Hi, all. I have a problem to compensate "sampling phase error" In spectrum analyzer, I get the sampling data from analog signal to OFDM signal. but I knew that there is sampling phase error. I mean, sampled data can be expressed as y[0], y[1], y[2].....for time domain signal. but, it is not exact point. In some processing sampled data with C language, there were some phase error. That is, for example, exact sampling point is y[0.4], y[1.4], y[2.4].... how can I recover the phase error with OFDM signal? [(ex) y[0] -> y[0.4)] I can not control it in Spectrum analyzer. I should recover it with only using the sampled data.
Sampling phase error
Started by ●September 23, 2009
Reply by ●September 23, 20092009-09-23
On 23 Sep, 13:22, "wirelessor" <wireles...@gmail.com> wrote:> but I knew that there is sampling phase error. > > I mean, sampled data can be expressed as y[0], y[1], y[2].....for time > domain signal. > > but, it is not exact point. In some processing sampled data with C > language,Ah. There's your error. You should have used assmbly. Or matlab. Rune
wirelessor wrote:> Hi, all. > > I have a problem to compensate "sampling phase error" > > In spectrum analyzer, I get the sampling data from analog signal to OFDM > signal. > > but I knew that there is sampling phase error. > > I mean, sampled data can be expressed as y[0], y[1], y[2].....for time > domain signal. > > but, it is not exact point. In some processing sampled data with C > language, > > there were some phase error. That is, for example, exact sampling point is > y[0.4], y[1.4], y[2.4].... > > how can I recover the phase error with OFDM signal? [(ex) y[0] -> y[0.4)] > > I can not control it in Spectrum analyzer. > > I should recover it with only using the sampled data.Hey studiot: "Interpolation" is the keyword. VLV
