the Laplace transformin a way that is exact. �The usual > > derivation defines sampling as multiplication by a series of impulses of > > infinite height and finite area; this gives everyone gas pains but is > > generally a nice way of thinking of it. �You can avoid impulses at the > > expense of convenience (but not rigor, as far as I can tell). > > There's no need for those "gas pains" ... > > 1. The transform for the Unit Impulse is derived from a limiting process. > > 2. A practical limiting process for us is the Nyquist criterion. > > 3. According to Nyquist, once the sampling pulses have become sufficiently > frequent to ensure that the amplitude-modulated sidebands are not aliasing > with each other, no further advantage (OK, yeah, low pass filtering becomes > easier) is gained by increasing the frequency of the sampling pulses, and, > thereby > reducing their width. > > 4. To make life easier for ourselves, we like to use a previously calculated > transform in our analysis, that of the Unit Impulse. > > 5. However, because of the stopping-short in our limiting process, our > sampling signal is not a train of Unit Impulses, but a train of T*d(t). > > Simple to derive ..... a Unit Impulse is T* (1/T), but our sampling pulses > are T * 1 ie, 1 volt. So to convert Unit Impulses so that they can represent our > sampling pulses, we must multiply by T > > 6. Most texts omit this crucial facor of T, the sampling interval, and so > bring about the "gas pains" .... (Cue: Airry r. been (sp?)) > > 7. Bristow-Johnson has a spiel on the reconstruction process, and finds it > necessary to introduce this T factor to make things work. > > 8. If you introduce it at the sampling stage, then all is sweetness and > light. > > 9. Conclusion. Change all the textbooks to describe sampling as a train of > T*d(t) and not as a train of d(t), then the gas pains disappear, and peace reigns > throughout the realm.essentially, the Laplace Transform of the *unscaled* (no leading T) sampled signal: SUM{ x(t) * delta(t - n*T) } (over all integer n) which is SUM{ x[n] * delta(t - n*T) } (where x[n] is x(n*T) ) is the same as the Z Transform. the leading T is necessary, in my opinion, only to understand how to properly do reconstruction if you are modeling reconstruction to do sample rate conversion or interpolation. that is where this sinc function (or windowed-sinc) comes from. but, to see where the Z transform comes from, leave the T factor out (and put it back in when you do ideal reconstruction, that what i intended to be what my spiel to be about). r b-j
"robert bristow-johnson" <rbj@audioimagination.com> wrote in message news:3be4133b-84f8-478b-94db-1a50df9d4a90@n4g2000vba.googlegroups.com...> essentially, the Laplace Transform of the *unscaled* (no leading T) > sampled signal:'Fraid not, old chap. The sampled signal has an inherent factor of T as explained. Else, if you model the sampling circuitry that originates the signals with which you deal, where do the impulses come from?
Reply by ●July 18, 20092009-07-18
On Jul 17, 10:28�am, "Me" <inva...@invalid.invalid> wrote:> > 'Fraid not, old chap. > > The sampled signal has an inherent factor of T as explained. > > Else, if you model the sampling circuitry that originates the > signals with which you deal, where do the impulses come from?i dunno what you think i meant, but the words i forgot to say are: the Z Transform is ...> > essentially, the Laplace Transform of the *unscaled* (no leading T) > > sampled signal... with the substitution of z for for e^(sT). the Z transform operates on the discrete samples, x[n], and doesn't have T anywhere in it. it is as true for signals sampled at 48 kHz as it is for 48 MHz. it's only an operator on x[n]. but, if you attach those x[n] to a bunch of dirac deltas spaced by some given T (but *not* scaled in amplitude by T like you would for reconstruction to x (t)), the Laplace transform of that evaluated at some s is the same value of the Z transform of x[n] evaluated at z = e^(sT). that's what i meant by "no leading T". sometimes i forget to say everything i mean, even when i spiel. r b-j
Reply by ●April 26, 20182018-04-26
On Tuesday, July 14, 2009 at 5:28:13 PM UTC+5:30, somanath17 wrote:> Hi All, > > I have studied three diff kinds of transforms, The laplace transform, the > z transform and the fourier transform. As per my understanding the usage of > the above transforms are: > Laplace Transforms are used primarily in continuous signal studies, more > so in realizing the analog circuit equivalent and is widely used in the > study of transient behaviors of systems. > > The Z transform is the digital equivalent of a Laplace transform and is > used for steady state analysis and is used to realize the digital circuits > for digital systems. > > The Fourier transform is a particular case of z-transform, i.e z-transform > evaluated on a unit circle and is also used in digital signals and is more > so used to in spectrum analysis and calculating the energy density as > Fourier transforms always result in even signals and are used for > calculating the energy of the signal. > > Is my understanding correct. What more technical differences exist and > where do all these differences find their application. Would be really > helpful if someone can give an understanding of this and provide links > where i can look up for the same. > > Thanks, > SomaRead this For Solution http://readitdud.blogspot.com/2018/04/difference-between-laplace-transform.html
On 4/26/2018 8:03 AM, ccrs336@gmail.com wrote:> On Tuesday, July 14, 2009 at 5:28:13 PM UTC+5:30, somanath17 wrote: >> Hi All, >> >> I have studied three diff kinds of transforms, The laplace transform, the >> z transform and the fourier transform. As per my understanding the usage of >> the above transforms are: >> Laplace Transforms are used primarily in continuous signal studies, more >> so in realizing the analog circuit equivalent and is widely used in the >> study of transient behaviors of systems. >> >> The Z transform is the digital equivalent of a Laplace transform and is >> used for steady state analysis and is used to realize the digital circuits >> for digital systems. >> >> The Fourier transform is a particular case of z-transform, i.e z-transform >> evaluated on a unit circle and is also used in digital signals and is more >> so used to in spectrum analysis and calculating the energy density as >> Fourier transforms always result in even signals and are used for >> calculating the energy of the signal. >> >> Is my understanding correct. What more technical differences exist and >> where do all these differences find their application. Would be really >> helpful if someone can give an understanding of this and provide links >> where i can look up for the same. >> >> Thanks, >> Soma > > Read this For Solution http://readitdud.blogspot.com/2018/04/difference-between-laplace-transform.html >Well, Fourier transform is a special case of the Laplace transform. The Digital Fourier Transform (DFT usually implemented as the Fast Fourier Transform - FFT) bears the same relation to the Z transform as the Fourier transfrm bears to the Laplace transform. Best wishes, --Phil -- Best wishes, --Phil pomartel At Comcast(ignore_this) dot net
