Please excuse me if this is a stupid question, but DSP hardware isn't my field of expertise. A business partner has an algorithm applicable to schocastic data, for which it isn't possible to reverse engineer by studying the outputs and inputs. Is it possible to fabricate a custom DSP chip in such a way to prevent the underlying algorithm from being extracted, so it can remain a trade secret? -A
Snoop-proof DSP: possible?
Started by ●September 26, 2009
Reply by ●September 26, 20092009-09-26
axlq wrote:> Please excuse me if this is a stupid question, but DSP hardware > isn't my field of expertise. > > A business partner has an algorithm applicable to schocastic data, > for which it isn't possible to reverse engineer by studying the > outputs and inputs. Is it possible to fabricate a custom DSP > chip in such a way to prevent the underlying algorithm from being > extracted, so it can remain a trade secret?It is possible to make a custom or semi-custom chip, however you need to order large quantities to be commertially viable. You can use DSP with security features, like ADI BlackFin. That protection is good enough to stop an individual hacker. Any chip can be reverse engineered, this is a matter of money and capabilities of the attacker. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Sat, 26 Sep 2009 16:59:44 +0000 (UTC), axlq@spamcop.net (axlq) wrote:>Please excuse me if this is a stupid question, but DSP hardware >isn't my field of expertise. > >A business partner has an algorithm applicable to schocastic data, >for which it isn't possible to reverse engineer by studying the >outputs and inputs. Is it possible to fabricate a custom DSP >chip in such a way to prevent the underlying algorithm from being >extracted, so it can remain a trade secret? > >-AThere is no %100 protection but there are several levels of protection which can be put into a design to make the cost of reverse engineering increasingly higher. Most protection mechanisms involve a battery backed volatile storage for your design content/encryption keys. These features are available in a number of DSP processors/FPGAs. Solutions which have non-volatile storage of the design are usually much easier to duplicate than otherwise. -- Muzaffer Kal DSPIA INC. ASIC/FPGA Design Services http://www.dspia.com
Reply by ●September 27, 20092009-09-27
On Sat, 26 Sep 2009 16:59:44 +0000, axlq wrote:> Please excuse me if this is a stupid question, but DSP hardware isn't my > field of expertise. > > A business partner has an algorithm applicable to schocastic data, for > which it isn't possible to reverse engineer by studying the outputs and > inputs. Is it possible to fabricate a custom DSP chip in such a way to > prevent the underlying algorithm from being extracted, so it can remain > a trade secret? > > -AAnd you can put the World's Best Lock on your door -- but sooner or later you'll come home to find a hole cut out of your wall. Nothing will keep a well-funded potential competitor from grinding the top off the chip and reverse-engineering (or just outright copying) the code and/or design. But as others have said, there are chips with security features that'll make it harder. All you can ever do is make it hard enough to be unprofitable; you'll never make it impossible. -- www.wescottdesign.com
Reply by ●September 28, 20092009-09-28
In article <E_adneyngKqVlCLXnZ2dnUVZ_qydnZ2d@web-ster.com>, Tim Wescott <tim@seemywebsite.com> wrote:>On Sat, 26 Sep 2009 16:59:44 +0000, axlq wrote: >> A business partner has an algorithm applicable to schocastic data, for >> which it isn't possible to reverse engineer by studying the outputs and >> inputs. Is it possible to fabricate a custom DSP chip in such a way to >> prevent the underlying algorithm from being extracted, so it can remain >> a trade secret?>Nothing will keep a well-funded potential competitor from grinding the >top off the chip and reverse-engineering (or just outright copying) the >code and/or design. > >But as others have said, there are chips with security features that'll >make it harder. > >All you can ever do is make it hard enough to be unprofitable; you'll >never make it impossible.That's what I figured. I appreciate all the responses. I would have thought these days the chip circuitry might be sufficiently 3-dimensional to make grinding off the top impractical for copying purposes. -A
On 9/27/2009 8:45 PM, axlq wrote:> In article<E_adneyngKqVlCLXnZ2dnUVZ_qydnZ2d@web-ster.com>, > Tim Wescott<tim@seemywebsite.com> wrote: >> On Sat, 26 Sep 2009 16:59:44 +0000, axlq wrote: >>> A business partner has an algorithm applicable to schocastic data, for >>> which it isn't possible to reverse engineer by studying the outputs and >>> inputs. Is it possible to fabricate a custom DSP chip in such a way to >>> prevent the underlying algorithm from being extracted, so it can remain >>> a trade secret? > >> Nothing will keep a well-funded potential competitor from grinding the >> top off the chip and reverse-engineering (or just outright copying) the >> code and/or design. >> >> But as others have said, there are chips with security features that'll >> make it harder. >> >> All you can ever do is make it hard enough to be unprofitable; you'll >> never make it impossible. > > That's what I figured. I appreciate all the responses. > > I would have thought these days the chip circuitry might be > sufficiently 3-dimensional to make grinding off the top impractical > for copying purposes. > > -AIt's still expensive to de-cap a chip. You have to really want to do it to go that route, but it is possible. And you're right, getting through all the layers is so expensive that it's rarely done, but, still, it's possible. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
axlq <axlq@spamcop.net> wrote: < In article <E_adneyngKqVlCLXnZ2dnUVZ_qydnZ2d@web-ster.com>, < Tim Wescott <tim@seemywebsite.com> wrote: (snip) <>Nothing will keep a well-funded potential competitor from grinding the <>top off the chip and reverse-engineering (or just outright copying) the <>code and/or design. (snip) <>All you can ever do is make it hard enough to be unprofitable; you'll <>never make it impossible. < That's what I figured. I appreciate all the responses. < I would have thought these days the chip circuitry might be < sufficiently 3-dimensional to make grinding off the top impractical < for copying purposes. That does make it harder, but I beleive that there is still an etch photograph repeat process to slowly go through the layers. The usual processors used in systems such as smart cards are produced in large quantities and for a low price each. The many metal layers of 64 bit processors are not needed and not affordable. http://www.cl.cam.ac.uk/~mgk25/tamper.pdf -- glen
Eric Jacobsen <eric.jacobsen@ieee.org> wrote: (big snip) < It's still expensive to de-cap a chip. You have to really want to do it < to go that route, but it is possible. And you're right, getting through < all the layers is so expensive that it's rarely done, but, still, it's < possible. About 35 years ago someone showed my how to decap cerdip chips by putting them in a vice such that one side pushes on the top and the other on the bottom. A little squeeze and the top (usually) pops right off. Plastic is somewhat harder, but, again see: http://www.cl.cam.ac.uk/~mgk25/tamper.pdf where they show how to do it with inexpensive equipment. -- glen
>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: >(big snip) > >< It's still expensive to de-cap a chip. You have to really want to do it>< to go that route, but it is possible. And you're right, gettingthrough>< all the layers is so expensive that it's rarely done, but, still, it's>< possible. > >About 35 years ago someone showed my how to decap cerdip chips >by putting them in a vice such that one side pushes on the top >and the other on the bottom. A little squeeze and the top >(usually) pops right off. > >Plastic is somewhat harder, but, again see: > >http://www.cl.cam.ac.uk/~mgk25/tamper.pdf > >where they show how to do it with inexpensive equipment.That paper is quite old. It seems a lot more is possible now, mostly because people have had more years to think up devious strategies. Beware of attacks by students. They tend to be in well equipped places for attacking chips at low cost. :-) Regards, Steve
On Sep 26, 12:59�pm, a...@spamcop.net (axlq) wrote:> Please excuse me if this is a stupid question, but DSP hardware > isn't my field of expertise. > > A business partner has an algorithm applicable to schocastic data, > for which it isn't possible to reverse engineer by studying the > outputs and inputs. �Is it possible to fabricate a custom DSP > chip in such a way to prevent the underlying algorithm from being > extracted, so it can remain a trade secret? > > -AYou might want to follow different route: instead of selling specialized DSP hardware (or software) you can sell a server-based service. This way nobody will have access to your servers so reverse- engineering of software algorithms will not be possible. That's what Google does for the most part That's why they could compete against MShit while Netscape could not Server-based vs client-based - makes all the difference Tamper-proof, hacker-proof, trade secrets forever...
