uclinux
Started by ramya October 19, 2009
1. How are system calls implemented ,interrupts are handled in
uclinux?
2. Does uclinux supports Reserving  hard ware resources for a real
time task ?
On Mon, 19 Oct 2009 04:58:29 -0700, ramya wrote:
> 1. How are system calls implemented ,interrupts are handled in uclinux? > > 2. Does uclinux supports Reserving hard ware resources for a real time > task ?
a. Google is your friend. b. This would be a great question for the comp.arch.embedded group -- comp.dsp is mostly about DSP algorithms and theory, a little about DSP practice, and very little about embedded. -- www.wescottdesign.com
ramya wrote:
> 1. How are system calls implemented ,interrupts are handled in > uclinux?
Which ucLinix?
> 2. Does uclinux supports Reserving hard ware resources for a real > time task ?
Which ucLinux? Reserving what? Reserwing how? For what task? The problem is not about using or not using C++. The problem is because pizza delivery boys don't make good programmers. VLV
Vladimir Vassilevsky wrote:
> > > ramya wrote: > >> 1. How are system calls implemented ,interrupts are handled in >> uclinux? > > Which ucLinix? > >> 2. Does uclinux supports Reserving hard ware resources for a real >> time task ? > > Which ucLinux? Reserving what? Reserwing how? For what task? > > The problem is not about using or not using C++. The problem is because > pizza delivery boys don't make good programmers.
Don't be so hard on the kid. I'm pretty sure than nowadays, some programmers make good pizza deliverers. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>The problem is not about using or not using C++. The problem is because >pizza delivery boys don't make good programmers. > >VLV >
This is too bad assumption that OP is somebody pizza delivery person or pizza dilvery boys do not make good programmers. Somebody had told me one good thing: Assumption is the mother of all fuck ups. You never know what is going to happen in future. And believe me or not, after some harsh comments to somebody or may be a tight slap, a little help and good guidance can make wonders. Chintan
On Mon, 19 Oct 2009 15:36:58 -0500, cpshah99 wrote:
>>The problem is not about using or not using C++. The problem is because >>pizza delivery boys don't make good programmers. >> >>VLV >> >> > This is too bad assumption that OP is somebody pizza delivery person or > pizza dilvery boys do not make good programmers. > > Somebody had told me one good thing: Assumption is the mother of all > f*** ups. >
Nah, the way to put it is to break the word "assume" into it's component parts: assume something, and you make an ass out of u and me. -- www.wescottdesign.com
On Mon, 19 Oct 2009 12:28:31 -0400, Jerry Avins wrote:
> Vladimir Vassilevsky wrote: >> >> >> ramya wrote: >> >>> 1. How are system calls implemented ,interrupts are handled in >>> uclinux? >> >> Which ucLinix? >> >>> 2. Does uclinux supports Reserving hard ware resources for a real >>> time task ? >> >> Which ucLinux? Reserving what? Reserwing how? For what task? >> >> The problem is not about using or not using C++. The problem is because >> pizza delivery boys don't make good programmers. > > Don't be so hard on the kid. I'm pretty sure than nowadays, some > programmers make good pizza deliverers. > > Jerry
And pizza boys can grow into good programmers, but only if they start working at it. -- www.wescottdesign.com
>On Mon, 19 Oct 2009 12:28:31 -0400, Jerry Avins wrote: > >> Vladimir Vassilevsky wrote: >>> >>> >>> ramya wrote: >>> >>>> 1. How are system calls implemented ,interrupts are handled in >>>> uclinux? >>> >>> Which ucLinix? >>> >>>> 2. Does uclinux supports Reserving hard ware resources for a real >>>> time task ? >>> >>> Which ucLinux? Reserving what? Reserwing how? For what task? >>> >>> The problem is not about using or not using C++. The problem is
because
>>> pizza delivery boys don't make good programmers. >> >> Don't be so hard on the kid. I'm pretty sure than nowadays, some >> programmers make good pizza deliverers. >> >> Jerry > >And pizza boys can grow into good programmers, but only if they start >working at it.
I expect they produce some pretty cheesy designs, though. Steve
cpshah99 wrote:
>>The problem is not about using or not using C++. The problem is because >>pizza delivery boys don't make good programmers. >> > > This is too bad assumption that OP is somebody pizza delivery person or > pizza dilvery boys do not make good programmers. > > Somebody had told me one good thing: Assumption is the mother of all fuck > ups. > > You never know what is going to happen in future. > > And believe me or not, after some harsh comments to somebody or may be a > tight slap, a little help and good guidance can make wonders. > > Chintan
Apparently, that didn't make wonder in your case. So, back to pizzas. VLV
> > >cpshah99 wrote: > >>>The problem is not about using or not using C++. The problem is because
>>>pizza delivery boys don't make good programmers. >>> >> >> This is too bad assumption that OP is somebody pizza delivery person
or
>> pizza dilvery boys do not make good programmers. >> >> Somebody had told me one good thing: Assumption is the mother of all
fuck
>> ups. >> >> You never know what is going to happen in future. >> >> And believe me or not, after some harsh comments to somebody or may be
a
>> tight slap, a little help and good guidance can make wonders. >> >> Chintan > >Apparently, that didn't make wonder in your case. So, back to pizzas. > >VLV > >
Hahhaha May be nobody gave me help or guidance.... Anyways.. You hardly know me buddy.....You have not even seen me..... I dont know when I will be coming to USA, but surely I will try to meet u.. And as long as I am not dead, I have got plenty of time..... Bye for now.... Take good care of yourself buddy..... Chintan
