Signal Localization
Started by Jimmy J. ●August 18, 2009
I am working on a problem involving signal localization and would like
suggestions on signal processing alternatives.
Imagine that you are in the hallway of a hotel with a receiver in hand.
Down the hall there are ten doors leading to ten suites.  Some dors are
open, some are closed. Somewhere inside of ONE of the suites is a sound
source that is producing an acoustic signal that sweeps linearly between
2.0kHz and 6.0kHz.  The sweep rate is approximately 8kHz/sec.  Each sweep
lasts approximately half a second and repeats approximately every two
seconds.
The task is to utlizize an optimal signal processing scheme in the receiver
that will lead the receiver to the source. There is considerable multipath
as well as attenuation between the source and the receiver. A constant-
amplitude template of the linear sweep is available.
Any/all suggestions for optimal signal processing are welcome.
Jimmy J. wrote:
> I am working on a problem involving signal localization and would like > suggestions on signal processing alternatives. > > Imagine that you are in the hallway of a hotel with a receiver in hand.
Can you tell about the real problem, not an imaginary example?
> The task is to utlizize an optimal signal processing scheme in the receiver > that will lead the receiver to the source.
Do you know the direction or just the intensity of the signal? Do you have the map of the area? Do you know the current receiver location wrt the map? How much of the processing power you can afford?
> There is considerable multipath > as well as attenuation between the source and the receiver. A constant- > amplitude template of the linear sweep is available. > > Any/all suggestions for optimal signal processing are welcome.
It depends. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Practical DSP is based on that the signal is localized at the inpot to the sensor device. If there is no signal present near the sensor, there is little reason to proceed.
> Imagine that you are in the hallway of a hotel with a receiver in hand. =
=A0
> Down the hall there are ten doors leading to ten suites. =A0Some dors are > open, some are closed. Somewhere inside of ONE of the suites is a sound > source that is producing an acoustic signal that sweeps linearly between > 2.0kHz and 6.0kHz. =A0The sweep rate is approximately 8kHz/sec. =A0Each s=
weep
> lasts approximately half a second and repeats approximately every two > seconds. =A0 > > The task is to utlizize an optimal signal processing scheme in the receiv=
er
> that will lead the receiver to the source. There is considerable multipat=
h
> as well as attenuation between the source and the receiver. A constant- > amplitude template of the linear sweep is available. > > Any/all suggestions for optimal signal processing are welcome. =A0
This is a trivial student excercise. The key is to get the problem formulation right, which happens to be where you have failed. Rune
Vladimir Vassilevsky <nospam@nowhere.com> wrote in
news:WOWdnWrDv9C26BbXnZ2dnUVZ_tCdnZ2d@giganews.com:
> > > Jimmy J. wrote: > >> I am working on a problem involving signal localization and would >> like suggestions on signal processing alternatives. >> >> Imagine that you are in the hallway of a hotel with a receiver in >> hand. > > Can you tell about the real problem, not an imaginary example?
The term "imagine" was a bad choice of words. The example that I described is a representative example of an actual real-world situation.
>> The task is to utlizize an optimal signal processing scheme in the >> receiver that will lead the receiver to the source. > > Do you know the direction or just the intensity of the signal?
Neither. No apriori information is available to the user other than the existence of the signal. The purpose of the receiver is to determine and provide directional and signal strength information to the user as the user hunts for the location of the signal source. The receiver may contain a highly directional microphone or a pair of spaced microphones (or both) to determine and idicate the direction and relative strength of the signal as the user hunts for the location of the signal source. The receiver needs to be battery-powered, hand-held device. Other than that, all options in terms of transducers, signal conditioning, signal processing, display, etc are on the table.
> Do you have the map of the area? > Do you know the current receiver location wrt the map?
No maps are available. Also, the geography of the area can vary from one situation to another situation. The only thing that common among the different situations is that the space is enclosed and is subdivided into various rooms of different shapes and sizes, sound absorbing characteristics, etc., as opposed to being an unobstructed outdoor situation.
For the sake of discussion, assume that of an IPOD.
>> There is considerable multipath >> as well as attenuation between the source and the receiver. A >> constant- amplitude template of the linear sweep is available. >> >> Any/all suggestions for optimal signal processing are welcome. > > It depends.
Then let me add that the signal exists in the presence of non-stationary background noise. If it were not for the multipath, I can see how a matched filter would improve the S/N of the signal at receiver. What I'd like to know is whether or not the linear sweep characteristic of the signal source is still beneficial in some way. If it is, I'd like to know what type of signal processing can be utilized to provide that additional benefit.
> Vladimir Vassilevsky > DSP and Mixed Signal Design Consultant > http://www.abvolt.com
Jimmy J wrote:
> Vladimir Vassilevsky <nospam@nowhere.com> wrote in > news:WOWdnWrDv9C26BbXnZ2dnUVZ_tCdnZ2d@giganews.com: >> >>Jimmy J. wrote:
> No apriori information is available to the user other than the > existence of the signal. The purpose of the receiver is to determine and > provide directional and signal strength information to the user as the > user hunts for the location of the signal source.
So your only option is going in the direction of the maximal signal strength.
> The receiver may > contain a highly directional microphone or a pair of spaced microphones > (or both) to determine and idicate the direction and relative strength of > the signal as the user hunts for the location of the signal source. The > receiver needs to be battery-powered, hand-held device. Other than that, > all options in terms of transducers, signal conditioning, signal > processing, display, etc are on the table.
So far, it is fairly basic. Where is a problem?
> Then let me add that the signal exists in the presence of non-stationary > background noise. If it were not for the multipath, I can see how a > matched filter would improve the S/N of the signal at receiver. What I'd > like to know is whether or not the linear sweep characteristic of the > signal source is still beneficial in some way.
The wideband signal averages out the signal strength variation due to the constructive and destructive interference; it is also less sensitive to the narowband interferrors. What kind of wideband signal to use is the matter of the application convenience.
> If it is, I'd like to > know what type of signal processing can be utilized to provide that > additional benefit.
Textbook stuff. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On 19 Aug, 19:46, Jimmy J <s...@spam.com> wrote:
> Vladimir Vassilevsky <nos...@nowhere.com> wrote innews:WOWdnWrDv9C26BbXnZ=
> > > > > Jimmy J. wrote: > > >> I am working on a problem involving signal localization and would > >> like suggestions on signal processing alternatives. > > >> Imagine that you are in the hallway of a hotel with a receiver in > >> hand. > > > Can you tell about the real problem, not an imaginary example? > > The term "imagine" was a bad choice of words. =A0The example that I > described is a representative example of an actual real-world situation. =
=A0
> > >> The task is to utlizize an optimal signal processing scheme in the > >> receiver that will lead the receiver to the source. > > > Do you know the direction or just the intensity of the signal? > > Neither. No apriori information is available to the user other than the > existence of the signal. =A0The purpose of the receiver is to determine a=
nd
Use a simple hand-held recorder, possibly with an external microphone, but shield the mic. Press it against each door and see where the signal is strongest. Rune
Rune Allnor <allnor@tele.ntnu.no> wrote in
news:d21916a2-d422-4fdb-aff9-79720c54debd@s6g2000vbp.googlegroups.com:
> On 19 Aug, 19:46, Jimmy J <s...@spam.com> wrote: >> Vladimir Vassilevsky <nos...@nowhere.com> wrote >> innews:WOWdnWrDv9C26BbXnZ > 2dnUVZ_tCdnZ2d@giganews.com: >> >> >> >> > Jimmy J. wrote: >> >> >> I am working on a problem involving signal localization and would >> >> like suggestions on signal processing alternatives. >> >> >> Imagine that you are in the hallway of a hotel with a receiver in >> >> hand. >> >> > Can you tell about the real problem, not an imaginary example? >> >> The term "imagine" was a bad choice of words. &#4294967295;The example that I >> described is a representative example of an actual real-world >> situation. > &#4294967295; >> >> >> The task is to utlizize an optimal signal processing scheme in the >> >> receiver that will lead the receiver to the source. >> >> > Do you know the direction or just the intensity of the signal? >> >> Neither. No apriori information is available to the user other than >> the existence of the signal. &#4294967295;The purpose of the receiver is to >> determine a > nd >> provide directional and signal strength information to the user as >> the user hunts for the location of the signal source. > > Use a simple hand-held recorder, possibly with an external > microphone, but shield the mic. Press it against each door > and see where the signal is strongest. > > Rune
Aside from the inconvenience, that will only get you past the first closed door. In my residence, for example, which has both upper and lower floors, there are no closed doors except for a bathroom that may occasionally be in use. So once you get past the front door, the simple hand-held recorder with shielded mic are useless. In fact, unless the mic is highly directional, you won't know whether to turn right and go down the entrance hall into the living room, or turn left toward the bedrooms or go take a dog leg and go down the stairs to the lower floor. And on top of that there's a potential S/N issue if one of the kids is screaming at the top of his lungs. Additionally, in a restaurant that may not have carpeted floors, there may also be considerable reverberant sound which could even render a highly directional mic virtually useless.
Jimmy J wrote:
> Rune Allnor <allnor@tele.ntnu.no> wrote in > news:d21916a2-d422-4fdb-aff9-79720c54debd@s6g2000vbp.googlegroups.com: > >> On 19 Aug, 19:46, Jimmy J <s...@spam.com> wrote: >>> Vladimir Vassilevsky <nos...@nowhere.com> wrote >>> innews:WOWdnWrDv9C26BbXnZ >> 2dnUVZ_tCdnZ2d@giganews.com: >>> >>> >>>> Jimmy J. wrote: >>>>> I am working on a problem involving signal localization and would >>>>> like suggestions on signal processing alternatives. >>>>> Imagine that you are in the hallway of a hotel with a receiver in >>>>> hand. >>>> Can you tell about the real problem, not an imaginary example? >>> The term "imagine" was a bad choice of words. The example that I >>> described is a representative example of an actual real-world >>> situation. >> >>>>> The task is to utlizize an optimal signal processing scheme in the >>>>> receiver that will lead the receiver to the source. >>>> Do you know the direction or just the intensity of the signal? >>> Neither. No apriori information is available to the user other than >>> the existence of the signal. The purpose of the receiver is to >>> determine a >> nd >>> provide directional and signal strength information to the user as >>> the user hunts for the location of the signal source. >> Use a simple hand-held recorder, possibly with an external >> microphone, but shield the mic. Press it against each door >> and see where the signal is strongest. >> >> Rune > > Aside from the inconvenience, that will only get you past the first > closed door. In my residence, for example, which has both upper and lower > floors, there are no closed doors except for a bathroom that may > occasionally be in use. So once you get past the front door, the simple > hand-held recorder with shielded mic are useless. In fact, unless the mic > is highly directional, you won't know whether to turn right and go down > the entrance hall into the living room, or turn left toward the bedrooms > or go take a dog leg and go down the stairs to the lower floor. And on > top of that there's a potential S/N issue if one of the kids is screaming > at the top of his lungs. Additionally, in a restaurant that may not have > carpeted floors, there may also be considerable reverberant sound which > could even render a highly directional mic virtually useless. >
I'm going to shock the group by agreeing with Mr. Vassilevsky. This seems to have too much "imaginary example". Your problem description just doesn't seem to "hang together"/"have focus"/"????". There was a recent thread (which I can't find at the moment) discussing good tech writing, it may have useful info/links.
Richard Owlett <rowlett@pcnetinc.com> wrote in
news:K-CdnYy_Xr7h9RHXnZ2dnUVZ_gCdnZ2d@supernews.com:
> Jimmy J wrote: >> Rune Allnor <allnor@tele.ntnu.no> wrote in >> news:d21916a2-d422-4fdb-aff9-79720c54debd@s6g2000vbp.googlegroups.com: >> >>> On 19 Aug, 19:46, Jimmy J <s...@spam.com> wrote: >>>> Vladimir Vassilevsky <nos...@nowhere.com> wrote >>>> innews:WOWdnWrDv9C26BbXnZ >>> 2dnUVZ_tCdnZ2d@giganews.com: >>>> >>>> >>>>> Jimmy J. wrote: >>>>>> I am working on a problem involving signal localization and would >>>>>> like suggestions on signal processing alternatives. >>>>>> Imagine that you are in the hallway of a hotel with a receiver in >>>>>> hand. >>>>> Can you tell about the real problem, not an imaginary example? >>>> The term "imagine" was a bad choice of words. The example that I >>>> described is a representative example of an actual real-world >>>> situation. >>> >>>>>> The task is to utlizize an optimal signal processing scheme in >>>>>> the receiver that will lead the receiver to the source. >>>>> Do you know the direction or just the intensity of the signal? >>>> Neither. No apriori information is available to the user other than >>>> the existence of the signal. The purpose of the receiver is to >>>> determine a >>> nd >>>> provide directional and signal strength information to the user as >>>> the user hunts for the location of the signal source. >>> Use a simple hand-held recorder, possibly with an external >>> microphone, but shield the mic. Press it against each door >>> and see where the signal is strongest. >>> >>> Rune >> >> Aside from the inconvenience, that will only get you past the first >> closed door. In my residence, for example, which has both upper and >> lower floors, there are no closed doors except for a bathroom that >> may occasionally be in use. So once you get past the front door, the >> simple hand-held recorder with shielded mic are useless. In fact, >> unless the mic is highly directional, you won't know whether to turn >> right and go down the entrance hall into the living room, or turn >> left toward the bedrooms or go take a dog leg and go down the stairs >> to the lower floor. And on top of that there's a potential S/N issue >> if one of the kids is screaming at the top of his lungs. >> Additionally, in a restaurant that may not have carpeted floors, >> there may also be considerable reverberant sound which could even >> render a highly directional mic virtually useless. >> > > I'm going to shock the group by agreeing with Mr. Vassilevsky. > This seems to have too much "imaginary example". > Your problem description just doesn't seem to "hang > together"/"have focus"/"????". > > There was a recent thread (which I can't find at the moment) > discussing good tech writing, it may have useful info/links.
It would be a lot more productive if you and others would dispense with the criticism and simply ask for whatever additional information you think that you require. The situation is a modified version of hide and seek that everyone has played as a child. The two modifications are: 1) the person who is hiding chirps every couple of seconds, and 2) the seeker is deaf and therefore needs to use an acoustic receiver with appropriate signal processing and display to assist him in finding the person who is hiding. The objective is to find the chirping person who is hiding. I have described the chirp signal, I have described the environment, and I have stated the two primary complicating factors which are 1) unkunknown amounts of miltipath, and 2) an unknown amount of uncorrelated noise that can have spectral content that may partially overlap the spectral content the signal. If you and others feel that this description is ambiguous or inadequate, then tell me specifically what is ambiguous and what is missing and I will fill in the missing details and/or provide whatever clarification is necessary. Simply asserting that the problem description doesn't seem to "hang together" or "have focus" amounts to engaging in the very lack of specificity that you are criticizing.
What EXACTLY is your question?
Jimmy J wrote:
> Richard Owlett <rowlett@pcnetinc.com> wrote in > news:K-CdnYy_Xr7h9RHXnZ2dnUVZ_gCdnZ2d@supernews.com: > > >>Jimmy J wrote: >> >>>Rune Allnor <allnor@tele.ntnu.no> wrote in >>>news:d21916a2-d422-4fdb-aff9-79720c54debd@s6g2000vbp.googlegroups.com: >>> >>> >>>>On 19 Aug, 19:46, Jimmy J <s...@spam.com> wrote: >>>> >>>>>Vladimir Vassilevsky <nos...@nowhere.com> wrote >>>>>innews:WOWdnWrDv9C26BbXnZ >>>> >>>>2dnUVZ_tCdnZ2d@giganews.com: >>>> >>>>> >>>>>>Jimmy J. wrote: >>>>>> >>>>>>>I am working on a problem involving signal localization and would >>>>>>>like suggestions on signal processing alternatives. >>>>>>>Imagine that you are in the hallway of a hotel with a receiver in >>>>>>>hand. >>>>>> >>>>>>Can you tell about the real problem, not an imaginary example? >>>>> >>>>>The term "imagine" was a bad choice of words. The example that I >>>>>described is a representative example of an actual real-world >>>>>situation. >>>> >>>> >>>> >>>>>>>The task is to utlizize an optimal signal processing scheme in >>>>>>>the receiver that will lead the receiver to the source. >>>>>> >>>>>>Do you know the direction or just the intensity of the signal? >>>>> >>>>>Neither. No apriori information is available to the user other than >>>>>the existence of the signal. The purpose of the receiver is to >>>>>determine a >>>> >>>>nd >>>> >>>>>provide directional and signal strength information to the user as >>>>>the user hunts for the location of the signal source. >>>> >>>>Use a simple hand-held recorder, possibly with an external >>>>microphone, but shield the mic. Press it against each door >>>>and see where the signal is strongest. >>>> >>>>Rune >>> >>>Aside from the inconvenience, that will only get you past the first >>>closed door. In my residence, for example, which has both upper and >>>lower floors, there are no closed doors except for a bathroom that >>>may occasionally be in use. So once you get past the front door, the >>>simple hand-held recorder with shielded mic are useless. In fact, >>>unless the mic is highly directional, you won't know whether to turn >>>right and go down the entrance hall into the living room, or turn >>>left toward the bedrooms or go take a dog leg and go down the stairs >>>to the lower floor. And on top of that there's a potential S/N issue >>>if one of the kids is screaming at the top of his lungs. >>>Additionally, in a restaurant that may not have carpeted floors, >>>there may also be considerable reverberant sound which could even >>>render a highly directional mic virtually useless. >>> >> >>I'm going to shock the group by agreeing with Mr. Vassilevsky. >>This seems to have too much "imaginary example". >>Your problem description just doesn't seem to "hang >>together"/"have focus"/"????". >> >>There was a recent thread (which I can't find at the moment) >>discussing good tech writing, it may have useful info/links. > > > > It would be a lot more productive if you and others would dispense with > the criticism and simply ask for whatever additional information you > think that you require. The situation is a modified version of hide and > seek that everyone has played as a child. The two modifications are: 1) > the person who is hiding chirps every couple of seconds, and 2) the > seeker is deaf and therefore needs to use an acoustic receiver with > appropriate signal processing and display to assist him in finding the > person who is hiding. The objective is to find the chirping person who > is hiding. I have described the chirp signal, I have described the > environment, and I have stated the two primary complicating factors which > are 1) unkunknown amounts of miltipath, and 2) an unknown amount of > uncorrelated noise that can have spectral content that may partially > overlap the spectral content the signal. If you and others feel that > this description is ambiguous or inadequate, then tell me specifically > what is ambiguous and what is missing and I will fill in the missing > details and/or provide whatever clarification is necessary. Simply > asserting that the problem description doesn't seem to "hang together" or > "have focus" amounts to engaging in the very lack of specificity that you > are criticizing. > > > > > > >
