On Aug 16, 11:00�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> Randy Yates wrote: > > Vladimir Vassilevsky <nos...@nowhere.com> writes: > > >>1. Record the signal at the known distance for using it as an etalon. > > > Hey Vlad, "etalon" is not in my dictionary - what is it? > > This is not the ethanol :-) > > Etalon (latin) = standard, norm, gauge, reference. > > VLVWe - the vulgar folks - dub this template :). -Manny
Signal Matching
Started by ●August 16, 2009
Reply by ●August 18, 20092009-08-18
On Aug 17, 5:22=A0pm, julius <juli...@gmail.com> wrote:> On Aug 16, 1:30 pm,amcneilly<amcnei...@gmail.com> wrote: > > > I am new to DSP and i have the following problem > > > I need to detect a 20khz pulse for a sonic ranging application using a > > PC. I can detect reasonably well the 20khz signal by measuring the RMS > > of the signal from the microphone then filtering the input using a > > high pass filter or goertzel calculation and take a RMS calculation of > > the filtered signal. If the RMS is over a threshold value then the > > signal has been detected. > > > The problem is that i cannot get a decent resolution. If i process the > > signal in >=3D 64 samples chunks my signal detection works but i requir=e> > 11 samples resolution and this results in poor accuracy. > > > Does anyone have any advice on a detection algorithm that would work > > on ~11 sample chunks? > > This problem sounds like a homework problem. =A0If it is not, then you > made too many assumptions too soon. =A0Let us start from the very > beginning again: =A0what resources do you have and what do you want > to do? =A0How did it come to be that you have a 20 kHz pulse? =A0Did you > choose this? > > JuliusMy resources, desktop computer, speaker and microphone. i am trying to build a crude sonic ranging system. My transmitter is a speaker with a frequency range of up to 22 khz. I selected 20Khz because i figured that it would have the least interference from the other available frequencies and is inaudible.
On Aug 18, 7:06=A0am, amcneilly <amcnei...@gmail.com> wrote:> On Aug 17, 5:22=A0pm, julius <juli...@gmail.com> wrote: > > > > > On Aug 16, 1:30 pm,amcneilly<amcnei...@gmail.com> wrote: > > > > I am new to DSP and i have the following problem > > > > I need to detect a 20khz pulse for a sonic ranging application using =a> > > PC. I can detect reasonably well the 20khz signal by measuring the RM=S> > > of the signal from the microphone then filtering the input using a > > > high pass filter or goertzel calculation and take a RMS calculation o=f> > > the filtered signal. If the RMS is over a threshold value then the > > > signal has been detected. > > > > The problem is that i cannot get a decent resolution. If i process th=e> > > signal in >=3D 64 samples chunks my signal detection works but i requ=ire> > > 11 samples resolution and this results in poor accuracy. > > > > Does anyone have any advice on a detection algorithm that would work > > > on ~11 sample chunks? > > > This problem sounds like a homework problem. =A0If it is not, then you > > made too many assumptions too soon. =A0Let us start from the very > > beginning again: =A0what resources do you have and what do you want > > to do? =A0How did it come to be that you have a 20 kHz pulse? =A0Did yo=u> > choose this? > > > Julius > > My resources, desktop computer, speaker and microphone. i am trying to > build a crude sonic ranging system. > > My transmitter is a speaker with a frequency range of up to 22 khz. I > selected 20Khz because i figured that it would have the least > interference from the other available frequencies and is inaudible.In the presence of white noise, the optimal signal delay estimator is a cross-correlator, followed by a peak-finder. So this should be the "signal matching" solution that you are looking for. However, your received signal may be subjected to frequency-selective distortion, and you may have to account for that. But in the simplest model under which the signal just gets reflected back at you, the solution is simple. Now you are left with the problem of choosing what signal to send. One of the factors is what others have mentioned: time-frequency ambiguity or profile. Look this up, and think again what this means in terms of the signal that you have selected (hint: your signal choice sucks). Once you learn that, then figure out what kind of noise you have, and optimize your signal parameter. Basically, all signs point towards some sort of wideband signal, such as chirp, or spread-spectrum, or something. But you decided yourself to choose a narrowband signal. Good luck. Julius
On 18 Aug, 13:06, amcneilly <amcnei...@gmail.com> wrote:> On Aug 17, 5:22=A0pm, julius <juli...@gmail.com> wrote: > > > > > > > On Aug 16, 1:30 pm,amcneilly<amcnei...@gmail.com> wrote: > > > > I am new to DSP and i have the following problem > > > > I need to detect a 20khz pulse for a sonic ranging application using =a> > > PC. I can detect reasonably well the 20khz signal by measuring the RM=S> > > of the signal from the microphone then filtering the input using a > > > high pass filter or goertzel calculation and take a RMS calculation o=f> > > the filtered signal. If the RMS is over a threshold value then the > > > signal has been detected. > > > > The problem is that i cannot get a decent resolution. If i process th=e> > > signal in >=3D 64 samples chunks my signal detection works but i requ=ire> > > 11 samples resolution and this results in poor accuracy. > > > > Does anyone have any advice on a detection algorithm that would work > > > on ~11 sample chunks? > > > This problem sounds like a homework problem. =A0If it is not, then you > > made too many assumptions too soon. =A0Let us start from the very > > beginning again: =A0what resources do you have and what do you want > > to do? =A0How did it come to be that you have a 20 kHz pulse? =A0Did yo=u> > choose this? > > > Julius > > My resources, desktop computer, speaker and microphone. i am trying to > build a crude sonic ranging system.I assume your 'desktop computer' is a PC or something similar? If so, you have made the implicit assumption that the synchronization between transmit and recieve modes will not be a probleml i.e. that it takes a negligable amount of time from you finish sending the pulse and to your reciever is up and running. Be aware that OSes like Windows have a lot of tasks running at any one time, so there might be a delay between the time you have finished sending and till the reciever has been initialized. Synchronization might be a problem, depending on what kinds of accuracies you are looking for.> My transmitter is a speaker with a frequency range of up to 22 khz. I > selected 20Khz because i figured that it would have the least > interference from the other available frequencies and is inaudible.You don't want a signal with no interference, you want a signal that you can extract even in the presence of interference. As you have been told several times, this is a standard problem in radar and sonar contexts. Check out the literature on pulse shaping and matched filters. Rune
