Help needed in Finding of Standard deviation of Random Noise
Started by Abdul Nasir Khan March 6, 2004
I am reading a digital signal processing book
"The Scientist and Engineer's Guide to Digital Signal Processing"
2nd Edition
by "Steven W. Smith"
I could not understand the following concept in its second chapter
QUOTE
Each random number has a value between zero and one, with an equal
probability of being anywhere between these two extremes. Figure 2-10a
shows a signal formed by taking 128 samples from this type of random
number generator. The mean of the underlying process that generated
this signal is 0.5, the standard deviation is, and the 1 / (12)^0.5 =
0.29 distribution is uniform between zero and one.
UNQUOTE
I couldn't derive
standard deviation = 1 / (12)^0.5
my derivation is as follows
Mean = Sum(xi, i=0 to n-1) / n = 0.5
variance= (1/n)*Sum( (xi-Mean)^2) 						{i=0 to n-1}
    	= (1/n)*Sum( (xi^2 + Mean^2 - 2*xi*Mean)) 			{i=0 to n-1}
	= (1/n)*(Sum(xi^2) + Sum(Mean^2) - Sum(2*xi*Mean))		{i=0 to n-1}
	= (1/n)*Sum(xi^2) + (1/n)*Sum(Mean^2) -(1/n)*Sum(2*xi*Mean) {i=0 to
n-1}
	= (1/n)*Sum(xi^2) + (Mean^2) - (2*Mean)(1/n)*Sum(xi)		{i=0 to n-1}
	= (1/n)*Sum(xi^2) + (Mean^2) - (2*Mean^2)				{i=0 to n-1}
	= (1/n)*Sum(xi^2) - (Mean^2)						{i=0 to n-1}
Now we know the value of mean (which is 0.5) but how can we know the
value for Sum(xi^2)
Abdul Nasir Khan wrote:
> I am reading a digital signal processing book > > "The Scientist and Engineer's Guide to Digital Signal Processing" > 2nd Edition > by "Steven W. Smith" > > > I could not understand the following concept in its second chapter > > QUOTE > Each random number has a value between zero and one, with an equal > probability of being anywhere between these two extremes. Figure 2-10a > shows a signal formed by taking 128 samples from this type of random > number generator. The mean of the underlying process that generated > this signal is 0.5, the standard deviation is, and the 1 / (12)^0.5 = > 0.29 distribution is uniform between zero and one. > UNQUOTE > > I couldn't derive > > standard deviation = 1 / (12)^0.5 > > my derivation is as follows > > Mean = Sum(xi, i=0 to n-1) / n = 0.5 > > variance= (1/n)*Sum( (xi-Mean)^2) {i=0 to n-1} > = (1/n)*Sum( (xi^2 + Mean^2 - 2*xi*Mean)) {i=0 to n-1} > = (1/n)*(Sum(xi^2) + Sum(Mean^2) - Sum(2*xi*Mean)) {i=0 to n-1} > = (1/n)*Sum(xi^2) + (1/n)*Sum(Mean^2) -(1/n)*Sum(2*xi*Mean) {i=0 to > n-1} > = (1/n)*Sum(xi^2) + (Mean^2) - (2*Mean)(1/n)*Sum(xi) {i=0 to n-1} > = (1/n)*Sum(xi^2) + (Mean^2) - (2*Mean^2) {i=0 to n-1} > = (1/n)*Sum(xi^2) - (Mean^2) {i=0 to n-1} > > > Now we know the value of mean (which is 0.5) but how can we know the > value for Sum(xi^2)
The claim of uniform distribution allows you to reorder the sequence to make an arithmetic series. You are effectively calculating the moment of inertia of a stick about its center of gravity. Does that help? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
You have a "uniform distribution". The mean and variance of a uniform distribution between 'a' and 'b' are: 1/2 * (a + b) <-- mean 1/12 * (b - a)^2 <-- variance See this site: http://mathworld.wolfram.com/UniformDistribution.html Good luck, OUP
Abdul,
You're going about this the wrong way.  Theoretically, uniform random
variables have a continuous probability density function and so you
should compute its variance using that definition (look this up in any
probability book):
    Variance(x) = integral of (x - 0.5)*(x - 0.5) dx
where the integration is over the interval zero to one.
You can use the samples to estimate the variance of your samples, but
you cannot use them to compute the variance of the "underlying process".
Mike
