Hi guys, I recently ran across an interesting article on the origins of the Sampling Theorem. If such things interest you, the article is at both of the following two web sites: http://webee.technion.ac.il/courses/044130/00755459.pdf http://www.hit.bme.hu/~papay/edu/Conv/pdf/origins.pdf See Ya', [-Rick-]
An Interesting Historical Paper on Sampling
Started by ●September 6, 2009
Reply by ●September 6, 20092009-09-06
On Sep 6, 7:19=A0am, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:> Hi guys, > =A0 I recently ran across an interesting article > on the origins of the Sampling Theorem. > > If such things interest you, the article is > at both of the following two web sites: > > http://webee.technion.ac.il/courses/044130/00755459.pdfhttp://www.hit.bme=.hu/~papay/edu/Conv/pdf/origins.pdf> > See Ya', > [-Rick-]I like at the end that they say the Sampling theory is attributed to Shannon-Nyquist etc etc but don't put the guy who was Historically first first! Whittaker.
On Sep 6, 12:07 pm, HardySpicer <gyansor...@gmail.com> wrote:>... > > I like at the end that they say the Sampling theory is attributed to > Shannon-Nyquist etc etc but don't put the guy who was Historically > first first! Whittaker.This is a characteristic tendency of human groups to award naming status to those whose publications have made a discovery more immediately convenient to a user group instead of to earlier discoverers. Examples include the DSP window known as Kaiser-Bessel which had earlier been published as 'Taylor one parameter', but has been credited to Kaiser since his publication of his rediscovery of Bessel's convenient series formula for the modified Bessel function of the first kind on the blackboard of one of his associates at Bell Labs.There is also the case of the continent and country where I live taking their name, in part, from the name of Amerigo Vespucci instead of from the name of Christopher Columbus or any of the others who have been suggested as early visitors to the New World. Dale B. Dalrymple
Reply by ●September 7, 20092009-09-07
>Hi guys, > I recently ran across an interesting article >on the origins of the Sampling Theorem. > >If such things interest you, the article is >at both of the following two web sites: > >http://webee.technion.ac.il/courses/044130/00755459.pdf >http://www.hit.bme.hu/~papay/edu/Conv/pdf/origins.pdfThat paper says who who wrote about the baseband and bandpass cases. It doesn't say who wrote about the complex sampling case. That would be interesting. I'm not sure this paper goes back far enough. I seem to remember reading about a statistician way back in the 19th century figuring out the basics of sampling, though I can't remember who it was. Of course, a part of the picture must have been obvious to the earliest investigators of stroboscopic effects. Steve
Reply by ●September 9, 20092009-09-09
On Sep 6, 3:07�pm, HardySpicer <gyansor...@gmail.com> wrote:> On Sep 6, 7:19�am, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote: > > > Hi guys, > > � I recently ran across an interesting article > > on the origins of the Sampling Theorem. > > > If such things interest you, the article is > > at both of the following two web sites: > > >http://webee.technion.ac.il/courses/044130/00755459.pdfhttp://www.hit... > > > See Ya', > > [-Rick-] > > I like at the end that they say the Sampling theory is attributed to > Shannon-Nyquist etc etc but don't put the guy who was Historically > first first! Whittaker.Actually, Whittaker is mentioned under the section "The Mathematicians". Cheers, David
Reply by ●September 10, 20092009-09-10
On 7 ���, 07:00, "steveu" <ste...@coppice.org> wrote:> >Hi guys, > > I recently ran across an interesting article > >on the origins of the Sampling Theorem. > > >If such things interest you, the article is > >at both of the following two web sites: > > >http://webee.technion.ac.il/courses/044130/00755459.pdf > >http://www.hit.bme.hu/~papay/edu/Conv/pdf/origins.pdf > > That paper says who who wrote about the baseband and bandpass cases. It > doesn't say who wrote about the complex sampling case. That would be > interesting. > > SteveOn the one hand Kotelnikov in "On the transmission capacity of 'ether' and wire in electrical communications", issued in 1933, has proved the theorem for a minimum sampling frequency of quadratures (Theorem IV): "If x(t) has frequencies from F1 to F2, then x(t) = x1(t)*cos(2piF0t) + x2(t)*sin(2piF0t), where F0=(F1+F2)/2, x1(t) and x2(t) have frequencies from 0 to (F2-F1)/ 2. So x1(t) and x2(t) can be sampled with Fs => F2-F1." In modern DSP books x1(t) and -x2(t) are known as "inphase" and "quadrature" components of x(t), while Kotelnikov did not name it so. Complex envelope ("minimal" complex forms of x(t)) is defined as: y(t) = x1(t) + j(-x2(t)) So sampling frequency for y(t) is the same as for x1(t) and x2(t). It seems, Kotelnikov`s Theorem IV is the first mention of an opportunity of such decomposition. On the other hand in original work Kotelnikov has proved all theorems for real signals. He used the math of real Fourier transform, so the proof seems difficult. But if to use the math of complex Fourier transform the proofs of theorems become simple and obvious. Also it becomes clear, that theorems are true for both real and complex signals. In this case Fs => Fh-Fl, where Fh is highest frequency in spectrum, Fl is lowest frequency in spectrum (for real signal spectrum includes negative frequencies, so Fl = -Fh). Andrew.
