Hi all, does anyone know how can I do the viterbi decoding of a very large bit stream by spliting it up in blocks? So, the output of the decoded stream of each block should be concatenated to the output of the next block. I have seen that it is a very common problem but none says how to solve it. The thing is that if I try to decode a very big string of bits, the metrics overflow. By the way, if someone has access to this document, it would be very appreciated if you could email it me... (amlmadrid@ yahoo.es) http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=176168 thanks a lot :)
Sliding Block Viterbi Decoder
Started by ●September 4, 2009
Reply by ●September 4, 20092009-09-04
On 9/4/2009 12:58 PM, amlmadrid wrote:> Hi all, > > does anyone know how can I do the viterbi decoding of a very large bit > stream by spliting it up in blocks? So, the output of the decoded stream of > each block should be concatenated to the output of the next block. I have > seen that it is a very common problem but none says how to solve it. The > thing is that if I try to decode a very big string of bits, the metrics > overflow. By the way, if someone has access to this document, it would be > very appreciated if you could email it me... (amlmadrid@ yahoo.es) > > http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=176168 > > thanks a lot :) > >Most decoder don't work on the full message length, and many can't since often the encoded stream is nearly continuous (e.g., video broadcasts, stuff like that). Search on "traceback depth" or "traceback memory" in the context of Viterbi decoders and see what you can find. I'll bet you'll get your answers that way. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Reply by ●September 6, 20092009-09-06
amlmadrid wrote:> The thing is that if I try to decode a very big string of bits, the metrics > overflow.Subtract the least weight from all paths at every step of the algorithm. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
