Can anyone tell that what is the effect of doing oversampling before pulse shaping on the transmission bandwidth? My concern is that as books describe that doing upsampling and then filtering results in reduction in the Bandwidth but at the same time if we view it from different angle, we are throwing more samples per second so so shouldn't Bandwidth also be increased ? Thanks in advance.
Effect of oversampling on Signal Band width
Started by ●August 12, 2009
Reply by ●August 12, 20092009-08-12
Ali A Nasir wrote:> Can anyone tell that what is the effect of doing oversampling before pulse > shaping on the transmission bandwidth? > > My concern is that as books describe that doing upsampling and then > filtering results in reduction in the Bandwidth but at the same time if we > view it from different angle, we are throwing more samples per second so > so shouldn't Bandwidth also be increased ? > > Thanks in advance. >That is the point of the upsampling - any filtering or aliasing artifacts would tend to be more out of band. How you get back down to the desired bandwidth depends on things not in evidence in the system. You may just be able to LPF the output. -- Les Cargill
"Ali A Nasir" <aliarshad46@hotmail.com> wrote in message news:K_adnULFZYMbhx7XnZ2dnUVZ_uKdnZ2d@giganews.com...> Can anyone tell that what is the effect of doing oversampling before pulse > shaping on the transmission bandwidth? > My concern is that as books describe that doing upsampling and then > filtering results in reduction in the Bandwidth but at the same time if we > view it from different angle, we are throwing more samples per second so > so shouldn't Bandwidth also be increased ?Actually, from the theoretical viewpoint, increasing the sample rate does _NOT_ increase the bandwidth, but merely increases the number of harmonics present in any given band. The reason is because the theoretical sampling waveform, a Shah function of multiple delayed Diracians (cue : Airy R Bean?) contains every harmonic up to infinity, all at the same level. The bandwidth of the sampled waveform is infinite and is independent of the sampling frequency. (Sequency?) Decimating***** reduces the processing workload, but not the bandwidth. ***** Means deleting every 10th, according to Roman tradition, and not deleting 9 out of every 10!
Computer Man wrote:> Decimating*****...> ***** Means deleting every 10th, according to Roman tradition, and not > deleting 9 out of every 10!When it comes to soldiers (legionairs?), the word is not usually "delete". Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> Computer Man wrote: > > >> Decimating***** > > ... > >> ***** Means deleting every 10th, according to Roman tradition, and not >> deleting 9 out of every 10! > > When it comes to soldiers (legionairs?), the word is not usually "delete". > > JerryI dunno - the "class Spartan" soldier had a "delete" method, as required by "with your shield or on it." This method has been deprecated since the abandonment of Bushido. -- Les Cargill
Ali A Nasir wrote:> Can anyone tell that what is the effect of doing oversampling before pulse > shaping on the transmission bandwidth? > > My concern is that as books describe that doing upsampling and then > filtering results in reduction in the Bandwidth but at the same time if we > view it from different angle, we are throwing more samples per second so > so shouldn't Bandwidth also be increased ? > > Thanks in advance. >It would help if you were clearer... Oversampling implies original sampling. Upsampling implies increasing the sample rate after sampling has already been done. So, which is it? If you oversample in the original sampling process then that just means there is bandwidth margin in the sample spectrum - around fs/2 there is very little energy and this extends for some distance around fs/2 depending on the oversample ratio. If you upsample, there are a few ways to do this. It depends on whether there is a fixed array of samples to start with or whether you're streaming data. Fundamentally it's an interpolation process in time. A common way to do this is to inject zeros between the samples .. thus increasing the sample rate without doing much else. Then, lowpass filter so that the repeated spectra are removed and the zeros are generally filled in with nonzero values. None of this does anything to the bandwidth of the samples you started with. Fred
