Hi I'm trying to get fftw3 running in visual studio C++ 2008. have linked libfftw3-3.lib in project properties->config properties->linker->input: additional dependencies:libfftw3-3.lib libfftw3f-3.lib libfftw3l-3.lib and added C:\FFTProj\fftw-3.2.2-dll64 to my INCLUDE path, LIB path and PATH. when I execute libfftw3-3.lib on the command line it starts VSC++ but on cancel windows says. The system cannot find the file C:\FFTProj\fftw-3.2.2-dll64\libfftw3-3.lib. so its registered but windows keeps complaining. I can compile a fftw program in VSC++ and no complaints ( although in another project I keep getting warning LNK4248: unresolved typeref token (0100001C) for 'fftw_plan_s'; image may not run ) anyway, it builds an executable and on running complains that it cant find libfftw3-3.lib. Is there somewhere else in VSC ++ 2008 that i should configure for fftw3? also, I'm on vista SP1. Thanks Ian
fftw3 compilation in VSC++ 2008 on vista SP1
Started by ●September 18, 2009
Reply by ●September 18, 20092009-09-18
>when I execute libfftw3-3.lib on the command line it starts VSC++ but on >cancel windows says.Huh? Windows can't execute .lib files. That's just an archive of object code. Do you mean you associated that extension with MSVC?>anyway, it builds an executable and on running complains that it cant >find >libfftw3-3.lib. Is there somewhere else in VSC ++ 2008 that i should >configure for fftw3? also, I'm on vista SP1.Windows shouldn't be looking for a .lib. If you're trying to link dynamically (the only way I've done it), Windows should be looking for libfftw3-3.DLL; otherwise, it shouldn't be looking for anything. Try downloading "dependency walker" to see what it's really looking for. On VC++ 6, at least, you add libfftw3-3.lib to the "Object/library modules" on the "Link" tab. Not sure about your version, but read the online help. Since you didn't say the compiler's complaining, obviously it's not a problem with your #include directory, so that's just noise. Have you ever used a DLL before?
