Blackfin Programmable flags
Started by KIRAN September 3, 2009
Hi Guys,
I am facing some problem in using PF0 on BF531 as input. I want
interrupt ( i am using channel A) to be generated when state of PF0
changes from Logic 0 -> Logic 1 and vice versa.  This is the
configuration iam using configuration.
#define RTS_INTERRUPT_CHANNEL  PF_A_INT
#define RTS_PF_NO  0
#if (RTS_INTERRUPT_CHANNEL == PF_A_INT)
  #define RTS_MASK_SET_REG  FIO_MASKA_S
  #define RTS_MASK_CLR_REG  FIO_MASKA_C
  #define RTS_INTERRUPT_NUM PF_A_INT
  #define RTS_INTERRUPT_BIT  (1 << 19)
  #define RTS_MASK_DATA_REG FIO_MASKA_D
#else
  #define RTS_MASK_SET_REG  FIO_MASKB_S
  #define RTS_MASK_CLR_REG  FIO_MASKB_C
  #define RTS_INTERRUPT_NUM PF_B_INT
  #define RTS_INTERRUPT_BIT  (2 << 19)
  #define RTS_MASK_DATA_REG FIO_MASKB_D
#endif
     volatile unsigned short *mmr = NULL;
    volatile unsigned int *sic_imask = (volatile UINT32 *)SIC_IMASK;
      /* configure direction: logic 0--> input : logic 1-->output */
      mmr = (volatile UINT16 *)FIO_DIR;
      *mmr &= ~(1 << RTS_PF_NO);
      /* polarity: logic 0--> Active high: logic 1-->Active low */
      mmr = (volatile UINT16 *)FIO_POLAR;
      /* configure for level sensitive; logic 0-->level sensitive:
Logic 1-->edge sensitive */
      mmr = (volatile UINT16 *)FIO_EDGE;
     /* enable the interrupt */
      mmr = (volatile UINT16 *)RTS_MASK_SET_REG;
     *mmr = (1 << RTS_PF_NO);
     mmr = (volatile UINT16 *)RTS_MASK_CLR_REG;
     *mmr = (0 << RTS_PF_NO);
     /* let the initial state of RTS be high (MARK) */
     mmr = (volatile UINT16 *)RTS_MASK_DATA_REG;
     mmr = (volatile UINT16 *)FIO_INEN;
     *mmr |= (1 << RTS_PF_NO);
    /* enable PF interrupt */
       *sic_imask |= RTS_INTERRUPT_BIT;
   /*************************END********************************/
With this I receive interrupt, when PF0 is high. Inside the ISR I
don't know how set registers to receive interrupt when PF0 state
changes to logic 0. Any help is appreciated.
Regards,
Kiran
KIRAN wrote:
> Hi Guys, > > I am facing some problem in using PF0 on BF531 as input.
No problems in using BlackFin programmable flags.
> I want > interrupt ( i am using channel A) to be generated when state of PF0 > changes from Logic 0 -> Logic 1 and vice versa. This is the > configuration iam using configuration.
> #define RTS_INTERRUPT_CHANNEL PF_A_INT > #define RTS_PF_NO 0
[...poorly done code snipped...] Who would setup the IARs, the IVGs and IMASK and for my dear inquisitive friend?
> With this I receive interrupt, when PF0 is high. Inside the ISR I > don't know how set registers to receive interrupt when PF0 state > changes to logic 0.
Tip: if you don't know something, try reading the manual. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Sep 3, 8:04=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:
> KIRAN wrote: > > Hi Guys, > > > I am facing some problem in using PF0 on BF531 as input. > > No problems in using BlackFin programmable flags. > > > I want > > interrupt ( i am using channel A) to be generated when state of PF0 > > changes from Logic 0 -> Logic 1 and vice versa. =A0This is the > > configuration iam using configuration. > > #define RTS_INTERRUPT_CHANNEL =A0PF_A_INT > > #define RTS_PF_NO =A00 > > [...poorly done code snipped...] >
Why do you think so? any justification? I am simulating CTS/RTS handsake using PF's and using PF0 for RTS. With #defined LABELS I can change the interrupt channel (A or B) with minimal code changes.
> Who would setup the IARs, the IVGs and IMASK and for my dear inquisitive > friend? >
my apologies for not providing the complete information. Once am done with writing all the registers, I call a function "fosHwiAdd" to register the interrupt provided by the Fusion RTOS . I am running my application on Fusion RTOS. This API will sets IMASK, IAR, IVG for me.
> > With this I receive interrupt, when PF0 is high. Inside the ISR I > > don't know how set registers to receive interrupt when PF0 state > > changes to logic 0. > > Tip: if you don't know something, try reading the manual. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com
