On Thu, 3 Sep 2009 03:20:09 -0700 (PDT) Rune Allnor <allnor@tele.ntnu.no> wrote:> On 3 Sep, 11:59, "chrah" <christer.ahlst...@vti.se> wrote: > > Hi, > > I need to downsample a bunch of signals, all of which have very > > different properties (the Nyquist criteria will not be fulfilled > > after the downsampling). > > A *very* bad start, what DSP is concerned. On the other > hand, DSP might not be the method of choise for working > these data. > > > My question is how to proceed in the best possible way. All > > processing is off-line but has to be fairly fast. > > > > Case 1: An analogue signal (continuous amplitude and time) has been > > sampled and needs to be downsampled. I have no problems here, just > > apply un antialias filter and resample properly. > > > > Case 2: An analogue signal with discontinuous jumps. Ripples > > introduced by the antialias filter makes the downsampled signal > > useless. Please help. > > Then you will have to decide what means more to you: > The (presumably useful) original data, or the storage space. > If the downsampled data are useless, there is no point of > downsampling. > > Or you will have to come up with a very detailed description > of both the process that generates your data, as well as the > purpose of your processing. There might be non-DSP methods > that can be used, but making such a judgement requires very > detailed insights in the problem. > > > Case 3: An analogue signal which contains constant segments. > > Antialias filters introduce ripples at the edge of each constant > > segment. Can this be avoided in a clever way? > > Nope. DSP filters work by convolution with waveforms. > This inevitably produces ripples near transients. > But again, non-DSP methods might be relevant, provided > one has the proper insights etc. > > > Case 4: An enum signal (a few discrete amplitude levels and > > continuous time). I guess the best approach here is to, kind of, > > just pick the sample which is closest to the new sampling time > > (nearest neighbour interpolation). > > This kind of thing can be represented as (start_time, level) > pairs. Which is outside the realm of DSP. > > > Case 5: Noisy enum signal. Using a linear filter will introduce > > lots of ripple since there are discontinuous jumps every time the > > signal changes from one amplitude state to another. My approach > > would be to use a median filter followed by the case 2 approach, > > but I guess there must be a better way? > > If you *know* that the signal is supposed to be a > number of constant segments, you could try and > detect the transitions (might be possible if the > noise amplitudes are small compared to level changes) > and estimate the levels in each segment. > > The nature of your signals seem to be rather different > from the types of signals one usually encounter in DSP. > You might want to consult fora where general time series > analysis problems are discussed. And as you understand by > now, you should also be prepared to come up with very > detailed descriptions of your data and what kinds of > information you want to extract from them. > > RuneAs a semantic quibble, I think you're off the mark in saying that the limitations of standard linear DSP are the limits are the entire field. Certainly ideas such as Vladmir's wavelet transform, or the run-length encoding that you suggested in Case 4, remain in the realm of digital signal processing. Christer, it sound like what you want isn't downsampling for its own sake, but just to get the volume of data down to a manageable level. I'm not enough of a DSP jock to help you out on case 2. However, case 3 can be handled in a the same run-length encoded way as was suggested for case 4: You try to approximate each segment as a straight line based on the first several samples you receieve; possibly adjusting that approximation slightly as more data comes in. You also define a tolerance band for that approximation. When samples come in that fall outside your tolerance band, you declare your assumption that those points were a part of the same segment as the last to be false, transmit only enough data to send the last segment as a straight line, and begin building up your next segment. Finally, on your noisy enumeration case 5, I'd implement hysteretic filtering. Start off with a crude linear filter, just to take a little of the noise off but nothing too aggressive. Then go back to picking the nearest enumeration value to your current state, but the function that you use for "nearest" has a serious bias towards staying with whatever the last state was, followed by adjacent states, and dropping off in willingness to commit to a change based on distance from where you last were. Then run-length encode yet again. -- Rob -- Rob Gaddi, Highland Technology Email address is currently out of order
Best resampling approach for different types of data?
Started by ●September 3, 2009
Reply by ●September 3, 20092009-09-03
On Thu, 03 Sep 2009 07:04:35 -0500, chrah wrote:> First of all, my apologies for posting a question that is only partly > related to DSP. However, I know that many of you are very good at > tweaking and fiddling with signals, not only in a strict DSP sense. >(I wish you'd leave the context in. This is USENET, no matter how hard Google Groups tries to make it look like another web forum, and with USENET it's nice to leave context in.) I'm not sure what restrictions Rune is placing by saying "not quite DSP". If it's a signal, and you're processing it, and you're doing it numerically, then it's DSP to me. -- www.wescottdesign.com
On Thu, 03 Sep 2009 04:59:31 -0500, chrah wrote:> Hi, > I need to downsample a bunch of signals, all of which have very > different properties (the Nyquist criteria will not be fulfilled after > the downsampling). My question is how to proceed in the best possible > way. All processing is off-line but has to be fairly fast. > > Case 1: An analogue signal (continuous amplitude and time) has been > sampled and needs to be downsampled. I have no problems here, just apply > un antialias filter and resample properly. > > Case 2: An analogue signal with discontinuous jumps. Ripples introduced > by the antialias filter makes the downsampled signal useless. Please > help. > > Case 3: An analogue signal which contains constant segments. Antialias > filters introduce ripples at the edge of each constant segment. Can this > be avoided in a clever way? > > Case 4: An enum signal (a few discrete amplitude levels and continuous > time). I guess the best approach here is to, kind of, just pick the > sample which is closest to the new sampling time (nearest neighbour > interpolation). > > Case 5: Noisy enum signal. Using a linear filter will introduce lots of > ripple since there are discontinuous jumps every time the signal changes > from one amplitude state to another. My approach would be to use a > median filter followed by the case 2 approach, but I guess there must be > a better way? > > I hope you can help > > Best regards > ChristerHow are cases 2 through 4 different, really -- I don't mean conceptually, I mean if you just look at a picture on a scope? I assume that this data is given, i.e. that you don't have influence over it's acquisition? If you do, then some other form of compression than simple sub-sampling is probably vastly better. I also assume that the anti-aliasing filter you mention is in the analog domain, before the original sampling? If you're bound and determined to use the sub-sampled data then this will actually help you to find the times of the discontinuities better, but it's kind of a nutty way to do it if you don't have to. For a signal that is just straight lines and discontinuities, then with sufficient time between the discontinuities you should be able to not only determine the level of the straight parts, but you should be able to infer the timing of the discontinuity with pretty fair accuracy. It won't be with a linear filter, though -- you'll need to decide that an edge has happened, then deduce when it happened. For a signal that's straight lines and discontinuities _and_ noise, then you should be able to extend your above result AS LONG AS the noise is moderate compared to the discontinuity size -- basically your discontinuity detector will have to be tuned to discriminate between plain old noise and real actual discontinuities. If case 3 is an analog signal with _some_ straight lines and _some_ curvy ones, then an "onset of straightness" and an "onset of curviness" detector could be used similar to the discontinuity detector I describe above, although it's operation will be much more smoky. But for cases 2, 4 and 5, it looks like you could get most of your data back for all cases where the discontinuities are spaced sufficiently far apart and are sufficiently large in comparison to the noise. -- www.wescottdesign.com
Rob,>Christer, it sound like what you want isn't downsamplingAs Tim commented on, there is a lot of context missing in my post. To start with, this is a large project where most of the decisions are made way over my head. Data from many different sources with different sample rates, some even irregularly sampled, will eventually end up in an SQL database where everything is synchronized and "pretty" so that questions such as 'select x from y where z>q and...'. My task is basically to put the data into the database with as little data loss as possible. I can do nothing about the data acquisition phase and nothing about the database, all I can do is to insert the time series with a predetermined (even) sample rate. Tim,>I also assume that the anti-aliasing filter you mention is in the analogWell, not really. Even though many of these signals are analogue to start with, they are already digital when fetched from the CAN bus. I am talking about anti-aliasing filters that have to be used in the resampling process to avoid introducing (additional) aliasing. In a previous project, the "old me" just picked out every tenth sample and that was the resampling process. You can imagine what the output looked like. All, thanks for your answers, I have learned a few new "DSP" tricks :o)
chrah wrote:> Hi, > I need to downsample a bunch of signals, all of which have very different > properties (the Nyquist criteria will not be fulfilled after the > downsampling). My question is how to proceed in the best possible way. All > processing is off-line but has to be fairly fast. > > Case 1: An analogue signal (continuous amplitude and time) has been > sampled and needs to be downsampled. I have no problems here, just apply un > antialias filter and resample properly. > > Case 2: An analogue signal with discontinuous jumps. Ripples introduced by > the antialias filter makes the downsampled signal useless. Please help. > > Case 3: An analogue signal which contains constant segments. Antialias > filters introduce ripples at the edge of each constant segment. Can this be > avoided in a clever way? > > Case 4: An enum signal (a few discrete amplitude levels and continuous > time). I guess the best approach here is to, kind of, just pick the sample > which is closest to the new sampling time (nearest neighbour > interpolation). > > Case 5: Noisy enum signal. Using a linear filter will introduce lots of > ripple since there are discontinuous jumps every time the signal changes > from one amplitude state to another. My approach would be to use a median > filter followed by the case 2 approach, but I guess there must be a better > way? > > I hope you can help > > Best regards > Christer >Christer, Let's try to break this down into a few fundamental things: By "downsample" we generally mean bringing a passband signal down to baseband with quadrature samples. This usually involves reducing the sample rate at the same time. By "decimate" or "sample rate reduction" we generally mean reducing the sample rate but leaving the signal spectrum location the same. I think you mean to decimate here / to reduce the sample rate. When there are discontinuities in the analog signal then you "should" filter before sampling so as to meet the Nyquist criterion. When there are discontinuities in a sampled signal then you "should" filter before sample rate reduction. [I say "should" because the degree, etc. becomes subjective to a degree.] Ripple at the discontinuities is caused by using a rectangular spectral window as in a "perfect" brick wall lowpass filter. Applying any filter causes convolution in the time domain. A brick wall filter has a sinc as its temporal response. The convolution with a sinc causes the ripples at transient edges. The solution to the ripples is to use a filter whose transition from passband to stopband is more gradual. There are even optimum filters that have monotonic temporal transitions - with *no* ripple and still have minimum rise time. This is as good as it gets. So, you pick a lowpass filter that has "nice" characteristics for your application and use that as a pre-decimation filter. You may want to decimate in stages using half-band filters - that's one option. With any lowpass filter you're going to have a transient in the impulse / unit sample response as the filter "fills up" with the next change in the signal. So, you may be motivated to ignore the ends of a filtered record and perhaps even to ignore the information around a step change - although that really isn't necessary. The signal, post-decimation is what it is, transients and all. Obviously you can't lowpass filter and *then* expect to identify exactly where the step changes have occurred ... at least not more accurately than the lower bandwidth allows. In general, the temporal resolution for this sort of thing is the reciprocal of the filter bandwidth. You'll be stuck with that. This ignores any fancy nonlinear processing one might do. Fred
>chrah wrote: >> Hi, >> I need to downsample a bunch of signals, all of which have verydifferent>> properties (the Nyquist criteria will not be fulfilled after the >> downsampling). My question is how to proceed in the best possible way.All>> processing is off-line but has to be fairly fast. >> >> Case 1: An analogue signal (continuous amplitude and time) has been >> sampled and needs to be downsampled. I have no problems here, justapply un>> antialias filter and resample properly. >> >> Case 2: An analogue signal with discontinuous jumps. Ripples introducedby>> the antialias filter makes the downsampled signal useless. Pleasehelp.>> >> Case 3: An analogue signal which contains constant segments. Antialias >> filters introduce ripples at the edge of each constant segment. Canthis be>> avoided in a clever way? >> >> Case 4: An enum signal (a few discrete amplitude levels and continuous >> time). I guess the best approach here is to, kind of, just pick thesample>> which is closest to the new sampling time (nearest neighbour >> interpolation). >> >> Case 5: Noisy enum signal. Using a linear filter will introduce lotsof>> ripple since there are discontinuous jumps every time the signalchanges>> from one amplitude state to another. My approach would be to use amedian>> filter followed by the case 2 approach, but I guess there must be abetter>> way? >> >> I hope you can help >> >> Best regards >> Christer >> > >Christer, > >Let's try to break this down into a few fundamental things: > >By "downsample" we generally mean bringing a passband signal down to >baseband with quadrature samples. This usually involves reducing the >sample rate at the same time. > >By "decimate" or "sample rate reduction" we generally mean reducing the >sample rate but leaving the signal spectrum location the same. > >I think you mean to decimate here / to reduce the sample rate. > >When there are discontinuities in the analog signal then you "should" >filter before sampling so as to meet the Nyquist criterion. > >When there are discontinuities in a sampled signal then you "should" >filter before sample rate reduction. >[I say "should" because the degree, etc. becomes subjective to adegree.]> >Ripple at the discontinuities is caused by using a rectangular spectral >window as in a "perfect" brick wall lowpass filter. >Applying any filter causes convolution in the time domain. >A brick wall filter has a sinc as its temporal response. >The convolution with a sinc causes the ripples at transient edges. > >The solution to the ripples is to use a filter whose transition from >passband to stopband is more gradual. There are even optimum filters >that have monotonic temporal transitions - with *no* ripple and still >have minimum rise time. This is as good as it gets. > >So, you pick a lowpass filter that has "nice" characteristics for your >application and use that as a pre-decimation filter. You may want to >decimate in stages using half-band filters - that's one option. > >With any lowpass filter you're going to have a transient in the impulse >/ unit sample response as the filter "fills up" with the next change in >the signal. So, you may be motivated to ignore the ends of a filtered >record and perhaps even to ignore the information around a step change ->although that really isn't necessary. The signal, post-decimation is >what it is, transients and all. > >Obviously you can't lowpass filter and *then* expect to identify exactly>where the step changes have occurred ... at least not more accurately >than the lower bandwidth allows. In general, the temporal resolution >for this sort of thing is the reciprocal of the filter bandwidth. >You'll be stuck with that. > >This ignores any fancy nonlinear processing one might do. > >Fred >Please tell me more about the fancy nonlinear processing. As I already mentioned, bilateral filtering works pretty good in the case where it is important to preserve the edges of a jump in the signal. Weighted median filters should also be able to do the trick fairly well. Any other suggestions? /Christer
chrah wrote:> > >chrah wrote: > >> Hi, > >> I need to downsample a bunch of signals, all of which have very > different > >> properties (the Nyquist criteria will not be fulfilled after the > >> downsampling). My question is how to proceed in the best possible way. > All > >> processing is off-line but has to be fairly fast. > >> > >> Case 1: An analogue signal (continuous amplitude and time) has been > >> sampled and needs to be downsampled. I have no problems here, just > apply un > >> antialias filter and resample properly. > >> > >> Case 2: An analogue signal with discontinuous jumps. Ripples introduced > by > >> the antialias filter makes the downsampled signal useless. Please > help. > >> > >> Case 3: An analogue signal which contains constant segments. Antialias > >> filters introduce ripples at the edge of each constant segment. Can > this be > >> avoided in a clever way? > >> > >> Case 4: An enum signal (a few discrete amplitude levels and continuous > >> time). I guess the best approach here is to, kind of, just pick the > sample > >> which is closest to the new sampling time (nearest neighbour > >> interpolation). > >> > >> Case 5: Noisy enum signal. Using a linear filter will introduce lots > of > >> ripple since there are discontinuous jumps every time the signal > changes > >> from one amplitude state to another. My approach would be to use a > median > >> filter followed by the case 2 approach, but I guess there must be a > better > >> way? > >> > >> I hope you can help > >> > >> Best regards > >> Christer > >> > > > >Christer, > > > >Let's try to break this down into a few fundamental things: > > > >By "downsample" we generally mean bringing a passband signal down to > >baseband with quadrature samples. This usually involves reducing the > >sample rate at the same time. > > > >By "decimate" or "sample rate reduction" we generally mean reducing the > >sample rate but leaving the signal spectrum location the same. > > > >I think you mean to decimate here / to reduce the sample rate. > > > >When there are discontinuities in the analog signal then you "should" > >filter before sampling so as to meet the Nyquist criterion. > > > >When there are discontinuities in a sampled signal then you "should" > >filter before sample rate reduction. > >[I say "should" because the degree, etc. becomes subjective to a > degree.] > > > >Ripple at the discontinuities is caused by using a rectangular spectral > >window as in a "perfect" brick wall lowpass filter. > >Applying any filter causes convolution in the time domain. > >A brick wall filter has a sinc as its temporal response. > >The convolution with a sinc causes the ripples at transient edges. > > > >The solution to the ripples is to use a filter whose transition from > >passband to stopband is more gradual. There are even optimum filters > >that have monotonic temporal transitions - with *no* ripple and still > >have minimum rise time. This is as good as it gets. > > > >So, you pick a lowpass filter that has "nice" characteristics for your > >application and use that as a pre-decimation filter. You may want to > >decimate in stages using half-band filters - that's one option. > > > >With any lowpass filter you're going to have a transient in the impulse > >/ unit sample response as the filter "fills up" with the next change in > >the signal. So, you may be motivated to ignore the ends of a filtered > >record and perhaps even to ignore the information around a step change - > > >although that really isn't necessary. The signal, post-decimation is > >what it is, transients and all. > > > >Obviously you can't lowpass filter and *then* expect to identify exactly > > >where the step changes have occurred ... at least not more accurately > >than the lower bandwidth allows. In general, the temporal resolution > >for this sort of thing is the reciprocal of the filter bandwidth. > >You'll be stuck with that. > > > >This ignores any fancy nonlinear processing one might do. > > > >Fred > > > > Please tell me more about the fancy nonlinear processing. As I already > mentioned, bilateral filtering works pretty good in the case where it is > important to preserve the edges of a jump in the signal. Weighted median > filters should also be able to do the trick fairly well. Any other > suggestions?Maybe you just need data compression. Is your task to store as much of the original data in a small amount of space. -jim> /Christer
chrah wrote:>> chrah wrote:> > Please tell me more about the fancy nonlinear processing. As I already > mentioned, bilateral filtering works pretty good in the case where it is > important to preserve the edges of a jump in the signal. Weighted median > filters should also be able to do the trick fairly well. Any other > suggestions? > /ChristerI'm not sure I know what to suggest... not my area of expertise. Fred
On Sep 3, 8:10�am, Jason <cincy...@gmail.com> wrote:> On Sep 3, 8:04�am, "chrah" <christer.ahlst...@vti.se> wrote: > > > >If the downsampled data are useless, there is no point of > > >downsampling. > > > Ok, useless was perhaps a strong word, sorry. The DSP related question > > would be. Is there a good way of doing 1D egde preserving filtering (or > > rather smoothing) to avoid ripples around discontinuities as much as > > possible? Bilateral filtering could be a useful approach, but something > > less CPU needy would be preferable. > > If you're wanting to use a linear filter to bandlimit the signal > before you decimate (or for that matter, an antialiasing filter before > you sample), then you are going to have ripples near discontinuities; > nothing you can do about that. Google for "Gibbs phenomenon." You can > compress the ripples in time by widening your filter bandwidth, but > their amplitude won't decrease. > > JasonJason, that is true only if the filter is "brick wall" i.e. the high frequencies are truncated suddenly. If instead the filter has a more gradual rolloff in frequency, the Gibbs ringing can be reduced and eliminated. Mark
Reply by ●September 4, 20092009-09-04
On Thu, 03 Sep 2009 15:25:45 -0500, chrah wrote:>>chrah wrote: >>> Hi, >>> I need to downsample a bunch of signals, all of which have very > different >>> properties (the Nyquist criteria will not be fulfilled after the >>> downsampling). My question is how to proceed in the best possible way. > All >>> processing is off-line but has to be fairly fast. >>> >>> Case 1: An analogue signal (continuous amplitude and time) has been >>> sampled and needs to be downsampled. I have no problems here, just > apply un >>> antialias filter and resample properly. >>> >>> Case 2: An analogue signal with discontinuous jumps. Ripples >>> introduced > by >>> the antialias filter makes the downsampled signal useless. Please > help. >>> >>> Case 3: An analogue signal which contains constant segments. Antialias >>> filters introduce ripples at the edge of each constant segment. Can > this be >>> avoided in a clever way? >>> >>> Case 4: An enum signal (a few discrete amplitude levels and continuous >>> time). I guess the best approach here is to, kind of, just pick the > sample >>> which is closest to the new sampling time (nearest neighbour >>> interpolation). >>> >>> Case 5: Noisy enum signal. Using a linear filter will introduce lots > of >>> ripple since there are discontinuous jumps every time the signal > changes >>> from one amplitude state to another. My approach would be to use a > median >>> filter followed by the case 2 approach, but I guess there must be a > better >>> way? >>> >>> I hope you can help >>> >>> Best regards >>> Christer >>> >>> >>Christer, >> >>Let's try to break this down into a few fundamental things: >> >>By "downsample" we generally mean bringing a passband signal down to >>baseband with quadrature samples. This usually involves reducing the >>sample rate at the same time. >> >>By "decimate" or "sample rate reduction" we generally mean reducing the >>sample rate but leaving the signal spectrum location the same. >> >>I think you mean to decimate here / to reduce the sample rate. >> >>When there are discontinuities in the analog signal then you "should" >>filter before sampling so as to meet the Nyquist criterion. >> >>When there are discontinuities in a sampled signal then you "should" >>filter before sample rate reduction. >>[I say "should" because the degree, etc. becomes subjective to a > degree.] >> >>Ripple at the discontinuities is caused by using a rectangular spectral >>window as in a "perfect" brick wall lowpass filter. Applying any filter >>causes convolution in the time domain. A brick wall filter has a sinc as >>its temporal response. The convolution with a sinc causes the ripples at >>transient edges. >> >>The solution to the ripples is to use a filter whose transition from >>passband to stopband is more gradual. There are even optimum filters >>that have monotonic temporal transitions - with *no* ripple and still >>have minimum rise time. This is as good as it gets. >> >>So, you pick a lowpass filter that has "nice" characteristics for your >>application and use that as a pre-decimation filter. You may want to >>decimate in stages using half-band filters - that's one option. >> >>With any lowpass filter you're going to have a transient in the impulse >>/ unit sample response as the filter "fills up" with the next change in >>the signal. So, you may be motivated to ignore the ends of a filtered >>record and perhaps even to ignore the information around a step change - > >>although that really isn't necessary. The signal, post-decimation is >>what it is, transients and all. >> >>Obviously you can't lowpass filter and *then* expect to identify exactly > >>where the step changes have occurred ... at least not more accurately >>than the lower bandwidth allows. In general, the temporal resolution >>for this sort of thing is the reciprocal of the filter bandwidth. You'll >>be stuck with that. >> >>This ignores any fancy nonlinear processing one might do. >> >>Fred >> >> > > Please tell me more about the fancy nonlinear processing. As I already > mentioned, bilateral filtering works pretty good in the case where it is > important to preserve the edges of a jump in the signal. Weighted median > filters should also be able to do the trick fairly well. Any other > suggestions? > /ChristerFor the case of finding a discontinuity you are faced with the case of deciding where an event of a known nature happened. Contrast this with the general anti-alias -> decimate -> upsample -> reconstruct case. In that case, you are reconstructing a signal of unknown nature that is known to have been bandlimited. The _only_ thing you can say _in general_ is that information has been tossed out -- but you have no clue what that information might be. On the other hand, say that you know you have nothing but straight-line data with discontinuities. For the sake of making the ASCII art easy, say that you've filtered it with a simple running average filter. So you'll get something like this: O O O O O O O Because it's a simple average filter, it's easy to fill in the output of the running average filter: O---O---O. \ \ O `--O---O---O--- From _that_ it's easy to see that the actual discontinuity happened early in a sample interval, letting the running average filter run out for a while before the sample happened. Do a bit of math, and you can name the exact time. -- www.wescottdesign.com
