Hi I am trying to implement a program in Matlab in order to apply a window to the peaks of the envelope of an OFDM signal. The window I am using is a Gaussian window, with factor gamma (exp(-gamma*t^2)) I have already implemented it, but I do not know if the results obtained are so satisfactory as they should be. My concern is on the proper choice of the value gamma: I make it inversely proportional to the duration of the peak above the threshold (that is, if there are 8 samples in a peak above the decided threshold, the factor gamma is proportional to 1/(8*SamplingTime^2)), but this is a rough approach and I have not found anything about the choice of this factor when appying peak windowing to OFDM. Is there anyone with experience in this topic who may suggest me anything, please? Thanks
Peak Windowing for OFDM
Started by ●September 23, 2009
Reply by ●September 23, 20092009-09-23
Crisanquito <crisancost@hotmail.com> wrote:>I am trying to implement a program in Matlab in order to apply a window to >the peaks of the envelope of an OFDM signal. The window I am using is a >Gaussian window, with factor gamma (exp(-gamma*t^2))>I have already implemented it, but I do not know if the results obtained >are so satisfactory as they should be. My concern is on the proper choice >of the value gamma: I make it inversely proportional to the duration of the >peak above the threshold (that is, if there are 8 samples in a peak above >the decided threshold, the factor gamma is proportional to >1/(8*SamplingTime^2)), but this is a rough approach and I have not found >anything about the choice of this factor when appying peak windowing to >OFDM.I have no insight into why you need to do this. (e.g. I don't know whether this signal is in the transmitter or the receiver, whether you are analyzing it or implementing some processing upon it, etc.) You need to enlighten us... Steve
>Crisanquito <crisancost@hotmail.com> wrote: > >>I am trying to implement a program in Matlab in order to apply a windowto>>the peaks of the envelope of an OFDM signal. The window I am using is a >>Gaussian window, with factor gamma (exp(-gamma*t^2)) > >>I have already implemented it, but I do not know if the resultsobtained>>are so satisfactory as they should be. My concern is on the properchoice>>of the value gamma: I make it inversely proportional to the duration ofthe>>peak above the threshold (that is, if there are 8 samples in a peakabove>>the decided threshold, the factor gamma is proportional to >>1/(8*SamplingTime^2)), but this is a rough approach and I have notfound>>anything about the choice of this factor when appying peak windowing to >>OFDM. > >I have no insight into why you need to do this. (e.g. I don't >know whether this signal is in the transmitter or the receiver, >whether you are analyzing it or implementing some processing >upon it, etc.) > >You need to enlighten us... > >Steve >I have an OFDM model in Matlab and in the transmitter I am using a device with a limited "quasi-linear" region (it is an optical modulator). I just want to limit the excursion of the signal amplitude, I do not want it to get any value. I think this is a step into a more realistic model of a communication system with OFDM. After the IFFT processing in the transmitter, I am trying to apply peak windowing in order to limit its excurssion. Hard clipping is another option, but I want also to try peak windowing to not ruin so much the performance. I do not know which more details you need, but I will give you them pleasantly if you can help me.
Crisanquito <crisancost@hotmail.com> wrote:>I have an OFDM model in Matlab and in the transmitter I am using a device >with a limited "quasi-linear" region (it is an optical modulator). I just >want to limit the excursion of the signal amplitude, I do not want it to >get any value. I think this is a step into a more realistic model of a >communication system with OFDM.I have had good luck with clipping the tx OFDM waveform at about 4x RMS. Hope this helps. Steve
Crisanquito wrote:> Hi > > I am trying to implement a program in Matlab in order to apply a window to > the peaks of the envelope of an OFDM signal. The window I am using is a > Gaussian window, with factor gamma (exp(-gamma*t^2))Yes, this is one of the methods for PAPR reduction; it is better then hardlimiting.> I have already implemented it, but I do not know if the results obtained > are so satisfactory as they should be.I don't know what do you consider as "satisfactory". What is the goal of your exersize?> My concern is on the proper choice > of the value gamma: I make it inversely proportional to the duration of the > peak above the threshold (that is, if there are 8 samples in a peak above > the decided threshold, the factor gamma is proportional to > 1/(8*SamplingTime^2)), but this is a rough approach and I have not found > anything about the choice of this factor when appying peak windowing to > OFDM.Think of the impact of your window as if you are adding the noise to the OFDM signal. The goal is the optimum performance considering the resulting PAPR and SNR.> Is there anyone with experience in this topic who may suggest me anything, > please?Textbook stuff. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●September 24, 20092009-09-24
> > >Crisanquito wrote:>> I have already implemented it, but I do not know if the resultsobtained>> are so satisfactory as they should be. > >I don't know what do you consider as "satisfactory". What is the goal of>your exersize?Well, I have just seen the effects of the windowing process on the envelope of the signal. What I see is the next: the maximum value of the peak is effectively reduced, but the sample next to it (or maybe two samples next to it), originally also above the threshold, is, once the windowing process is performed, higher than the previous maximum. Example: Threshold=3; SamplesAboveThreshold=[3 4 5 4 3] SamplesAfterWindowing=[2 3.25 3 3.25 2], so now the problem is with the samples with value 3.25. The result depends of the factor gamma chosen, and I have not found any reference with a systematic explanation which relates the value of the factor with the duration of the peak, or something similar.>> Is there anyone with experience in this topic who may suggest meanything,>> please? > >Textbook stuff.I have already checked some books and articles, but no any detailed explanation, so if there is anyone who has programmed this before, can tell me what approach to take? Thanks for the answer
Crisanquito wrote:> Well, I have just seen the effects of the windowing process on the > envelope of the signal. What I see is the next: the maximum value of the > peak is effectively reduced, but the sample next to it (or maybe two > samples next to it), originally also above the threshold, is, once the > windowing process is performed, higher than the previous maximum. Example:You are looking at the problem from the entirely wrong perspective. Limiting the envelope is no-brainer, but the real question is how much of BER performance impairment would you take due to that limiting. This is a long question as it depends on the parameters of OFDM and the channel. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Crisanquito <crisancost@hotmail.com> wrote:>Well, I have just seen the effects of the windowing process on the >envelope of the signal. What I see is the next: the maximum value of the >peak is effectively reduced, but the sample next to it (or maybe two >samples next to it), originally also above the threshold, is, once the >windowing process is performed, higher than the previous maximum. Example: > >Threshold=3; >SamplesAboveThreshold=[3 4 5 4 3] >SamplesAfterWindowing=[2 3.25 3 3.25 2], so now the problem is with the >samples with value 3.25.Confirm that your peak algorithm operates on the magnitude, rather than on the I/Q signal. S.
> > >Crisanquito wrote: > > >> Well, I have just seen the effects of the windowing process on the >> envelope of the signal. What I see is the next: the maximum value ofthe>> peak is effectively reduced, but the sample next to it (or maybe two >> samples next to it), originally also above the threshold, is, once the >> windowing process is performed, higher than the previous maximum.Example:> >You are looking at the problem from the entirely wrong perspective. >Limiting the envelope is no-brainer, but the real question is how much >of BER performance impairment would you take due to that limiting. This >is a long question as it depends on the parameters of OFDM and thechannel. My objective is, or it was, to make peak windowing in the correct way, after that I would be able to study the level of clipping, the value of the threshold to be applied in order to find a trade off, as you comment. But if I do not make it in the correct way, I will introduce unnecesary performance impairment, if will distort the signal more than necessary. And the distortion I introduce depends on the value of gamma (window=exp(-gamma*t^2)). At this point, my doubts are: -Should I take a value of gamma which depends on the duration of each peak above the threshold, or should I take a fixed value? I mean, why to use the same duration window with a peak with 9 samples above the threshold than with a peak with just one sample above the threshold? -Then, if I take a value of gamma which depends on the duration of the peak, which relationship should be in order to obtain a proper scaling of the peak? For sure it must be easier than I think.>Crisanquito <crisancost@hotmail.com> wrote: > >>Well, I have just seen the effects of the windowing process on the >>envelope of the signal. What I see is the next: the maximum value ofthe>>peak is effectively reduced, but the sample next to it (or maybe two >>samples next to it), originally also above the threshold, is, once the >>windowing process is performed, higher than the previous maximum.Example:>> >>Threshold=3; >>SamplesAboveThreshold=[3 4 5 4 3] >>SamplesAfterWindowing=[2 3.25 3 3.25 2], so now the problem is with the >>samples with value 3.25. > >Confirm that your peak algorithm operates on the magnitude, >rather than on the I/Q signal. >My peak algorithm operates just after the IFFT processing, on the magnitude of the digital samples.
