In D/A conversion, is sample-and-hold necessary?
Started by m26k9 July 23, 2009
Vladimir Vassilevsky wrote:
> > > robert bristow-johnson wrote: > >> On Jul 23, 1:49 pm, Vladimir Vassilevsky <nos...@nowhere.com> >> wrote: >> >>> There is a DSD audio format which is essentially a pulse density >>> modulated signal. There is no sample-hold there. > > Isn't DSD the direct analog to PDM conversion? BTW, I have never seen > the DSD in the reality. Do you actually use it? > >
If you have a music recording on SACD, you are using it. How important it is depends on (a) whether you believe SACD has a long-term (or even medium-term) future, and (b) which side you are on in the ongoing AES-hosted debate over the merits or otherwise of DSD v standard over-sampled(etc) PCM encoding. See e.g. refs at the bottom of: http://en.wikipedia.org/wiki/Direct_Stream_Digital Richard Dobson
On Jul 24, 3:06=A0am, "m26k9" <maduranga.liyan...@gmail.com> wrote:
> Thank you very much Robert, Steve.
yer welcome, FWIW.
> Actually I do have a impulse train of samples.
really, you actually *physically* have actual dirac delta functions happening? this i would like to see. (perhaps you can get a Nobel prize in physics for being able to synthesize actual dirac impulses.)
> I am doing the DAC on on an > IFFT output. So the digital samples are already there.
you have digital samples. that i can believe. is that the same as having attached those digital samples to dirac impulses in the real (analog) world?
> Does that mean I do > not need a S/H and do a LPF directly?
in the practical use of DACs, sometimes S/H circuits are used to deglitch the output (my very first published paper some 2 decades ago was about that), but the concept of the S/H here in this discussion is *hypothetical*. it is to *model* mathematically (and not just any mathematics, but the mathematics of Linear, Time-Iinvariant systems and the particular LTI we're referring to is called the Zero-Order Hold or ZOH) how the output of a D/A looks exactly like the output of this fictitious ZOH when driven by a fictitious string of dirac impulses. that's the whole purpose of this.
> But, even if I do not have a pulse train, I can do sampling on my analog > signal, get the digital samples, send it through a LPF and it will > construct an analog signal? would it not?
i presume you mean an LPF in the analog domain. a filter with a gain near to dimensionless 1 in the passband and near to 0 in the stopband, right?
> I am a little confused still as to why I need to do S/H before LPF, as > oppose to just LPF? > > Thank you and I am sorry if I am missing a a trivial point.
the point that you're missing is what is *hypothetical* or *fictitious* or a *mathematical model* vs. what is real and physical. you have to get that straight first. r b-j
On Jul 24, 9:41=A0am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:
> robert bristow-johnson wrote: > > On Jul 23, 1:49 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > >>There is a DSD audio format which is essentially a pulse density > >>modulated signal. There is no sample-hold there. > > Isn't DSD the direct analog to PDM conversion?
i dunno.
> BTW, I have never seen the DSD in the reality. > Do you actually use it?
no. i've been sorta a detractor of DSD as using more bits per sample than good ol' PCM with 32 bit words. but i tread lightly with that opinion, especially at AES conventions, lest they hang me up by my balls. my only point (besides playfully hoisting you by your own pitard) is that, even if the oversampling ratio is 64 or 128 (or whatever), so the sampling rate for this DSD is say 3 or 6 MHz, physically, for those 160 or 320 nanoseconds, the voltage is still held at a constant value (i don't think the are spiking it and returning back to zero between each sample) of either +1 or -1 (pick your units). that is still a ZOH, there is still a sinc() function in the frequency response, even though that sinc() function has little effect below 20 kHz (the zeros of the sinc() function are at integer multiples of Fs, except for 0). r b-j
> On Jul 24, 9:41 am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:
>> >>Isn't DSD the direct analog to PDM conversion? > > i dunno. > > >>BTW, I have never seen the DSD in the reality. >>Do you actually use it? > > no. i've been sorta a detractor of DSD as using more bits per sample > than good ol' PCM with 32 bit words. but i tread lightly with that > opinion, especially at AES conventions, lest they hang me up by my > balls.
IMO it could make sense to keep the audio in the PWM format with the low rate (say, 96kHz). So the PWM specific distortion can be corrected offline; the signal could be fed directly into the output stage. The volume can be adjusted by changing the supply voltage; the feedbackless class D needs the regulated rails anyway.
> my only point (besides playfully hoisting you by your own pitard) is > that, even if the oversampling ratio is 64 or 128 (or whatever), so > the sampling rate for this DSD is say 3 or 6 MHz, physically, for > those 160 or 320 nanoseconds, the voltage is still held at a constant > value (i don't think the are spiking it and returning back to zero > between each sample) of either +1 or -1 (pick your units). that is > still a ZOH, there is still a sinc() function in the frequency > response, even though that sinc() function has little effect below 20 > kHz (the zeros of the sinc() function are at integer multiples of Fs, > except for 0).
With PDM or PWM, although sampled at a fixed rate, math is not so simple since the pulse positions could be different within the sampling interval. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> > even if the oversampling ratio is 64 or 128 (or whatever), so > > the sampling rate for this DSD is say 3 or 6 MHz, physically, for > > those 160 or 320 nanoseconds, the voltage is still held at a constant > > value (i don't think the are spiking it and returning back to zero > > between each sample) of either +1 or -1 (pick your units). =A0that is > > still a ZOH, there is still a sinc() function in the frequency > > response, even though that sinc() function has little effect below 20 > > kHz (the zeros of the sinc() function are at integer multiples of Fs, > > except for 0). > > With PDM or PWM, although sampled at a fixed rate, math is not so simple > since the pulse positions could be different within the sampling interval=
. AFAIK, the math behind DSD is the same math behind sigma-delta modulators. there can be many different PCM to DSD conversion schemes; they would differ in computational cost and complexity and in audio quality. but the demodulation scheme (DSD to PCM) is the same, no matter how they were created. PCM =3D downsample{ LPF{ DSD } } if the bits of DSD are a[n], then the signal that gets LPFed is (-1)^a [n] (just like with MLS). r b-j
