Hi all. I have done a PLL for tracking frecuency carrier in a MFSK demodulator. I have used a moving filter average of length=64 as low pass filter. I cannot rise lenght more than 64 because then PLL would not track frecuency desviations of the transmitter. I dont know if there are other filters better than moving average filter for this application, without surpass 64 coeeficients. Can i use butterword filter low pass or similars??????
Low Pass Filter for a PLL
Started by ●September 20, 2009
Reply by ●September 20, 20092009-09-20
JAlbertoDJ wrote:> Hi all. > > I have done a PLL for tracking frecuency carrier in a MFSK demodulator. I > have used a moving filter average of length=64 as low pass filter. I cannot > rise lenght more than 64 because then PLL would not track frecuency > desviations of the transmitter. > > I dont know if there are other filters better than moving average filter > for this application, without surpass 64 coeeficients. > > Can i use butterword filter low pass or similars?????? >
Reply by ●September 21, 20092009-09-21
On Sun, 20 Sep 2009 17:47:48 -0500, JAlbertoDJ wrote:> Hi all. > > I have done a PLL for tracking frecuency carrier in a MFSK demodulator. > I have used a moving filter average of length=64 as low pass filter. I > cannot rise lenght more than 64 because then PLL would not track > frecuency desviations of the transmitter. > > I dont know if there are other filters better than moving average filter > for this application, without surpass 64 coeeficients. > > Can i use butterword filter low pass or similars??????Don't put FIR filters inside of control loops, unless you _really_ know what you're doing. Are you really implementing a PLL, or are you just implementing a phase estimator and calling it a PLL? Generally when you put a low pass filter inside a control loop the degradation to the loop response far exceeds the noise suppression of the low pass filter. Furthermore, the filter poles will generally become less stable when you close the loop, so if you _do_ put a low pass filter in your loop you want to make it far more heavily damped than you would outside a loop. So you really only want a low pass filter in there if your measurement has _lots_ of high frequency noise, and if tracking is relatively unimportant. This narrows things down: while there _are_ loops where low pass filters are indicated, you generally want a low-order (often just one pole) IIR filter, and you want to make sure you know what you're doing. -- www.wescottdesign.com
