Hey all, I am constructing a DFE to serve as a baseline algorithm which I ca n compare my future work against. I run my DFE on Proakis Channel C(0.227 0.460 0.688 0.460 0.227) and could not duplicate the BER vs Eb/No result thats in the Digital Communication book. It works fine (from the BER graph,again) if I run it through a truncated version of channel C, [0.688 0.46 0.227]. So I am wondering if theres any thing I need to take note of when dealing with channel with both precursor and post cursor ISI. Any form of help is appreciated. Thanks! Kelvin
Construction of DFE
Started by ●July 22, 2009
Reply by ●July 22, 20092009-07-22
In his book he has given results for both ZF and MMSE. I myself did it and I get exactly the same results. Check the paper by Al-Dahir and implement it.
Reply by ●July 24, 20092009-07-24
Hey thanks. When dealing with channel like Proakis Channel B where there is a delay, do we equalize the signal to the first tap? Or should we equalize it to the dominant tap (which is the 3rd tap in Channel B situation)? Thanks, Kelvin>In his book he has given results for both ZF and MMSE. > >I myself did it and I get exactly the same results. > >Check the paper by Al-Dahir and implement it. >
>Hey thanks. > >When dealing with channel like Proakis Channel B where there is a delay, >do we equalize the signal to the first tap? Or should we equalize it tothe>dominant tap (which is the 3rd tap in Channel B situation)? > >Thanks, >Kelvin >In any channel of Proakis or multipath in general, there will be delay. And in the channel B, the second tap with value 0.815 is dominant tap. There are two ways to equalize: 1. assume u know the channel at receiver 2. assume u do not know the channel at receiver. I would suggest implement the 1st option for channel B using both ZF and MMSE criteria. Chintan
Hey Chintan, Sorry I was talking about channel C. If my understanding of DFE is correct, the first two tap will cause post-cursor ISI if we are to equalize the channel to the dominant (3rd) tap, and DFE cant eliminate post-cursor ISI. I am working on channel-known, MMSE case, not going into adaptive equalizer...yet :) Thanks alot. Kelvin>In any channel of Proakis or multipath in general, there will be delay. > >And in the channel B, the second tap with value 0.815 is dominant tap. > >There are two ways to equalize: 1. assume u know the channel at receiver >2. assume u do not know the channel at receiver. > >I would suggest implement the 1st option for channel B using both ZF and >MMSE criteria. > >Chintan >
>Hey Chintan, > >Sorry I was talking about channel C. > >If my understanding of DFE is correct, the first two tap will cause >post-cursor ISI if we are to equalize the channel to the dominant (3rd) >tap, and DFE cant eliminate post-cursor ISI.The first two taps are pre-cursor and the last two are post cursor. The FF filter of DFE removes pre-cursor and FB filter removes post-cursor.> >I am working on channel-known, MMSE case, not going into adaptive >equalizer...yet :) >http://www.freescale.com/files/dsp/doc/app_note/AN2072.pdf I had used this document when I implemented DFE for channels B and C using MMSE. Read it carefully and u should find the ans. Hope this helps. Chintan
Reply by ●July 28, 20092009-07-28
Hey Chintan, The page has been removed. Do you still have the softcopy with u? Or u know of any other sources to access the file? Thanks, Kel>http://www.freescale.com/files/dsp/doc/app_note/AN2072.pdf > >I had used this document when I implemented DFE for channels B and Cusing>MMSE. Read it carefully and u should find the ans. > >Hope this helps. > >Chintan > >
Thanks! Its piakster@gmail.com Kelvin> >I do have the soft copy. Tell me your email add and I will forward thatto>u. > >Chintan >
