Hi all, I am relatively new to using FFTW.. I have been using FFTW to take fft for a few complex matrices. My problem is that I am not gettign the same values in Matlab and C++, the values seem to be differing after the sixth or seventh significant bit. When we use fftw_plan are we using double precision by default or do we have to use fftwl_plan[so on for all the fftw calls]?? I have been trying to use fftwl_plan, but my code seems to get hung. The error that i get is Unhanded exception in the libfftw3l.dll. 1.Can someone tell me the default precision used in FFTW?? 2.What other factors should I be considering inorder to make my values in matlab and C++ the same?? Thank you in advance.
Double precision in FFTW
Started by ●September 9, 2009
Reply by ●September 9, 20092009-09-09
>Hi all, > >I am relatively new to using FFTW.. I have been using FFTW to take fftfor>a few complex matrices. My problem is that I am not gettign the samevalues>in Matlab and C++, the values seem to be differing after the sixth or >seventh significant bit. When we use fftw_plan are we using double >precision by default or do we have to use fftwl_plan[so on for all thefftw>calls]?? I have been trying to use fftwl_plan, but my code seems to get >hung. The error that i get is Unhanded exception in the libfftw3l.dll. > >1.Can someone tell me the default precision used in FFTW?? >2.What other factors should I be considering inorder to make my valuesin>matlab and C++ the same?? > >Thank you in advance. > >Hi all,I am trying to use long double precision...I have issues when i run libfftw3l.dll.. I cannot seem to understand what else could have gone wrong for the values in Matlab and C++ to differ. This seems to happen only for huge complex matrices. Could someone please help me with this problem of mine. I have been with this problem for quite a while now.. thank you.
Reply by ●September 10, 20092009-09-10
chiraag wrote:> Hi all, > > I am relatively new to using FFTW.. I have been using FFTW to take fft for > a few complex matrices. My problem is that I am not gettign the same values > in Matlab and C++, the values seem to be differing after the sixth or > seventh significant bit. When we use fftw_plan are we using double > precision by default or do we have to use fftwl_plan[so on for all the fftw > calls]?? I have been trying to use fftwl_plan, but my code seems to get > hung. The error that i get is Unhanded exception in the libfftw3l.dll. > > 1.Can someone tell me the default precision used in FFTW?? > 2.What other factors should I be considering inorder to make my values in > matlab and C++ the same?? > > Thank you in advance. >Default precision for FFTW is double. You have to explicitly build a single precision version if you want to work with floats. I don't know off-hand if FFTW supoorts long double precision but I would imagine that this kind of thing is covvered in the documentation. Paul
On Sep 8, 11:17 pm, "chiraag" <sinara...@gmail.com> wrote:> Hi all, >...> 2.What other factors should I be considering inorder to make my values in > matlab and C++ the same?? >Exactly what calls are you making and how are you comparing the results? Dale B. Dalrymple
On Sep 9, 2:17�am, "chiraag" <sinara...@gmail.com> wrote:> I am relatively new to usingFFTW.. I have been usingFFTWto take fft for > a few complex matrices. My problem is that I am not gettign the same values > in Matlab and C++, the values seem to be differing after the sixth or > seventh significant bit.The sixth significand "bit"? That would be a huge error. Do you mean the sixth or seventh significant decimal digit? Although even that would be a huge error. Both Matlab (which uses FFTW) and FFTW are double precision in the ordinary interface, and normally they should differ only in the 14th-15th significant decimal digit. If you are getting much bigger differences than this then you are probably calling one or the other incorrectly.> When we use fftw_plan are we using double > precision by default or do we have to use fftwl_plan[so on for all thefftw > calls]?? I have been trying to use fftwl_plan, but my code seems to get > hung. The error that i get is Unhanded exception in the libfftw3l.dll.fftw_* is double precision, fftwf_* is single precision, and fftwl_* is long double precision. This is documented in the FFTW manual in the section titled (not surprisingly) "Precision": http://fftw.org/doc/Precision.html However, you may have trouble with fftwl_* on Windows because Microsoft Visual C++ does not support extended precision. In Visual C+ +, "long double" is the same as double. The libfftw3l library from the FFTW site, on the other hand, was compiled with gcc which does support extended precision, so you can only use it with other compilers that support extended precision (gcc or the Intel compiler). This is probably why it hangs if you try to call the fftwl_* functions, because you are passing data of the wrong size. See also: http://en.wikipedia.org/wiki/Long_double In any case, it is unlikely that you need long double -- double should be enough for almost any application. Even for an extremely large FFT, the accumulation of roundoff errors in FFTW (and other floating- point FFTs) is extremely slow, so usually you will get nearly machine precision. See fftw.org/accuracy Regards, Steven G. Johnson
