hi I've a doubt whether there is any possibility to implement HHT on hardware.Whether it can be implemented on FPGA.Thanks in advance
HILBERT HUANG TRANSFORM
Started by ●July 22, 2009
Reply by ●July 22, 20092009-07-22
On Jul 22, 10:45�am, "NIRMAY" <vidhusai...@yahoo.co.in> wrote:> hi > I've a doubt whether there is any possibility to implement HHT on > hardware.Whether it can be implemented on FPGA.Thanks in advanceWell of course the answer is yes it is possible. The HHT is a multistep process where the 1st step is iterative. This will be a large effort on coding this into an FPGA. I would suggest you get this working well in software before you look at doing it in hardware. I would thing your FPGA will need to handle a chunk of ram for holding the sifting results. You will need a bunch of test vectors to certify your hardware is working along the way. Good luck! Clay
Reply by ●July 26, 20092009-07-26
>On Jul 22, 10:45=A0am, "NIRMAY" <vidhusai...@yahoo.co.in> wrote: >> hi >> I've a doubt whether there is any possibility to implement HHT on >> hardware.Whether it can be implemented on FPGA.Thanks in advance > >Well of course the answer is yes it is possible. The HHT is a >multistep process where the 1st step is iterative. This will be a >large effort on coding this into an FPGA. I would suggest you get this >working well in software before you look at doing it in hardware. I >would thing your FPGA will need to handle a chunk of ram for holding >the sifting results. You will need a bunch of test vectors to certify >your hardware is working along the way. > >Good luck! > >Clay >thank's a lot sir
Reply by ●July 27, 20092009-07-27
On Jul 22, 10:45�am, "NIRMAY" <vidhusai...@yahoo.co.in> wrote:> hi > I've a doubt whether there is any possibility to implement HHT on > hardware.Whether it can be implemented on FPGA.Thanks in advanceUS Patent 5,983,162 "Computer implemented empirical mode decomposition method, apparatus and article of manufacture" You are on the hook for royalties, dude
