Why overlap-save algo applys more often than overlap-add? What is its advantage comparing with overlap-add? HyeeWang
overlap-save vs. overlap-add
Started by ●October 14, 2009
Reply by ●October 14, 20092009-10-14
On 14 Okt, 10:40, HyeeWang <hyeew...@gmail.com> wrote:> Why overlap-save algo applys more often than overlap-add? �What is its > advantage comparing with overlap-add?Don't know the two algorithms well enough to comment on the specifics, but in general any of several reasons might decide. There are the technical reasons, like - One method has some superior advantage, like less computational complexity or less memory footprint in terms of auxillary variables etc. - One method is simpler to understand and implement But then there are the arbitrary reasons, like - One method tends to be listed first in textbooks. People read till they find it, realizes it's what they need, and never bother to investigaet the other - One method is already dominant among users. One very often wants to eliminate variables in investigations. For that reason, one tends to select the most popular methods for the standard tasks. "If you want to step off the beaten path, make sure you have a good reason." Rune
For some reason overlap add seems to get mentioned more in text books at least that's my impression. Overlap save is a bit easier to handle and more efficient because you eliminate a bunch of adds. Except when you want to partition your impulse response it all gets a bit tricky.
"Fully Half Baked" <jfezl07@googlemail.com> wrote in message news:3353030c-28d2-4ceb-a26a-88a1775cc0f2@f16g2000yqm.googlegroups.com...> For some reason overlap add seems to get mentioned more in text books > at least that's my impression. Overlap save is a bit easier to handle > and more efficient because you eliminate a bunch of adds. Except when > you want to partition your impulse response it all gets a bit tricky.I've used zero padded overlap-save successfully in reverb convolutions; and overlap-add for vocoder applications, where the overlap is more than 2.
>Why overlap-save algo applys more often than overlap-add? What is its >advantage comparing with overlap-add? > >HyeeWang >I've often wondered what the real difference was as well. While I can see the implementation difference, both algorithms are used for implementation of fast convolution using STFT. This is supposed to be more efficient when a large number of filter taps are needed, such as in reverb effects where a room's impulse response has been sampled. The real question is, is there any difference in output, or are both algorithms numerically equivalent to convolution the conventional way? Jacob
On Oct 14, 3:14=A0pm, "foxcob" <jacob.the...@gmail.com> wrote:> >Why overlap-save algo applys more often than overlap-add? =A0What is its > >advantage comparing with overlap-add? > > >HyeeWang > > I've often wondered what the real difference was as well. =A0While I can =see> the implementation difference, both algorithms are used for implementatio=n> of fast convolution using STFT. =A0This is supposed to be more efficient =when> a large number of filter taps are needed, such as in reverb effects where=a> room's impulse response has been sampled. =A0The real question is, is the=re> any difference in output, or are both algorithms numerically equivalent t=o> convolution the conventional way? > > JacobBoth algorithms are equivalent. Short of any differences in the result based on finite precision (since the actual operations you're doing are different, you might end up with different roundoff errors), you will get the same answer. Jason
On Wed, 14 Oct 2009 14:14:58 -0500, "foxcob" <jacob.thefox@gmail.com> wrote:>The real question is, is there >any difference in output, or are both algorithms numerically equivalent to >convolution the conventional way?Overlap and add is necessary if your filter is time-varying. Greg
Reply by ●October 16, 20092009-10-16
On Oct 14, 8:11=A0pm, "contact" <cont...@invalid.com> wrote:> "Fully Half Baked" <jfez...@googlemail.com> wrote in messagenews:3353030c=-28d2-4ceb-a26a-88a1775cc0f2@f16g2000yqm.googlegroups.com...> > > For some reason overlap add seems to get mentioned more in text books > > at least that's my impression. Overlap save is a bit easier to handle > > and more efficient because you eliminate a bunch of adds. Except when > > you want to partition your impulse response it all gets a bit tricky. > > I've used zero padded overlap-save successfully in reverb convolutions; a=nd> overlap-add for vocoder applications, where the overlap is more than 2.I tried this a few weeks ago but it wasn't obvious to me how to keep overlap save with a partitioned impulse. So tell us how you do it ;)
>"Fully Half Baked" <jfezl07@googlemail.com> wrote in message >news:6bbdcadc-67f4-4ab6-aa56-4254c08b2b54@g23g2000yqh.googlegroups.com... >On Oct 14, 8:11 pm, "contact" <cont...@invalid.com> wrote: >> "Fully Half Baked" <jfez...@googlemail.com> wrote in >> messagenews:3353030c-28d2-4ceb-a26a-88a1775cc0f2@f16g2000yqm.googlegroups.com... >> >> > For some reason overlap add seems to get mentioned more in text books >> > at least that's my impression. Overlap save is a bit easier to handle >> > and more efficient because you eliminate a bunch of adds. Except when >> > you want to partition your impulse response it all gets a bit tricky. >> >> I've used zero padded overlap-save successfully in reverb convolutions; >> and >> overlap-add for vocoder applications, where the overlap is more than 2. > >I tried this a few weeks ago but it wasn't obvious to me how to keep >overlap save with a partitioned impulse. >So tell us how you do it ;)Try:- http://tinyurl.com/yzl582h ; ) I can basically remember converting the IR into FFT sections by placing the impulse signal on the left half with zeros on the right, stepping through the signal in half FFT length overlaps. Then when in the convolution loop (2X overlap) use the right half to save as the continuous signal. Something like that.
On Oct 16, 9:27=A0pm, "contact" <cont...@invalid.com> wrote:> >"Fully Half Baked" <jfez...@googlemail.com> wrote in message > >news:6bbdcadc-67f4-4ab6-aa56-4254c08b2b54@g23g2000yqh.googlegroups.com..=.> >On Oct 14, 8:11 pm, "contact" <cont...@invalid.com> wrote: > >> "Fully Half Baked" <jfez...@googlemail.com> wrote in > >> messagenews:3353030c-28d2-4ceb-a26a-88a1775cc0f2@f16g2000yqm.googlegro=ups.com...> > >> > For some reason overlap add seems to get mentioned more in text book=s> >> > at least that's my impression. Overlap save is a bit easier to handl=e> >> > and more efficient because you eliminate a bunch of adds. Except whe=n> >> > you want to partition your impulse response it all gets a bit tricky=.> > >> I've used zero padded overlap-save successfully in reverb convolutions=;> >> and > >> overlap-add for vocoder applications, where the overlap is more than 2=.> > >I tried this a few weeks ago but it wasn't obvious to me how to keep > >overlap save with a partitioned impulse. > >So tell us how you do it ;) > > Try:- =A0http://tinyurl.com/yzl582h=A0 =A0 ; ) > I can basically remember converting the IR into FFT sections by placing t=he> impulse signal on the left half with zeros on the right, stepping through > the signal in half FFT length overlaps. Then when in the convolution loop > (2X overlap) use the right half to save as the continuous signal. Somethi=ng> like that.I'm pretty sure that I scraped the bottom of googles barrel at the time but didn't find a single explanation of it. What you've explained sounds just like overlap save but the problem came when the impulse response was longer than the input buffer it wasn't obvious how to do it so I ended up with overlap add. I probably just need to sit down with it sometime and figure it out properly.
