Hello, In the following A is a real constant value signal and the symbol * denotes the convolution operation. We know that: A*x(n)----Fourier----> A.&(f).X(f), where &(f) denotes Dirac function. however, A.X(0) <----Fourier---- A.&(f).X(f) Therefore A*x(n)=A.X(0)=A.sum(x(n)) which is expected when we apply the convolution expression on A*x(n). However, i am getting a problem to extrapolate the same verfication with the expression A*Rxx(n) where Rxx is the autocorrelation function of the signal x. we know that Rxx(n)=x(n)*x(-n)=sum(x(k).x(n+k)) (1) Hence, A*Rxx(n)=A*x(n)*x(-n)----Fourier----> A.&(f).X(f).X(-f) however A.X(0)^2 <---Fourier---- A.&(f).X(f).X(-f) Therefore A*x(n)*x(-n)=A.X(0)^2 = A.sum(x(n))^2. (2) If we have to apply equation (1), we have A*Rxx(n)=A.sum(Rxx(n))=A.sum[sum(x(k).x(n+k))] (3) I am struggling to equal (2) to (3) , any help please
Convolution with a constant value signal
Started by ●August 12, 2009
Reply by ●August 13, 20092009-08-13
On 12 Aug, 18:10, karl bezzoto <karl.bezz...@googlemail.com> wrote:> Hello, > In the following A is a real constant value signal and the symbol * > denotes the convolution operation. > > We know that: > A*x(n)----Fourier----> A.&(f).X(f), where &(f) denotes Dirac function.Wrong. FT{ax(t)} =3D aFT{x(t)}.> however, > A.X(0) =A0 =A0 <----Fourier---- A.&(f).X(f)Wrong. Dirac's delta is a distribution, and should never appear outside an integration sign.> I am struggling to equal (2) to (3) , any help pleaseThe results don't make sense because your derivations don't make sense. Read up on the properties of the FT. Rune
"Rune Allnor" <allnor@tele.ntnu.no> wrote in message news:d0f090ac-e82c-4fa9-8d81-e0e42d04b72b@w6g2000yqw.googlegroups.com...> Wrong. Dirac's delta is a distribution, and should never > appear outside an integration sign.There are two discussion points here. 1. When the Delta Function is introduced (to electronic engineers, at least) as Limit as T -> 0 of (U(t) - U(t-T)) / T then other waveforms (such as the sampled pulse) can be discussed as being a scaled version of the Impulse itself, rather than as the effect of the impulse on another waveform, in which case the integral operation is irrelevant. (ISTR "That's not irrelevant, that's ir hippopotamus" from the Goon Show?) 2. A discussion about distributions is unhelpful to the point of irrelevance. When the Delta Function is introduced (to electronic engineers, at least), they are invited to feel uncomfortable about it not being a proper function despite that up to that point they will have been handling steps, pulses, square and triangular waves, functions that are as equally unanalytic as the delta, without any discomfort whatsoever being felt or suggested. To ease the suggested discomfort, a study of distributions and generalised functions is a further suggestion, after which, you come back to using the delta as an ordinary function, just as you were before the suggested disconfort, but without the application of any new mathematics that you might have encountered during your study. Therefore the suggestion of distributions and / or generalised functions is an irrelevant sidetrack that adds nothing to the understanding or the application of mathematics.
On Aug 13, 4:12�am, Rune Allnor <all...@tele.ntnu.no> wrote:> On 12 Aug, 18:10, karl bezzoto <karl.bezz...@googlemail.com> wrote: > > > Hello, > > In the following A is a real constant value signal and the symbol * > > denotes the convolution operation. > > > We know that: > > A*x(n)----Fourier----> A.&(f).X(f), where &(f) denotes Dirac function. > > Wrong. �FT{ax(t)} = aFT{x(t)}.Rune - he stated that the * meant convolution not multiplication, so his original statement is, I believe, correct.> > > however, > > A.X(0) � � <----Fourier---- A.&(f).X(f) > > Wrong. Dirac's delta is a distribution, and should never > appear outside an integration sign.While you may not like the dirac function appearing by itself, it does have a FT since in taking the FT you are integrating over it. Cheers, David
On 13 Aug, 14:26, Dave <dspg...@netscape.net> wrote:> On Aug 13, 4:12�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > On 12 Aug, 18:10, karl bezzoto <karl.bezz...@googlemail.com> wrote: > > > > Hello, > > > In the following A is a real constant value signal and the symbol * > > > denotes the convolution operation. > > > > We know that: > > > A*x(n)----Fourier----> A.&(f).X(f), where &(f) denotes Dirac function. > > > Wrong. �FT{ax(t)} = aFT{x(t)}. > > Rune - he stated that the * meant convolution not multiplication, so > his original statement is, I believe, correct.I am sure you can come up with a reference for how to convolve with a constant?> > > however, > > > A.X(0) � � <----Fourier---- A.&(f).X(f) > > > Wrong. Dirac's delta is a distribution, and should never > > appear outside an integration sign. > > While you may not like the dirac function appearing by itself, it does > have a FT since in taking the FT you are integrating over it.I know quite a few (most?) of my opinions are generally regarded as controversial. However, at least one other person agrees with me, check out Papoulis: "The Fourier Integral and its Applications", (1961) page 269: The problems about understanding the Dirac Delta are down to "...the reluctance of the applied scientist to accept the description of a physical quantity by a concept that is not an ordinary function, but is specified by certain properties of integral nature." I think Papoulis nailed the cause of just about every single comp.dsp semantics war over Dirac's Delta, decades before USENET ever existed. Rune
On Aug 13, 9:12�am, Rune Allnor <all...@tele.ntnu.no> wrote:> On 13 Aug, 14:26, Dave <dspg...@netscape.net> wrote: > > > On Aug 13, 4:12�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > On 12 Aug, 18:10, karl bezzoto <karl.bezz...@googlemail.com> wrote: > > > > > Hello, > > > > In the following A is a real constant value signal and the symbol * > > > > denotes the convolution operation. > > > > > We know that: > > > > A*x(n)----Fourier----> A.&(f).X(f), where &(f) denotes Dirac function. > > > > Wrong. �FT{ax(t)} = aFT{x(t)}. > > > Rune - he stated that the * meant convolution not multiplication, so > > his original statement is, I believe, correct. > > I am sure you can come up with a reference for how > to convolve with a constant?Yes, See Papoulis "Signals, Systems and Transforms" 1977. The FT of a constant is the scaled (i.e. amplitude) dirac delta at zero frequency.> > > > > however, > > > > A.X(0) � � <----Fourier---- A.&(f).X(f) > > > > Wrong. Dirac's delta is a distribution, and should never > > > appear outside an integration sign. > > > While you may not like the dirac function appearing by itself, it does > > have a FT since in taking the FT you are integrating over it. > > I know quite a few (most?) of my opinions are generally > regarded as controversial. However, at least one other > person agrees with me, check out > > Papoulis: "The Fourier Integral and its Applications", > (1961) page 269: > > The problems about understanding the Dirac Delta are > down to "...the reluctance of the applied scientist to > accept the description of a physical quantity by a concept > that is not an ordinary function, but is specified by > certain properties of integral nature." > > I think Papoulis nailed the cause of just about every > single comp.dsp semantics war over Dirac's Delta, decades > before USENET ever existed.Yes, I agree - I didn't want to see this thread dissolve into one of those. However, he still uses the dirac delta throughout his derivations without it appearing under an integral (see the book referenced about). In another one of his books he explains the multiplication by a dirac delta train (i.e sampling) by saying that the samples have an area (thus meaing integrating) equal to the value of the continuous function at that time. Cheers, Dave
Computer Man wrote: ...> (ISTR "That's not irrelevant, that's ir hippopotamus" from the Goon Show?)Flanders and Swann's patter intro to "The Hippopotamus Song". ... Glorious mud to you, Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 13 Aug, 16:15, Dave <dspg...@netscape.net> wrote:> On Aug 13, 9:12�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > > > On 13 Aug, 14:26, Dave <dspg...@netscape.net> wrote: > > > > On Aug 13, 4:12�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > On 12 Aug, 18:10, karl bezzoto <karl.bezz...@googlemail.com> wrote: > > > > > > Hello, > > > > > In the following A is a real constant value signal and the symbol * > > > > > denotes the convolution operation. > > > > > > We know that: > > > > > A*x(n)----Fourier----> A.&(f).X(f), where &(f) denotes Dirac function. > > > > > Wrong. �FT{ax(t)} = aFT{x(t)}. > > > > Rune - he stated that the * meant convolution not multiplication, so > > > his original statement is, I believe, correct. > > > I am sure you can come up with a reference for how > > to convolve with a constant? > > Yes, See Papoulis "Signals, Systems and Transforms" 1977. The FT of a > constant is the scaled (i.e. amplitude) dirac delta at zero frequency. > > > > > > > > > > > > however, > > > > > A.X(0) � � <----Fourier---- A.&(f).X(f) > > > > > Wrong. Dirac's delta is a distribution, and should never > > > > appear outside an integration sign. > > > > While you may not like the dirac function appearing by itself, it does > > > have a FT since in taking the FT you are integrating over it. > > > I know quite a few (most?) of my opinions are generally > > regarded as controversial. However, at least one other > > person agrees with me, check out > > > Papoulis: "The Fourier Integral and its Applications", > > (1961) page 269: > > > The problems about understanding the Dirac Delta are > > down to "...the reluctance of the applied scientist to > > accept the description of a physical quantity by a concept > > that is not an ordinary function, but is specified by > > certain properties of integral nature." > > > I think Papoulis nailed the cause of just about every > > single comp.dsp semantics war over Dirac's Delta, decades > > before USENET ever existed. > > Yes, I agree - I didn't want to see this thread dissolve into one of > those. However, he still uses the dirac delta throughout his > derivations without it appearing under an integral (see the book > referenced about). In another one of his books he explains the > multiplication by a dirac delta train (i.e sampling) by saying that > the samples have an area (thus meaing integrating) equal to the value > of the continuous function at that time. > > Cheers, > Dave- Hide quoted text - > > - Show quoted text -- Hide quoted text - > > - Show quoted text -Thanks Dave. It is what i had in mind while using Dirac function above. As you explained, the sampling of a signal is often formalised first as a multiplication of the input signal with a dirac delta train. however as far as my question is concerned i can't still equal to the 2 equations given in my OP
On 13 Aug, 17:15, Dave <dspg...@netscape.net> wrote:> On Aug 13, 9:12�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > > > On 13 Aug, 14:26, Dave <dspg...@netscape.net> wrote: > > > > On Aug 13, 4:12�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > On 12 Aug, 18:10, karl bezzoto <karl.bezz...@googlemail.com> wrote: > > > > > > Hello, > > > > > In the following A is a real constant value signal and the symbol * > > > > > denotes the convolution operation. > > > > > > We know that: > > > > > A*x(n)----Fourier----> A.&(f).X(f), where &(f) denotes Dirac function. > > > > > Wrong. �FT{ax(t)} = aFT{x(t)}. > > > > Rune - he stated that the * meant convolution not multiplication, so > > > his original statement is, I believe, correct. > > > I am sure you can come up with a reference for how > > to convolve with a constant? > > Yes, See Papoulis "Signals, Systems and Transforms" 1977. The FT of a > constant is the scaled (i.e. amplitude) dirac delta at zero frequency.In that case you need to define what you mean both by 'FT' and 'convolution'. One of the requirements for a signal is that inf integral |f(x)|^2 dx < inf. -inf This is clearly not satisfied if f is a non-zero constant. Rune
"Dave" <dspguy2@netscape.net> wrote in message news:2ba5ecc3-9d8d-489a-89ba-d82fdbdd7b6c@a13g2000yqc.googlegroups.com...> In another one of his books he explains the > multiplication by a dirac delta train (i.e sampling) by saying that > the samples have an area (thus meaing integrating) equal to the value > of the continuous function at that time.Then it must be the only case in advanced mathematical analysis of an integration being claimed to happen but never appearing in any of the derivations!
