i have a computer microphone and i want to be able to detect a tone at a specific frequency from the recording from the microphone. i want the program to work with background sound. What methods are available ?
detect tone
Started by ●July 28, 2009
Reply by ●July 28, 20092009-07-28
On 28 Jul, 12:09, amcneilly <amcnei...@gmail.com> wrote:> i have a computer microphone and i want to be able to detect a tone at > a specific frequency from the recording from the microphone. i want > the program to work with background sound. What methods are available ?It depends a bit on what what you mean by 'tone'. If you mean 'monochromatic signal at the specified frequency' then the task is simple: Use a narrow-band band-pass filter centered at the frequency, and measure the energy at the output of this filter relative to the energy of the unfiltered signal. If you by 'tone' means 'a tone played by some musical instrument' then this might be very hard. Rune
Thanks for your reply. The tone should be monochromatic. as i am producing a pure tone of a specified frequency. How would i calculate the energy of a waveform? On Jul 28, 11:21=A0am, Rune Allnor <all...@tele.ntnu.no> wrote:> On 28 Jul, 12:09,amcneilly<amcnei...@gmail.com> wrote: > > > i have a computer microphone and i want to be able to detect a tone at > > a specific frequency from the recording from the microphone. i want > > the program to work with background sound. What methods are available ? > > It depends a bit on what what you mean by 'tone'. > > If you mean 'monochromatic signal at the specified > frequency' then the task is simple: Use a narrow-band > band-pass filter centered at the frequency, and measure > the energy at the output of this filter relative to the > energy of the unfiltered signal. > > If you by 'tone' means 'a tone played by some musical > instrument' then this might be very hard. > > Rune
> How would i calculate the energy of a waveform?You can use RMS value on the output of the filter (over a window). gopi --- Sankhya Technologies Private Limited http://www.sankhya.com Mobile: +91 94408 78042 US (Voice-Mail) (408) 556-9757
On Jul 28, 6:09=A0am, amcneilly <amcnei...@gmail.com> wrote:> i have a computer microphone and i want to be able to detect a tone at > a specific frequency from the recording from the microphone. i want > the program to work with background sound. What methods are available ?Try reading Vlad's paper http://www.abvolt.com/research/Multitone%20detect-IEEE.pdf Clay
On Jul 28, 6:09=A0am, amcneilly <amcnei...@gmail.com> wrote:> i have a computer microphone and i want to be able to detect a tone at > a specific frequency from the recording from the microphone. i want > the program to work with background sound. What methods are available ?I'd probably just use a Goertzel DTFT at the tone frequency. Darrell
amcneilly wrote:> i have a computer microphone and i want to be able to detect a tone at > a specific frequency from the recording from the microphone. i want > the program to work with background sound. What methods are available ?If you want to impress your professor, use LM567. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Jul 28, 10:53=A0am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> amcneilly wrote: > > i have a computer microphone and i want to be able to detect a tone at > > a specific frequency from the recording from the microphone. i want > > the program to work with background sound. What methods are available ? > > If you want to impress your professor, use LM567. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comAnd it will directly drive an LED to let you know when the frequency is present.
Reply by ●July 30, 20092009-07-30
On Jul 28, 11:21�am, Rune Allnor <all...@tele.ntnu.no> wrote:> On 28 Jul, 12:09,amcneilly<amcnei...@gmail.com> wrote: > > > i have a computer microphone and i want to be able to detect a tone at > > a specific frequency from the recording from the microphone. i want > > the program to work with background sound. What methods are available ? > > It depends a bit on what what you mean by 'tone'. > > If you mean 'monochromatic signal at the specified > frequency' then the task is simple: Use a narrow-band > band-pass filter centered at the frequency, and measure > the energy at the output of this filter relative to the > energy of the unfiltered signal. > > If you by 'tone' means 'a tone played by some musical > instrument' then this might be very hard. > > RuneWould a monochromatic tone a specific frequency be a pure sin wave?
Reply by ●August 1, 20092009-08-01
Thanks for your help. I have successfully detected my 20 khz tone using Goertzel algorithm using Matlab. What i would like to do now is change the sender signal and the detection algorithm to help reduce the problem of detection of background sound. The goal is to detect from a microphone a signal from a transmitter with minimal interference from background sound. i can tolerate a low percentage of false positives. What i was thinking is mixing a 20 khz tone and 19 khz . i am a novice to DSP. What approach would you guys recommend? On Jul 30, 4:53�pm, amcneilly <amcnei...@gmail.com> wrote:> On Jul 28, 11:21�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > > > On 28 Jul, 12:09,amcneilly<amcnei...@gmail.com> wrote: > > > > i have a computer microphone and i want to be able to detect a tone at > > > a specific frequency from the recording from the microphone. i want > > > the program to work with background sound. What methods are available ? > > > It depends a bit on what what you mean by 'tone'. > > > If you mean 'monochromatic signal at the specified > > frequency' then the task is simple: Use a narrow-band > > band-pass filter centered at the frequency, and measure > > the energy at the output of this filter relative to the > > energy of the unfiltered signal. > > > If you by 'tone' means 'a tone played by some musical > > instrument' then this might be very hard. > > > Rune > > Would a monochromatic tone a specific frequency be a pure sin wave?
