Cost of DSP In Other Consumer Items
Started by Bret Cahill ●October 20, 2009
Digital hearing aids seem to remain pretty pricy.  Is anything else
using DSP more expensive than a $300 laptop?
Bret Cahill
On 20 Oct, 09:42, Bret Cahill <BretCah...@peoplepc.com> wrote:
> Digital hearing aids seem to remain pretty pricy. &#4294967295;Is anything else > using DSP more expensive than a $300 laptop? > > Bret Cahill
High end digital HD TV - $2,000 Medical ultrasound - $20,000 MRI - $20,000,000
These two are not consumer goods.
>Medical ultrasound - $20,000 >MRI - $20,000,000 >
This is a bit closer to what Bret asked of: Sigma SD14 digital single-lens reflex camera. It costs about 700 USD at amazon.com and as far as I know it uses ADSP-BF561 for image processing. I guess that there are much more examples in the field of embedded multimedia systems. -- Alexander
> > Digital hearing aids seem to remain pretty pricy. &#4294967295;Is anything else > > using DSP more expensive than a $300 laptop? > > > Bret Cahill > > High end digital HD TV - $2,000 > Medical ultrasound - $20,000 > MRI - $20,000,000
DSP isn't responsible for most of those costs. Bret Cahill
Chris Bore wrote:
> > On 20 Oct, 09:42, Bret Cahill <BretCah...@peoplepc.com> wrote: > > Digital hearing aids seem to remain pretty pricy. Is anything else > > using DSP more expensive than a $300 laptop? > > > > Bret Cahill > > High end digital HD TV - $2,000 > Medical ultrasound - $20,000 > MRI - $20,000,000
Microdyne RCB-2000 telemetry reciever - $80,000 -- The movie 'Deliverance' isn't a documentary!
Bret Cahill wrote:
> Digital hearing aids seem to remain pretty pricy. Is anything else > using DSP more expensive than a $300 laptop?
Is the cost of a $300 laptop different from the cost of a $300 bicycle? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Tue, 20 Oct 2009 14:43:30 -0400
Jerry Avins <jya@ieee.org> wrote:
> Bret Cahill wrote: > > Digital hearing aids seem to remain pretty pricy. Is anything else > > using DSP more expensive than a $300 laptop? > > Is the cost of a $300 laptop different from the cost of a $300 > bicycle? > > Jerry
Only insofar as two years from now, replacing your $300 bicycle won't yet have crossed your mind. -- Rob Gaddi, Highland Technology Email address is currently out of order
Rob Gaddi wrote:
> On Tue, 20 Oct 2009 14:43:30 -0400 > Jerry Avins <jya@ieee.org> wrote: > >> Bret Cahill wrote: >>> Digital hearing aids seem to remain pretty pricy. Is anything else >>> using DSP more expensive than a $300 laptop? >> Is the cost of a $300 laptop different from the cost of a $300 >> bicycle? >> >> Jerry > > Only insofar as two years from now, replacing your $300 bicycle won't > yet have crossed your mind.
You must be right. I still have the $96.50 bicycle I got in 1947. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Oct 20, 10:21&#4294967295;am, Bret Cahill <BretCah...@peoplepc.com> wrote:
> > High end digital HD TV - $2,000 > > Medical ultrasound - $20,000 > > MRI - $20,000,000 > > DSP isn't responsible for most of those costs.
Welcome to engineering! DSP is used when it is less costly than the alternatives; it is a cost savings to use a DSP filter rather than a tuned seven-pole wundernetwork. DSP is responsible, in a way, for the cost difference in HDTV using coupled vanadium tuning forks and HDTV with DSP, that actually does show up on the store shelves. Alas, there ISN"T any vanadium-tuning-fork price data easily available for this comparison.
> > Digital hearing aids seem to remain pretty pricy. &#4294967295;Is anything else > > using DSP more expensive than a $300 laptop? > > Is the cost of a $300 laptop different from the cost of a $300 bicycle?
The first derivative is certainly different. Bret Cahill
